Thoughts on 37s
Discussion in 'Wheels & Tires' started by SGTCap, May 8, 2014.
  1. May 3, 2015 at 1:05 PM
    #1021
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    It always seems like never enough :goingcrazy:
  2. May 3, 2015 at 3:16 PM
    #1022
    SGTCap
    SGTCap [OP] Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    It never is. Gonna have to cut out A LOT. Something in the neighborhood of a square foot I think. Maybe not quite that much, but a lot.
    Fortunately I know a guy that can do that sort of thing. :)
  3. May 3, 2015 at 4:03 PM
    #1023
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Hopefully you'll get yours done before I start my re-tub. What are you running for your rear setup?
  4. May 3, 2015 at 4:48 PM
    #1024
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    As far as rear suspension?, just some 5150bilsteins and Allpro Expos. I want to relocate my shock mounts and run 14" Fox's next. Probably be smooth bodies. I don't know that my uses really make remote resivour shocks advantageous
  5. May 3, 2015 at 9:36 PM
    #1025
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    hows the steering and Ifs with 37s,
    I can definitely notice a difference in response with 35s
  6. May 4, 2015 at 7:29 AM
    #1026
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Not bad. At a stop on dry pavement it's a little stiff, after that it's fine. I'm sure off road it will be a little stiff but nothing I would complain about
  7. May 4, 2015 at 3:13 PM
    #1027
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Turned out badass man. What do you think of those tires? I think they are the identical compound to KM2's myself, pretty grippy for something that lasts so long.
  8. May 4, 2015 at 4:57 PM
    #1028
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Thank you I'm loving it so far.
    The BEGs ride much better than I expected. It's more like a super aggressive AT than a MT like I was expecting. I put the Equal bags in the tires to help balance them but as I understand it they take a while to bust open so I have some wobble in the steering but I think it will go away. If not, it's not that bad.
    I'm really impressed by how well it rides and the overall drivability of it. The 4.56s give me plenty of power without feeling overgeared. I can still skip shift 1-2-4-6 like I always have.
    The little bit of flexing I got to do impressed my too. The tires grab well and hang on. I really couldn't ask for more at the price point I paid.
    There's still some cutting, welding and beating to do but I couldn't be more pleased overall. I think getting my black flares back on will really make it look complete.
    I haven't decided if beadlocks are in my future budget but I really would like some as not to worry about losing a bead. I also think black wheels with tan rock rings would look sick on the truck. For now I think I'm going to rig up the Cheetahs as an OBA tank so that if I do lose a bead I have an easy way to reseat it. I already have a masterflow compressor, spare battery and the tank, so why not?
  9. May 4, 2015 at 5:14 PM
    #1029
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Eh, you have a spare. Drop them down to 15psi and go for a cruise around the block. I think you will be surprised how well the bead holds. It might get sketchy at single digit PSI, but 15 is as low as I ever need to go with the BFG's. You get side lug engagement and a nice footprint with enough air left to keep the rims out of the rocks. The sidewalls are not as stiff as the goodyears. Those things were so stiff I could drive down the highway with the valve stems out.
    Long story short beadlocks are over rated unless you really need single digit PSI and have axles strong enough to survive that much traction.
    SGTCap[OP] and HomerTaco like this.
  10. May 4, 2015 at 5:32 PM
    #1030
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    I have dropped my Red letter's down to single digits without loosing a bead.... but.. I'm on a narrowish rim
  11. May 4, 2015 at 7:00 PM
    #1031
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I'm not gonna lie, I fear for my rear diffs safety. Mostly cause I don't trust the Damn elocker. It's slow to engage and even when it says it's locked in I don't trust that it's 100% engaged. I may look for someone that wants to swap rears for a non elocker and some cash and throw an ARB back there.
  12. May 4, 2015 at 7:19 PM
    #1032
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Glad I didn't blow a grand on beadlocks then. I rather put that money toward a crawl box or diamond axle
  13. May 4, 2015 at 7:40 PM
    #1033
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Ya. I got them because they withstand more abuse at speed, but with the weld on rock rings you can get now a days you can get a set of steelies pretty bomb proof. That said, the TWF beadlocks have survived massive amounts of abuse that I know that normal aluminum wheels grenade under.
  14. May 4, 2015 at 8:50 PM
    #1034
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    You're worried about the e-locker? I thought when you blew your factory gears the locker was fine? I always thought for some reason just the teeth on the ring go and the locker survives...
  15. May 5, 2015 at 3:32 AM
    #1035
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    The locker itself is fine. I think it may contribute to people blown reagents though. Just a theory
  16. May 9, 2015 at 9:01 AM
    #1036
    BoatRacer
    BoatRacer Well-Known Member
    Olalla WA
    '02 TRD 3.4 5-Speed
    All Pro front bumper, Warn winch, leds, Dakar leaf pack, locker wire mod.
    From my experience with 37's and the factory rear, I would suggest having a track bar or "axle anti wrap" bar fabbed. I bought the kit from Rough Stuff and hope to have it welded in this weekend. I'm no suspension expert, but when we use lift springs for these light weight trucks, it allows the rear end to twist easier. The leaf spring bends slightly from the force of acceleration and the pinion is forced upward. When the trans shifts and momentarily unloads the force, the leaf springs unload and shock the pinion angle back and it starts all over again. In my case it was much worse with the manual trans and lag between shifting, when I pushed in the clutch I could feel and hear the rear end bang down. I broke two ring gears on 4.88's in approx. 18K miles with the factory rear, this last time blew apart the side carrier bearing, I found the bearing cage laying in the housing. The e-locker portion was fine and mine has always worked well after the anytime mod was done. I got pissed off and spent big $$ on a Currie 9+ rear end before really looking into what was happening, I think the stock rear can handle the abuse of daily driving and moderate speeds of wheeling if you set it up properly.
    If you fear the e-locker actuator, you could carry a second one or change to a manual operated setup. One positive thing about them, if its not locking you can remove the actuator and move the side gear with a screw driver or pocket knife. If your thinking about changing and feel comfortable driving your truck in all conditions, it's hard to beat a Detroit locker. They don't fail.
  17. May 9, 2015 at 9:31 AM
    #1037
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    The last time I lost a factory rear end it was during a full throttle 2-3 shift (manual trans). At the 1-2 shift, I hit the locker button but it still wasn't fully engaged, causing the side gear to break and taking out the axle (stripped splines) when the third locked up. In ten years and 100K miles, that was the first time that happened and it was entirely my fault for not being patient, lifting off the throttle, and allowing the E-locker to fully engage. I also got frustrated and built a bomb proof Diamond rear end with a detroit locker, but in all honesty it's overkill. The nice thing about running Spring Under Axle (SUA) is that it resists axle wrap so well that anti-wrap bars aren't needed. SUA also gives you more anti-squat, so the rear end really bites in when you get into the throttle. It's really nice on hill climbs. We have one here called the "widowmaker" that was supposedly unclimbable for over twenty years, and only a handful of trucks have ever made it over the top. I took one of the guys who has climbed it in a locked bronco over the top and he said "that's the fastest I've ever been up that hill!" and I laughed and said "we should try it in 4wd". He was dumbfounded we made it in 2wd.
  18. May 9, 2015 at 9:38 AM
    #1038
    BoatRacer
    Olalla WA
    '02 TRD 3.4 5-Speed
    Agreed! There are a few things I would have done different from the start of this swap, SUA is the biggest one. I may buy new rear springs and make that change at some point, but the next big $$ drop for me will be SAS.
  19. May 9, 2015 at 11:35 AM
    #1039
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Mine failed.... bolts backed out of the locker and got caught in the ring gear. It was quite interesting
  20. May 9, 2015 at 1:40 PM
    #1040
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    They don't fail
