Thinking about getting a dirtbike, few questions
Discussion in 'Motorcycles' started by TACOMABOSS, Jun 19, 2012.
  1. Jun 19, 2012 at 6:08 PM
    TACOMABOSS
    TACOMABOSS [OP] Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    As the title states, Im thinking about getting a dirtbike. Bare with me here, Im sort of a noob. Ive been around quads my whole life :eek: Anyways, for a new rider, is a 125 a good starter bike? im 6'+ 160lbs. Anything under a 125 I think would be too small for me. Ive also thought about a 150 or a 200, too much for a new rider? Ive ridden a 200 before, only once and it was my first time on a dirtbike. Definatly want a 2-stroke. Thoughts, comments, concerns?
  2. Jun 19, 2012 at 7:05 PM
    TACOMABOSS
    96 SR5 4x4
    bump. anyone?
  3. Jun 19, 2012 at 7:12 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    All depends on what u want. If you wanna race a two stroke won't keep up. IMHO two strokes are fading fast. In the trails you will foul out plugs than the thing won't run. Get a 4 stroke 250 and your all set!
  4. Jun 19, 2012 at 7:14 PM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    are you looking at getting something new? and what are you looking are do trails? race?
  5. Jun 19, 2012 at 7:29 PM
    TACOMABOSS
    96 SR5 4x4
    Im not going to race haha
    Not new. Mostly trails. I was thinking yz125? Anyone have experience with those? I was also thinking a KTM 125, but those are pricey!
  6. Jun 19, 2012 at 7:36 PM
    TACOMABOSS
    96 SR5 4x4
    Which do you prefer? 2-stroke or 4-stroke? And why?
  7. Jun 19, 2012 at 7:40 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Four stroke! They r much more reliable don't have to rev the hell out of them
    All day long in the trails. Don't have to worry about fouling a plug or
    Messing with reeds and all that crap. Buy a four stroke they don't stink easier to ride on the trails since a two stroke always wants to go faster it's hard to keep at a constant throttle.
  8. Jun 19, 2012 at 7:42 PM
    TACOMABOSS
    96 SR5 4x4
    I thought 4-strokes had good low end power and 2-strokes had the high end power?
  9. Jun 19, 2012 at 8:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    4 stroke.
    Smoother power band... good torque available over a wider RPM range.
    2 strokes have a very narrow band, and when they hit, they hit hard.
    Inexperienced riders quite often loop it.
    Of course, I've looped my 250 thumper a couple of times....
    Yes, I'm flat-footing it. I'm 6'3".
    Yes, I moved the pegs down and back, and modded the seat with foam that's 2" taller.
  10. Jun 19, 2012 at 8:32 PM
    hondarider215
    hondarider215 Well-Known Member
    Wes
    Socal
    KR Tacoma
    KR Fabrication front and rear bumper ICON 2.5 c/o's All pro leafs Maxtrac Fox rear resi shocks Lr uca 17" methods
    If you want a 2 stroke than definitely get a 125cc and if you want more power later on big bored it :)
    If i was you id get a 250 4 stroke and since you do trails id recommend a crf250x. They are really easy to ride and they go as fast as you want them to go so they are okay for beginner riders. Plus you get electric start with a headlight on the x model. I ride both trail and track so i have the crf250r and it does great in both
  11. Jun 19, 2012 at 8:38 PM
    TACOMABOSS
    96 SR5 4x4
    Well this is interesting haha I figured a 2-stoke is a good starter bike.. My friends KTM 200 has a pretty wide power band
    250 isnt to much for a beginner rider?
  12. Jun 19, 2012 at 8:42 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1 on the dual-purpose competition grade bike.
    Stay away from the 230, and be careful with Yamaha's WR series. When I got mine, the only difference between the WRf and YZf engine was the cam timing (easy enough to change). The WR had a wide-ratio gearbox which was AWESOME for trails... 1st gear you could idle at a walking pace, and the rev limiter in 5th was around 80mph (got there a few times in Ocotillo).
    By comparison, the YZ is a pure competition bike. 50 pounds lighter without the starter and battery, but also tops out at around 65mph... and that's screaming wound out at the rev limiter (12k?).
    The WR will cruise 65 all day in 5th.
    BUT.....
    Somewhere around 2008, Yamaha revamped the WR250 lineup and added a true dual sport and a street legal Motard.
    At the same time, they separated the engine from the YZ design, so it became more than just a detuned YZ.
    I'm not familiar with Honda's offerings, but in 2005 the CRF250x was the equivalent of the WR250F. Don't know if they took the same road departing from the pure performance of the CRF later or not.
  13. Jun 19, 2012 at 8:45 PM
    TACOMABOSS
    96 SR5 4x4
    wow thats some really good info. thanks! il keep this in mind
  14. Jun 19, 2012 at 8:47 PM
    diesel30
    diesel30 Well-Known Member
    columbus ohio
    2011 dbl cab long bed trd sport 4x4 mag gray
    carbon fiber blacked out grill ddm tuning hid kit 35w/55w bi-xenon kit ddm tuning hid fog light kit 35w m/t classic lock blacks fierce attitudes 285/70/17 5100's installed on front 2.5" rear TSB done masterlock tailgate lock 35% front window tint scangaugeII duplicolor red caliper paint
    If you want a great woods bike that will be very low on maintenance upkeep look for a pre-owned ktm 200 xc-w. it's a 200 2 stroke with electric start and it's geared for smooth power ideal for the woods. Maintenance on a 4 stroke is very expensive compared to the 2 stroke. top end rebuild on a 4 stroke = $5-600 every 40-50 hours. Top end rebuild kit for ktm = $ 140 once a year at most. The ktm will have a bit more power but will also be a smoother power hit than a 125 that you'll have to run the piss out of to get it to go anywhere.
  15. Jun 19, 2012 at 8:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    250 4-stroke competes in the same class as the 125 2-stroke.
    450 4-stroke competes in the same class as the 250 2-stroke.
    Oh... that's right... the AMA is doing everything they can to kill the 2-stroke.
    But seriously, a 4-stroke is SO much simpler.
    There's no mixing oil into your fuel... run out of gas on the trail and you can bum a gallon from anyone. Plugs last for-freaking-ever. Fuel lasts almost twice as long. Even on the stock tank (the '05 WR had a 3 gallon tank I think?) my buddy and I could ride 80 miles.
    We added 4.3 gallon "desert tanks" and can make over 100 miles now.
    And the EPA and some states are progressively taking steps to ban 2-strokes from the trails. Already, in California, you are severely limited in the "season" for riding what is called "red-sticker" bikes. In some desert areas it's Labor Day to Memorial day. In some mountain areas it's Dec-15 to Jan-15.
  16. Jun 19, 2012 at 8:49 PM
    usfatboy01
    usfatboy01 Member
    Jeff
    Portland, Oregon
    '11Tacoma Reg Cab 4X4
    She a Stocker, from really good stock, too.
    ++++1
  17. Jun 19, 2012 at 8:50 PM
    hondarider215
    Wes
    Socal
    KR Tacoma
    I wouldnt think so I pretty much jumped from a ttr125 to a crf250r when i was 12. Like i said they go as fast as you want them to go. A 2 stroke can get away from you and a 4 stroke can too but the 4 stroke has a much smoother power band plus i think they are easier on trails than a 2 stroke. I own both a kx144 and a crf250r and id take the 250 over the 144 just because its smoother. My kx144 is faster than my 250 and hauls ass but like anything you can control it to go as fast as you want it to go.
  18. Jun 19, 2012 at 8:53 PM
    TACOMABOSS
    96 SR5 4x4
    two of my friends have the KTM 200 xc. not the xc-w though. great bike just really pricey
    Im well aware of the red sticker issue.. i used to have a 2-stoke quad lol. seems like most everyone is leaning towards a 4-stoke on here
  19. Jun 19, 2012 at 8:55 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Go with a 250 four stroke, im 5'9 and 140 pounds and its perfect for me so it'll be great for you and it has good power in all rpms. I have a kawasaki 250f right now, i had a yz125 2 stroke and it was good but youll like the 250 better! Good luck :thumbsup:
    edit: if you get a 125 youll want to upgrade later, so just go for the 250 ;)
  20. Jun 19, 2012 at 8:57 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    i love 2 stokes. i would still have one if more people made em. seems they are fading. plus my 450 yamaha runs superb and takes very little maint. it has crazy torque, full fmf exhaust with megabomb header. but i still love 2 strokes.. btw I'm 6' 170 pounds so size doesn't always pick your bike, more about your skill;)
