Thinking about buying a 2013 Jayco x17z
Discussion in 'Towing' started by celica91st, Sep 26, 2017.
  1. Sep 26, 2017 at 7:02 PM
    celica91st
    celica91st [OP] New Member
    D
    2009 Taco V6 4x4
    I have an 09 Tacoma SR5, V6, 4x4 with access cab and towing package. The Jayco is 2580lbs, with a GVWR of 3500lbs. Dry hitch weight of 350lbs. Unfortuntely I don't have the 7 pin connector for the trailer brakes, only the 4 pin (which I have to replace since it was corroded).
    So, A) I'm assuming that this towing this is ok since the the Tacoma is rated for towing up to 6500lbs. and B) can I get away with not having a brake controller just to take it home from the point of sale, which is roughly 20 miles away? The road going home is a country road and pretty flat.
    Is there anything else anyone can suggest to get, such as trailer mirrors, weight distribution hitch, etc.?
  2. Sep 27, 2017 at 6:56 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I would not want to tow that kind of weight without brakes even a short distance and depending on your state I'm pretty sure it's not legal so if you get in a crash, even if it's not your fault you may be held liable. Can you borrow a truck with a brake controller just to get it home? And if you have the towing package, on an 09 you should have a factory harness with the 7 way plug. Why do you only have a flat 4? Tow mirrors are a very good idea and also probably needed for compliance with the law.
  3. Sep 27, 2017 at 11:18 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    If you don't have the 7 pin you don't have the towing package (unless the 7 pin was broken off and replaced with a 4 pin which wouldn't make any sense).
    You're going to want a brake controller, a WD hitch, and towing mirrors. You should also confirm that you do in fact have the towing package, if not the towing limit is 3,500lbs.
  4. Sep 30, 2017 at 5:50 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Your truck can do it and you won't even crash if you don't have to stop fast. I've done it not legally with a 1999 4-cylinder.
  5. Sep 30, 2017 at 5:56 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Don't forget tranny cooler if you've got an auto. I'd say airbags or beefier rear springs as well. (I've added both to mine which does have the tow package)
  6. Oct 12, 2017 at 11:51 AM
    tow-coma
    tow-coma Well-Known Member
    Look up the state requirements for towing trailers in that weight. You may need trailer brakes to be legal towing it home
  7. Oct 20, 2017 at 9:40 PM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Lord Humongous likes this.
