Thinking about putting a Leer cap on my 4 banger..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Desert Dave, Feb 13, 2015.
  1. Feb 13, 2015 at 9:52 AM
    Desert Dave
    Desert Dave [OP] Member
    Apple Valley, Ca.
    Bilstein 5100's at .85 over stock, Relentless fabrication aluminum skid plate.
    Hi. I have a 2014 regular cab 4x4 stick with the 2.7 in it. I'm running 265/75/16's and bilstein 5100's set at .85 over stock right now. I've been wanting to put a cap on it for a while now, and now have the money. My questions are, #1, will the extra weight of the cap slow this little guy down much more than it already is? #2, how much lift, (if any) will I need in the rear to get it sitting about stock again, (Maybe a little taller, I can always set the Bilsteins to 1.75 in front). The truck is used mainly for camping trips/ exploring the desert out here, and does see some rough, rocky trails, and climbs. Thanks!
  2. Feb 13, 2015 at 9:59 AM
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
  3. Feb 13, 2015 at 10:07 AM
    Desert Dave
    Apple Valley, Ca.
  4. Feb 13, 2015 at 4:05 PM
    bdevr
    bdevr Well-Known Member
    Brian
    Blue State He**
    '10 4 popper
    Put a need cap on my 2010 access cab 4 banger 2 days ago. On a 4 hour drive home that was hills backroads and highway I didn't even notice that it was there.
  5. Feb 13, 2015 at 7:51 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    To answer your questions
    1) You might notice a little bit of the added weight, but not enough to regear your truck. Now if you wanna run a 285 or 33 AND a shell with the 2.7 4cyl...u might as well get out and push. It will be slower for sure if you don't regear. I know. I did it on my 2002 reg. cab. Running through the mountains/hills sucked.
    2) You prob won't notice THAT much of a "bro-lean", especially with the shorter wheel base of a reg cab. I have a Leer on my 2010 dcsb. I notice a very slight rear rake. Definitely not enough to worry about.
  6. Feb 14, 2015 at 1:11 PM
    Desert Dave
    Apple Valley, Ca.
    Thanks for all of the info!
