Thinking about Lifting the Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlvmaiden, Apr 20, 2014.
  1. Apr 20, 2014 at 12:47 PM
    rlvmaiden
    rlvmaiden [OP] Member
    Calgary
    Hey, just bought a 2014 Taco and I'm thinking about putting a small lift/level on it. I don't plan on getting bigger tires or anything, just purely for aesthetics.
    I'm thinking about going with 5100s on the front set at either 1.75 or 2.5, and then maybe just a spacer on the back, but not too sure what size to keep the truck level. I want to avoid dealing with diff drop, replacing uca, etc. from the lift as I'm not very knowledgeable with that stuff yet.
    Any advice?
  2. Apr 20, 2014 at 1:38 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    You can do a 3 inch with no diff drop, no uca, it will work just fine
  3. Apr 20, 2014 at 1:40 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Don't worry about the diff drop it is completely useless. Just set the bilsteins to 1.75 with the eibach coils and for the rear just put an aal oon. That should be good for your lift needs.
  4. Apr 20, 2014 at 1:41 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    1.75 with Eibachs ?
  5. Apr 20, 2014 at 1:53 PM
    rlvmaiden
    Calgary
    Would you recommend slapping 5100's on the rear also? I know it won't raise it any, I've just heard it really improves the ride
    EDIT:
    Also, how much lift does an AAL add to the rear? From what I've been reading it looks like it'll add 1.5. Will the truck sit level(ish) with that setup?
  6. Apr 20, 2014 at 3:22 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Usually the least amount you can get from an AAL is 1.5".
    To get a better idea of where your truck will sit you need to figure out which rear leaf suspension you have. Whether it's the 2+1 or the 3+1. Either way with the front set at 1.75 and a 1.5" AAL the truck will still have a rake. More so with the 3+1 rear leaf.
    You could figure out the difference between the front and rear by measuring and go from there with your settings. You can also get a 1" rear block if you dony want more than an 1". If your not doing any major off roading it isn't going to hurt anything.
  7. Apr 20, 2014 at 3:42 PM
    rlvmaiden
    Calgary
    My offroading is pretty minimal so that's why I was considering just a 1" spacer for the rear. Like I said it's purely for aesthetics.
    I don't know what my leaf setup is, and I'm out of town so I can't just run outside and look. Whatever the stock 2014 TRD Sport comes with is what I have, unless they vary.
    If offroading isn't going to happen very often in this truck, can I get away with the 1" block on the rear and 1.75" Bilstein/Eibach on the front? I don't want the ride quality to diminish, but this is a pretty minor lift so I can't imagine it would.
    Thanks for the input guys.
    EDIT:
    Did some more digging, apparently Eibach's add lift in addition to the Bilstein. Maybe I should just go with the AAL then?
  8. Apr 20, 2014 at 7:02 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    I have a 1 inch block in the back and I might just be imagining things but it feels a bit rougher now than it did before. The ride isn't exactly silky smooth stock either though so whatever.
    Personally I think if you lift a truck 3 inches the smaller stock tires look kinda goofy. They just look really small. On second thought it probably wasn't the tire size because a more aggressive tire would look a lot better at the same size.
  9. Apr 20, 2014 at 7:47 PM
    rlvmaiden
    Calgary
    That's another thing that's been on my mind. I don't really want to go with a 3" lift because it definitely does look a little goofy with the small stock tires. Ideally I'd like to go 1" at most on the back and around 1.75" on the front, but AAL's only come in 1.5".
    Are spacers that bad on the rear? Because the 1" blocks sound like a pretty good solution for me. Or would getting new leaf springs with more lift be a better idea?
  10. Apr 20, 2014 at 7:55 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Lies. Diff drop is useless yes, but without new UCAs you won't get back into alignment specs and it will make your truck wander at higher speeds.
  11. Apr 20, 2014 at 8:05 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    The problems that I've heard are that the blocks can cause axle wrap and the ride quality is subjective, the ride quality doesn't bother me in slightest but for some people it's the end of the world.
    Honestly I don't think the half inch is going to make much of a difference because the stock rake is a 2 inch difference IIRC.
  12. Apr 20, 2014 at 8:05 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    Mine is in spec w/o a UCA and it drives straight as an arrow.
  13. Apr 20, 2014 at 8:33 PM
    moondeath
    Pa, Gardners
    This is true for larger blocks. 1" isn't going to do anything and will retain the factory ride.
    New complete leaf packs are a better quality option, but again a 1" block isn't going to hurt anything. A single AAL is going to be a stiffer ride.
  14. Apr 21, 2014 at 4:24 AM
    rlvmaiden
    Calgary
    I've been checking out the Wheeler's 5 leaf pack, and I think it might be my best bet. It's supposed to add 1.5", and I'm assuming it would stiffen the ride a bit, but one of the leafs is removable, reducing ride height a bit and softening the ride. Then all I need is 5100's all around, with the front set at either 1.75" or 2" and I should be set.
    My next question, do I need new coils for the 5100's? Not a big deal if I do, but it seems like most coils add lift. Which would be the best option to add minimal lift?
  15. Apr 21, 2014 at 8:28 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    too much preload, i would not set at 1.75
  16. Apr 21, 2014 at 8:40 AM
    OZ-T
    Peter North
    British Columbia
    Exactly my thoughts
  17. Apr 21, 2014 at 8:58 AM
    mcbagpiper
    mcbagpiper Well-Known Member
    Ottawa, Canada
    14 DC/LB TRD Sport
    Tonneaupro hard tri-fold 3D Maxpider floor mats 10g steel skid plate N-Fab steps AVS bug guard & window visors 5100's @ 1.75" 1" steel rear blocks 265/70/17 Nitto Terra Grapplers Graphite metallic sport rims 20% front tint MBRP dual cat-back exhaust
    Just lifted my 2014 DCLB a couple of weeks ago, 5100's up front set to 1.75 (stock sport coils) and 1" rear block. Tires are 265/70/17 (Nitto Terra Grapplers). As noted above I haven't felt any difference in the quality of ride from the 1" rear blocks.
    The lift is just enough to improve the look but still allows me to fit in my underground parking at work.
  18. Apr 21, 2014 at 12:46 PM
    rlvmaiden
    Calgary
    That's a pretty solid looking setup, I might end up going that route as I think replacing my rear leaf springs or even going AAL is overkill considering how little offroading I'll be doing.
    Did you have to add a diff drop/UCA/whatever in addition to the lift? I keep reading everywhere how mandatory it is to get a diff drop kit when lifting more than 1.5" and I'm seeing even in this thread that new UCA's are a good idea, but does it matter with a lift under 2"?
  19. Apr 21, 2014 at 1:20 PM
    moondeath
    Pa, Gardners
    You do not need UCAs at 1.75".
    You do not need a diff drop at 1.75".
    Even at 2".
  20. Apr 21, 2014 at 1:25 PM
    rlvmaiden
    Calgary
    Same goes for a 2" lift?
