Thoughts on 37s
Discussion in 'Wheels & Tires' started by SGTCap, May 8, 2014.
  1. Dec 10, 2014 at 7:47 AM
    #61
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    Thanks for the links, you have me some hope on still running my elocker... a front ARB would be probably nice in those sticky situations :) looks like you need to use a spacer on the rear
  2. Dec 10, 2014 at 9:37 AM
    #62
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Spacer?
    Also where are you from? Sind sie Deutscher? It's hard to pick up accents from typing.
  3. Dec 10, 2014 at 10:17 AM
    #63
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    That's cool! I want to avoid a body lift though... What do you think of those fiberglass fenders? *cough cough* Username!
  4. Dec 10, 2014 at 10:22 AM
    #64
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Why the coughing? The glass fenders are tougher than they look, pretty easy to install, and really help fitting big tires. They do not line up perfectly, and I hear all of the glass companies are pita to deal with. I went through Kartek and it was easy.
  5. Dec 10, 2014 at 10:32 AM
    #65
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Stick with 35's, that extra inch of radius is the tough part to clear. Something else to think about...my tires actually measure 37" mounted on wheels. Most offroad tires don't measure out to what is on the sidewall.
  6. Dec 10, 2014 at 10:41 AM
    #66
    dakotasyota
    Dakota
    Ellensburg, WA
    Hmm glass interests me. Thanks for your awesome responses! So regardless of glass or not, the tops of the inner fenders will have to be cut and I will have to relocate/remount stuff under the hood, correct?
  7. Dec 10, 2014 at 10:41 AM
    #67
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    this is sick. :spy:
    I'll prob run 35/37's on my 82' toyota pickup so dont mind a lurker :spy:
  8. Dec 10, 2014 at 10:59 AM
    #68
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    No, Haws still has in tact inner fenders with 36's. That's only 1/2" smaller radius than my tires. The best advice I can give is to build it at full stuff and go from there. Might have to get 1/2" taller bumps in the front or something, but it'll work. You can do it. :D Another thing that really helps is pushing the LCA as far forward as the caster adjustment cams allow.
  9. Dec 10, 2014 at 11:30 AM
    #69
    dakotasyota
    Dakota
    Ellensburg, WA
    That's good, and a 37" mtr probably won't measure out to a full 37 inches like yours do. Ill try that, I heard the LT helps a lot too cuz it moves the hub forward.
    Eff it, I'm going for it! Ill try 4" out of the flares first unless you think I could get away with 3"... I doubt it. I know that spoonman rubs and he only has 3" out.
  10. Dec 10, 2014 at 1:27 PM
    #70
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    4". Do it man. I work in Ellensburg at the airport sometimes, was just up there last week. Are you going to school there or are you from there? I hear there is some awesome four wheeling up your way, maybe we can set up a run sometime.
  11. Dec 10, 2014 at 6:23 PM
    #71
    dakotasyota
    Dakota
    Ellensburg, WA
    I'm in. :D I'm not afraid to do some extensive work. I know I can make it work.
    I was thinking too, an easy way to tell rubbing will be to get everything out of the way while installing my ORIs. They'll be resting on bumps before I pump them up.
    No way?! Thats so cool. I'd love to meet you/see your truck. Nope I was born and raised here. Just graduated highschool and working at the family business. There is some great wheelin around here. We should set up a run with the other TW guys!
  12. Dec 10, 2014 at 6:30 PM
    #72
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    For sure, although the WSP doesn't like my truck too much, lol. I need to get a trailer for it. Never have an issue in Oregon though. Do you already have Ori's? I wouldn't advise going that route if you haven't pulled the trigger on them yet. It's not that you can't make them work, but coilovers are a lot easier to set up and tune.
  13. Dec 10, 2014 at 6:33 PM
    #73
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Yup just found my sig quote.
  14. Dec 10, 2014 at 8:52 PM
    #74
    clupi
    Sacramento Ca
    07 taco 4x4
    Ha ha.. you can pick up an accent???.. im from Sac ;)
    I was born In Romania and came here when I was about 7-8..
  15. Dec 10, 2014 at 9:08 PM
    #75
    dakotasyota
    Dakota
    Ellensburg, WA
    Really?? What don't they like? No mudflaps? Front license plate? I always thought Oregon was worse about that...
    No I dont... Ugh dammit I just finally thought I had it all figured out. Nate87 was telling me some great stuff about them on his build. Basically you set a lift height/spring rate in the upper chamber, and then you can adjust the valving (squishyness) in the lower chamber... Am I right? I'm just sick of such a stiff suspension with no downtravel.
  16. Dec 10, 2014 at 9:35 PM
    #76
    clupi
    Sacramento Ca
    07 taco 4x4
    Spacer or thick gear for thr stock e-locker to be geared under 4:10.. no?
  17. Dec 10, 2014 at 9:42 PM
    #77
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'm on 37s. I like to party.
  18. Dec 10, 2014 at 9:49 PM
    #78
    dakotasyota
    Dakota
    Ellensburg, WA
    I know Jamie. You've ruined my life.
  19. Dec 10, 2014 at 9:54 PM
    #79
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
  20. Dec 11, 2014 at 6:38 AM
    #80
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I guess so. I lived overseas for almost 8 years exposed to all kinds of accents, sometimes you can tell by the syntax where people are from even if they are speaking or typing in English. Romania has some bad ass offroading, it's like the Alaska of Europe.
