This is probably something I should know but am not sure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason chairs, Apr 11, 2011.
  1. Apr 11, 2011 at 3:37 PM
    Jason chairs
    Jason chairs [OP] Active Member
    jason
    Coatesville,pa
    none yet want many
    The maintenance required light flashes about 4 times when I start my truck should I be concerned or is it to be ignored. I just changed the oil about a 1000 miles ago so it cant be that again. My truck just hit 100000 by the way it is a 07 access cab v6 4wd
    thanks
    jason
  2. Apr 11, 2011 at 3:40 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Did the people reset the light when they changed the oil?
  3. Apr 11, 2011 at 3:42 PM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    You need to reset the light. Hold down the trip meter button while you turn the key on and keep holding it down untill all the dashed lines on the odometer go away.
  4. Apr 11, 2011 at 3:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. You will see a few lines and it counts down from there.
  5. Apr 11, 2011 at 3:46 PM
    Jason chairs
    jason
    Coatesville,pa
    none yet want many
    thank you I am gonna try holding down the trip meter tahnk you for your help
  6. Apr 11, 2011 at 3:56 PM
    Jason chairs
    jason
    Coatesville,pa
    none yet want many
    I tried holding the trip reset button down and started it and it did not work maybe I will just change the oil again this upcoming weekend I dont know why its doing this.
  7. Apr 11, 2011 at 3:57 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Do not start the truck. Just turn the key to "On" and leave it there until the Maintenance Light resets. When you pass the "On" position on the key lock it stops trying to reset the light.
  8. Apr 11, 2011 at 3:58 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Dont start the engine itself, just flip the key over to auxilary mode I believe it was. Try that first.
