Thinkware F770 Dashcam Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gpb, Dec 20, 2016.
  1. Jan 27, 2017 at 12:24 PM
    #41
    gpb
    gpb [OP] Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I don't use the safety features as there's no way for them to know when I intend to change lanes etc.
    I also use a PNY 32GB card and swap it out with the included card. I may buy something bigger but haven't had a need yet.
    *knock wood* I've not had to use parking mode for anything. I use the time-lapse and it's pretty cool. I like that the unit senses shock and will put the current recording in a separate folder, but kind of wish it'd figure out that the sensed shock of my opening the door and getting in isn't worthy of an announcement of an incident during parking mode. Once I figured that was what was quit looking for something happening in the videos when the unit told me there'd been 1 incident during parking. :)
  2. Jan 27, 2017 at 12:27 PM
    #42
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    I have the thinkware F770 (Dual) installed with the Cellink Battery B and really like the setup. Got a two meter cable with aright mini and another short cable
    with a left mini so the install is almost transparent. When I first got the cameras, my 128GB micro SDXC card arrived cracked and unusable, but BBMC quickly replaced it without question. I now have four 64GB and a 128GB card that I am
    swapping around to keep some history. Spend another $214 and get the Cellink
    Battery if you intend to use the parking mode. I have mine set on parking
    impact mode rather than motion, because I park facing a busy street and it
    would drain my batteries in no time. The video clarity is unbelievable from both
    cameras. Personally, I do not use any of the"safety features" because of the
    feedback from other owners (annoying alarms when turning, etc.) I also have
    the audio muted.
    Bottom line - Fantastic mod that helps relieve vandalism and hit-and-run
    worries. I'd buy it again. Thinking of putting a system in my wife's Avalon.
  3. Jan 27, 2017 at 12:33 PM
    #43
    gpb
    Atlanta
    No issues here without the cellink battery.
    I've not validated that the F770's low-voltage cutoff doesn't engage at home but no issues through the work day at my office's parking deck.
    I don't do motion detection as it'd be silly in a parking deck, I stick to impact sensing.
  4. Jan 27, 2017 at 12:49 PM
    #44
    wudbuchr
    Linnie
    Lexington, TN
    Listen to this guy, he was a great help when I was trying to decide on a dashcam system. I continue
    to go to him for his opinion on mods to my TACO!
    PJnc284 likes this.
  5. Jan 27, 2017 at 1:10 PM
    #45
    implicitprodigy
    implicitprodigy Well-Known Member
    Isn't the cell-link battery only if you do not plan on hardwiring the unit.
    Also as far as the notifications go, pretty much you know when to look st the parking mode video when it says there are more than 1 incident (you opening up the door)???
  6. Jan 27, 2017 at 1:11 PM
    #46
    implicitprodigy
    Also here is another question.
    Is it easy/simple to view videos for playback. Using the app I guess?
  7. Jan 27, 2017 at 1:16 PM
    #47
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    the one thing to know, if you use the alerts for parking mode (tells you how many motion or impact detections it had while parked) you will often get alerts for shutting your car door, so i typically will have 1-2 impacts detected each time, more if i go into my back seat or topper before getting in.
  8. Jan 27, 2017 at 1:18 PM
    #48
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  9. Jan 27, 2017 at 1:18 PM
    #49
    gpb
    Atlanta
    @implicitprodigy While @wudbuchr is kind, I'm still figuring this stuff out as I go... :)
    Yes, pretty much if it says more than one parking incident that's a signal to check it out. The exception would be if you turned off the truck and screwed around for more than whatever the delay is before it switches into parking mode. Might be a minute? Probably in the user manual.
    Videos are easy to check since the F770 sorts them in different folders based on what they're for (continuous, parking motion, etc) and labels each file with the date & time plus a F or R for which camera. You can turn on wifi and view them on your phone as well as download them to your phone, though that part is pretty slow. Or pop out the microSD card and put it into your computer. That's why you'll find folks keeping a 2nd card in the truck, something to swap out with while they take the other card in to look at.
  10. Jan 27, 2017 at 5:35 PM
    #50
    wudbuchr
    Linnie
    Lexington, TN
    If you do not intend to hardwire the dashcam, you either have to use the vehicle's cigarette lighter
    or use an inverter to convert your 110V household power to 12.5 volts DC to recharge the cellink
    battery. Otherwise, cut the cigarette lighter off the harness supplied with the Cellink battery's
    output harness and wire it to the Thinkware harness (connecting yellow to yellow red to red and
    black to black). I replaced the 20A fuse with a 7.5A fuse since the Cellink Battery only draws 7A
    when charging. 20A is a bit much.
  11. Jan 28, 2017 at 8:31 AM
    #51
    gpb
    Atlanta
    @implicitprodigy Since you were asking about ease of getting at videos. After the following event this morning I sat in my parked truck for a few minutes and: copied the video from the F770 to my iphone over wifi, exported from the Dashcam app to the phone's camera roll, imported the video into iMovie, trimmed the excess from the beginning and end, removed the audio track, and exported/uploaded to Vimeo. All from my phone. Sitting in my (parked) truck.
    Red truck goes wide in the turn, jumps the corner island, and finally corrects before nearly hitting the two construction workers.
  12. Jan 28, 2017 at 10:09 AM
    #52
    implicitprodigy
    Wow! That's pretty incredible. Glad it wasn't a toyota! I love the user friendly ease with this thing. It seems like its worth every penny. Thanks for uploading this video!
    gpb[OP] likes this.
  13. Jan 31, 2017 at 2:25 PM
    #53
    implicitprodigy
    Hey guys,
    Unit just came in, and I just got it hardwired and set up. This thing is LEGIT! Anyways, I was wondering what you guys set the voltage to on the system settings for it to kill the unit at a certain voltage? Did any of y'all change the default setting for this?
    Also, right now I have it set to time lapse, but black has recommended motion detection. I just ordered a 128gb so I can make that happen because as of right now my 32gb can only handle 2 hrs. It may be fine, but I'd rather have more than enough space.
    Can't say enough about the quality on the back camera, I have used dash cams for a while now and so far I feel like this is how they were supposed to function. I will say I liked the look/design of the blackvue dashcam more, but I'm happy I didn't go with it.
  14. Feb 1, 2017 at 6:35 AM
    #54
    gpb
    Atlanta
    @implicitprodigy I chose TimeLapse instead of MotionDetection because my truck is regularly in a parking deck with people and cars going by all the time. At home it's parked out doors and the rear camera has a view of the driveway and street. If something should happen while parked, such as a break in, I'd also like the opportunity to document anyone casing my truck beforehand. Still, maybe I'll try the motion detection version and see what I get.
    As for threshhold shutoff voltage, I've had good success with setting it to 12.0VDC -- seems to keep it running overnight and through the work day with no issues with starting the truck afterward. The default 12.2VDC seemed to cut off after a few hours parked. Particularly with the TimeLapse mode, the voltage stamp in the videos can give you a sense of what you need to set it to in order to cover the timeframe you want to cover.
    Yes. the F770 and BlackVue 650 are the top of the game right now. I chose the F770 for its form factor (look/design) and neatness of the main unit cables as much as for its capabilities. One advantage for those who want to start with a front camera and add a 2nd cam later is the F770 supports that model whereas with the Blackvue you buy either the 1 or 2 channel system and can't add a rear camera to a 1 channel version.
  15. Feb 16, 2017 at 7:47 AM
    #55
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Hey all,
    I'm considering getting this bundle and have a concern about power usage when the vehicle is off. I would plan to hard wire the unit, but would getting the Cellink Battery B pack and hooking into the hard wire setup be wise to prevent car battery drain if you leave the vehicle off for a few days?
    Think if you take a flight somewhere for a week. You wouldn't want to come home to a dead car battery thanks to your dashcam.
    If it's even recommended to do such a thing, how would one go about wiring that backup battery into the mix? Only other option would be to add a switch to kill power to the dashcam for such long trips.
    Cheers, :cheers:
    -Sam
  16. Feb 16, 2017 at 7:51 AM
    #56
    gpb
    Atlanta
    sigrooms likes this.
  17. Feb 17, 2017 at 12:26 PM
    #57
    wudbuchr
    Linnie
    Lexington, TN
    BBMC advises to hardwire the cellink Battery to an accessory fuse so it will have no effect on your Taco's
    battery when the vehicle is left for a few days. I am running the Thinkware F770 (dual) connected to the
    Cellink Battery B and am having no problems. Mine is using the add-a-fuse connected to the DC Power #2
    fuse (cigarette lighter in the center console). It works like a champ, and is transparent in daily use. Actually,
    I am considering adding the extension battery to my configuration for additional monitor time.
  18. Feb 20, 2017 at 11:35 AM
    #58
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    Do any of you F770 owners live in a hot summer environment? If so, do you take your cam down off the mount when you park, during the summer? If you have the rear cam too, do you take that down as well? I live in Phoenix and my sub-$100 dash cams seem to last about 2 years before becoming unreliable (crashing, turning off, freezing, etc.). I'm concerned about dropping $400 on a cam system that would die in the same time frame. It appears that you can disconnect the forward facing camera with no issues, but I've read the rear cam doesn't have a base to release from. I generally leave my cams running 24/7 until the warmer months roll around. Then I will take them down when I park and place them in a cup holder or center console. As much as I want a rear facing cam, it would be a real PITA to have to detach it every time I park (during the summer months).
    Any ideas or comments on how to deal with the heat? I also sent an email to support@thinkware.com in hopes they have some guidelines on how to prolong the unit life in extreme heat environments.
  19. Feb 20, 2017 at 11:58 AM
    #59
    gpb
    Atlanta
    Haven't had mine long enough and during the day I'm either parked in a deck or under a tree canopy.
    I do know that some of the lower end units tend to have batteries instead of capacitors; higher end units moved to capacitors specifically for the heat death reason.
  20. Feb 20, 2017 at 1:25 PM
    #60
    OneFastGeek
    2010 TRD Sport 4x4
    Well, their support guys got back to me a few hours later (which is a good sign).
    Hi OneFastGeek,
    Thank you for contacting Thinkware Dash Cam.
    The operating temperature of our cameras are 14°F to 140°F/ -4°F to 158°F.
    They will automatically shut off if they become too hot to avoid damage.
    We recommend not leaving the camera in the vehicle during extreme temperatures.
    Our cameras easily detach from the mount.
    The rear camera is not removable but will be fine left in the vehicle.
    Please feel free to contact us again if you encounter any other issues.
    Kind regards,
    Customer Support
    THINKWARE Dash Cam™ (North America)
