This should be good....
Discussion in '4 Cylinder' started by NOTNA, Jan 25, 2013.
  1. Jan 25, 2013 at 1:26 PM
    NOTNA
    NOTNA [OP] Member
    Andrew
    New Jersey
    2012 Tacoma Access Cab 2.7L
    How far have you gone in your 4 cyl once the gas "Empty" light has turned on??? [​IMG]
    :oldglory:
  2. Jan 25, 2013 at 1:30 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  3. Jan 25, 2013 at 3:18 PM
    choyt
    choyt Well-Known Member
    wayne
    new york
    2015 tacoma
    Nope and never will. (sorry)
  4. Jan 26, 2013 at 9:20 AM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    hard on the fuel pump, since the gas keeps it cool. i fill up when it hits 1/4 tank
  5. Jan 27, 2013 at 6:33 AM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I believe that warning light comes on when you have around 2.5 gallons left. Given driving styles, terrain, weather, vehicle configuration, type of fuel blend, it could mean you have to find gas in the next 50 miles. As noted, running it to the bottom isn't generally recommended. But it's good to know what you have left given your own situation so you can make a better decision. Given my configuration, winter blend, colder temperatures, I would be able to manage about 50 miles. In the summer with regular gas, maybe 60 miles. However, I only use that to make buying decisions relative to where I'm at when the light comes on. If I know my regular service station is cheaper and within 20 miles, I might wait. If price is comparable, I'll buy and be happy.
  6. Jan 27, 2013 at 8:29 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    I've never seen the light come on. I fill up between 3/4 & 1/2 tank.
  7. Jan 28, 2013 at 6:56 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    My light comes on with about 4 gallons left so I can normally make it at least 70 miles
  8. Jan 28, 2013 at 7:08 AM
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    On my v6 Taco, I've noticed my fuel light to be pretty conservative. I can usually get another 50-75 miles after my light turns on which is equivalent to 4-5 gallons of gas. I understand it's best to not drain the tank though as you're likely to clog up the fuel system with particulate settled at the bottom of the tank. Good luck
  9. Jan 28, 2013 at 7:23 AM
    Rackster
    Kevin
    Connecticut
    After seeing the 4/5 gallon reserves, I got to thinking that I should have noted my tank size in case it matters - 18.5 gallons with the 2.5 gallons left in the tank when the light comes on. Conservative estimate of 50-60 mile travel distance (2.7L 4x4).
  10. Jan 28, 2013 at 10:48 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    It comes on with 4 gallons left in the tank, says so in my owners manual anyhow.
  11. Jan 29, 2013 at 5:40 AM
    Rackster
    Kevin
    Connecticut
    Thanks. I'll have a look at mine next time in the glovebox. My fuel gage and light are very routine: about 105 miles per 1/4 tank (spring/summer) and light comes on after 16 gallons consumed.
  12. Feb 15, 2013 at 3:05 PM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Ive driven 70 miles before with my light on, its always more of an adventure..
  13. Feb 15, 2013 at 6:09 PM
    Rackster
    Kevin
    Connecticut
    I'll bet!! Could have you sweating on a winter's day!!!:)
  14. Feb 18, 2013 at 10:45 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Kramer reaches 100 when he test drives tacomas
  15. Feb 19, 2013 at 1:35 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    About 90 miles the time I broke my old record for most miles/tank.
    But I don't often see the light, I usualy fill it up before it comes on.
    My record on my 4Banger 4x4 with a 3" lift, stock tires & shell.
  16. Feb 19, 2013 at 4:21 PM
    Rackster
    Kevin
    Connecticut
    Good numbers for a stock 4x4 for that matter! Glad you made it to the gas station Randy!
    But is a 500 mile tank in your future???
  17. Feb 19, 2013 at 4:23 PM
    RedTacoDriver
    RedTacoDriver Out of my mind....be back later.
    Dale
    Portland, OR
    2012 Tacoma Regular Cab 2.7L
    BakFlipG2, Westin Nerf Bars, Harbor Freight Bed Jacks, Flame Devil Horns, vinyl raven emblems, intermittent wiper switch swapout More to come.
    There is a low fuel light? Amazing!!!!!
  18. Feb 19, 2013 at 8:54 PM
    2004TacomaSR5
    Jon
    Montana
    That's cutting it close, you were probably literally running on fumes haha
  19. Feb 20, 2013 at 12:23 AM
    4Wheelin4Banger
    Randy
    That was doing 75MPH most of the time on 7 70ish mile round trips to work. Going from 4400' (old house) to over 4500' and down to 4100' (work) and back with a lot of ups & downs in the middle.
    Maybe after I do the sail mod or I find a 500 mile flat stretch of freeway.
    I always have 4 gal in a 5 gal can in back.
  20. Apr 6, 2013 at 4:23 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    I could care less on driving the most miles from one tank. I will not subject my fuel pump to those conditions. Electric fuel pumps are not cheap or easy to replace. 1/4 tank is as low as I go.
