Thinking of going to 5 or 6 inches
Discussion in 'Suspension' started by Aww Boo, Jul 2, 2012.
  1. Jul 2, 2012 at 9:48 AM
    Aww Boo
    Aww Boo [OP] Well-Known Member
    Jayson Lee
    Petaluma,CA
    98 tacoma 4x4 manual, 2.7L, (300k club)
    Front and rear trail gear armor Trail gear rock ripper headers K&n air intake Headach rack Anzo headlight at 8k Ome rear leaf spring Bilstein 5100
    Hey TW 98 Tacoma with adjustable billies in the front and OME leafs in the back, was wondering Wut do I need to make it go higher and the parts ima need to replace to make it work. Tryin to make it inexpensive as possible but for it to be sturdy (I.e no body lifts).
    I tryed putting 285 wit 17in rim and rubs up against the A/upper control arm (not sure which one no one told me the difference). So I'm trying to put more tire on
  2. Jul 2, 2012 at 9:53 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Are you 2wd or 4wd?
    Why do you want more tire if the ones you have now are touching the control arms? Lift doesn't fix that, it makes it worse.
  3. Jul 2, 2012 at 11:33 AM
    Aww Boo
    Jayson Lee
    Petaluma,CA
    4wd, I'm have 265 on 17s right now
  4. Jul 2, 2012 at 9:54 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    3" BL or drop bracket. IMO I wouldnt choose either. Stick with 2.5-3" lift and call it good. Taller is not always better. 285's are doable on 6" lift but eventually you want to tuck 305's then you will lose MPG and need to regear. Drop bracket also will require cutting the cross member.
  5. Jul 3, 2012 at 12:02 AM
    Manwithoutaplan
    ID
    dont do db if you off road alot.
  6. Jul 3, 2012 at 12:12 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    after 3" you need a drop bracket lift, which IS NOT in expensive. You can fit 33s with a 3" and almost no cutting, and 35" tires with a 3" lift if you cut and hack your wheel wells and fenders to shit. Since body lifts are out, your only option is a 6" DB lift, which really is not necessary on these trucks for off roading.
  7. Jul 3, 2012 at 2:02 PM
    Aww Boo
    Jayson Lee
    Petaluma,CA
    Is there another option if I didn't want DB And what company's should I look for
  8. Jul 3, 2012 at 2:15 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If your touching the UCA's just install wheel spacers or buy new wheels with less back spacing.
  9. Jul 3, 2012 at 3:36 PM
    Aww Boo
    Jayson Lee
    Petaluma,CA
    The rim was off a 2005 Tacoma and I'm not getting spacer again I had them and they were paper weight for the longest time that was a bad choice when I tryed putting chevy weld rims on that everybody thinks that it works
  10. Jul 3, 2012 at 9:48 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Seems like you Offroad plenty. Why would you say that? Have you had a bad experience?
  11. Jul 3, 2012 at 10:06 PM
    Manwithoutaplan
    ID
    Yea i due do alot off roading the travel on db is only 6 inches of travel compared to mid travel getting 10-12 inches in the front. Plus if you are 4x4 you hVe to cut the cross member for the drive shaft. As far bad experience s none so far. But their no preformance advantage cause you dont get alot travel in the front. But if you do decide get the db lift get basic and get like icons or kings. The pro comps are trash plus you have to send to procomp in sd which sux.
  12. Jul 3, 2012 at 11:28 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Dear op.
    That's what she said
    :D
