Things that make you say hmmm...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by argm31i, Nov 6, 2007.
  1. Nov 6, 2007 at 11:14 AM
    argm31i
    argm31i [OP] Well-Known Member
    Anybody got an idea what the in-bed load capacity is on an 07 Tacoma? I know that options (TRD, towing package, etc.) might make a difference, but I was just looking for round numbers, and from what I've found, nobody has a definitive answer.
    Thanks!
  2. Nov 6, 2007 at 11:51 AM
    gcwaterski
    gcwaterski Well-Known Member
  3. Nov 6, 2007 at 11:56 AM
    GTiVR6r
    GTiVR6r Big Cat Chew Toy
    Carpentersville, IL
    07 Tacoma Access Cab 2.7L Impulse Red
    According to Toyota's website and the brochure
    Load capacity for Man. Trans is 1350 Lbs
    Load capaciaty for Auto Trans is 1380 Lbs
    - M
  4. Nov 6, 2007 at 12:06 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Yea, its different for each model but i wanna say for your truck it should be around 900lbs, but if you've done the suspension TBS i would make it an even 1000... or more.... basically i'm gonna load it up till it bottoms out, but thats just me
  5. Nov 6, 2007 at 12:07 PM
    nd
    Nate
    Greenville, SC
    Really? i didnt know it was that high. I think the load capcity goes down alot when you have the double cab too, but i dont know
  6. Nov 6, 2007 at 12:17 PM
    GTiVR6r
    Carpentersville, IL
  7. Nov 6, 2007 at 1:12 PM
    argm31i
    Thanks for the info guys.
  8. Nov 7, 2007 at 4:16 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    This is weird. On My Nissan pickup the manual trans could take more than the auto...why is this opposite with the Tacomas?
  9. Nov 7, 2007 at 6:19 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    What year Nissan? And are you sure about that? I looked at an 04 Frontier before I bought my 04 Tacoma, and wound up getting the 2.7L in the Taco because the 2.7L 5-speed tacoma could pull 3500 lbs, and the 3.5L v6 Nissan with a 5-speed could also pull 3500 lbs, while an auto in the Nissan was rated for 5000 lbs.
    Oh, and to answer your question. It is not a weakness of transmission in the Toyota it is that the auto trans weighs more, and threfore decreases the payload capacity by the additional weight of the transmission because the GVWR of the truck does not change.
  10. Nov 7, 2007 at 7:11 AM
    argm31i
    You're right about that...that's also the reason that the 4x4 has less capacity...the stuff to make it 4x4 (transfer case, etc.) makes it weigh more and therefore, it can handle less load for the given GVWR.
  11. Jan 12, 2008 at 5:02 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I don't know about max weight in the bed. I have read on other boards people putting 2000-3000 lbs in the bed even while towing 6000 lb trailers. I think that would be a little excessive!...But what really makes me go hmmmmmmmmm...why the hell is it 2008 and these new trucks still have the same problems as the 2005-2007?..You think toyota would have learned by now!
  12. Jan 12, 2008 at 5:39 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I had 1300 lbs in the bed of my DC, it was squating pretty good, but no problems.
  13. Jan 13, 2008 at 6:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    With the TSB springs I would assume.....
  14. Jan 13, 2008 at 6:50 AM
    Janster
    Jandy
    Lancaster, PA
    What's a scoop of mulch weigh?
    Just curious, cuz that's what I'll be expecting my taco to haul this spring.
    ON my old 96 taco - I had the rear leaf pak re-arched with 2 custom AAL's made at the same time. That rear suspension was HEAVY DUTY and I absolutely love it!! It laughed at the mulch!
    I'm wondering if this TSB spring pak can handle a scoop of mulch?
  15. Jan 13, 2008 at 7:40 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I have the AAL's from my Toytec 3" lift in and I've loaded around 1600lbs of wood pellets (give or take a couple 40lb bags) 3 times now. I have between 1/2 and 1/4 inch left between the bump stops and springs each time.
    So I'd say with an AAL lift OR the TSB, 1,000lbs should be fine. Just keep an eye on it beyond that.
    The thing I can't get a clear answer on is if the cargo capacity (~1300lbs according to Toyota) includes passengers, etc in the cab, or if it's just the bed. I'm assuming it's everything, but you know what they say about ass-uming. So if you have 2 adults in there, keep that in mind.
  16. Jan 13, 2008 at 7:47 AM
    concrete jedi
    Rochester N.Y
    No just what came with it.
  17. Jan 13, 2008 at 8:46 AM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
    The owners manual says "Vehicle load limits includes total load capacity, seating capacity, towing capacity, and cargo capacity" and "Total load capacity means combined weight of occupants, cargo, and luggage." In the 2007 owners manual they even give an example of figuring the passengers weight and subtracting it from the total allowed.
    It has been the same way for every truck I have owned.
    Another thing to remember is that anything added to your truck reduces the amount of cargo you can carry. This would include a trailer hitch, bed mat, tonneau cover or cap, and any racks you install for carrying stuff.
    Most Tacoma owners will never need to worry about the cargo limit, but it is also easy to exceed it if you don't think ahead. For example; concrete blocks weigh 40 pounds each. My access cab has 1.340 pounds of payload. If I have 340 pounds of passengers and misc stuff already in the truck that means I can load 25 blocks in the bed. The bed will hold more than that and if you don't realize it you can overload the truck.
    My experience is that most small truck owners don't overload their trucks with one big item, but load way too many smaller items into the bed not realizing how much it adds up to.
    Most places that load stuff like gravel or wood mulch can tell you how much it weighs per cubic yard and know the volume of the buckets on their equipment. You can then figure out what your load will be.
    Watch out for the operators that dump their buckets while high above your bed. Even if the weight is within limits the shock of dropping the load in can damage your truck.
  18. Jan 13, 2008 at 12:53 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Remember also, trailer tongue weight also counts as cargo weight.
  19. Jan 14, 2008 at 4:35 AM
    Viper-2
    Keith
    Charleston, SC
    It was a 1997 Nissan Hardbody and I'm absolutely certain about the payloads.
  20. Jan 14, 2008 at 7:18 AM
    maverick491
    South Jersey
    Ok, perhaps there was a diference between your 97, and the 03/04 frontiers that I had looked at. And I may have responded incorrectly as I realize now that you were talking about payload and I was talking about towing. So I stand corrected. :)
