THEY SAID IT COUNDN'T BE DONE
Discussion in '1st Gen. Tacomas (1995-2004)' started by kerns 2495, Jun 17, 2012.
  1. Jun 17, 2012 at 5:25 AM
    kerns 2495
    kerns 2495 [OP] Member
    scott
    va
    2001 dbl. cab 4x4
    2" body lift, 2.5 " coil over with rear blocks
    Well just came back from my trial run. No problems at all. Toyota says no possible way to flat tow my 1st generation tacoma/ w the auto matic tranny. After lots of disscussion and a little nerve, I decided to set the record straight once and for all. Although my trip was only for twenty miles , no heat build-up was found in any of the drivetrain. I do intend on taking a much longer trip this week. I simply remove the rear shaft , set xfer case to neutral , dis connect battery, turn key one click for steering and start rollin. I had to add the extra bulb in my rear tail light housing ,because of the way toyota builds with the flat 5 wire system. Any way I think there should be a section somewhere in our forums ,maybe in towing where people can understand you can flat tow the trucks , with out worry. I have done quite a bit of research on this topic and found that no one really ever tried. I'm going 400 miles next week, If that does'nt prove something , well I don't no.
  2. Jun 17, 2012 at 5:34 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    you're not the first. . but congrats, glad it all worked out for you.
  3. Jun 17, 2012 at 5:39 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    People flat tow 1st gen trucks all the time. As you disconnected the driveshaft, there is no need to put the transfer case in neutral.
  4. Jun 17, 2012 at 6:02 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    He does not mean towing on a flat bed...I think.
    Talking about towing it behind something.
  5. Jun 17, 2012 at 6:04 PM
    jgwheeler17
    NC
    neglect, mostly.
    yeah, that's called flat towing. four wheels on the ground.
  6. Jun 17, 2012 at 6:11 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :facepalm:
  7. Jun 17, 2012 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good job! many folks wonder what the correct method for flat towing these trucks is.
  8. Jun 18, 2012 at 5:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I thought the general concensus always has been that if you removed the rear drive shaft you could flat tow the Tacoma :confused:
  9. Jun 18, 2012 at 6:35 AM
    Pugga
    Massachusetts
    That's what I figured, most people wouldn't go through the hassle of removing the drive shaft every time they needed to tow a vehicle. So is it just me or have we not broken any new barriers here... :anonymous:
  10. Jun 18, 2012 at 6:50 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Pulled my 2nd gen on a dolly for 400 odd miles. Trick is to disconnect the rear drive shaft from the axle. Same effect for flat pulling
  11. Jun 18, 2012 at 4:39 PM
    kerns 2495
    scott
    va
    2001 dbl. cab 4x4
    So whyt does'nt Remco offer a simplew drive shaft disconnect. Like it does for thwe pre runner
