Thoughts on 37s
Discussion in 'Wheels & Tires' started by SGTCap, May 8, 2014.
  1. Jun 17, 2015 at 6:18 PM
    #1301
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    They are nice, no mucking with driveshaft angles, carrier bearing shims, fixing vibes that only show up on a full moon while doing 45.3 mph. Slap that one piece in and be done with it, best thing is that they are cheap and plentiful. Save your money from a tom woods shaft, toyota makes the strongest driveline you can find for the price. Only downside is that the bolt pattern is different so you have to get a double drilled pinion flange or just mark and drill the holes yourself.
  2. Jun 17, 2015 at 6:19 PM
    #1302
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    Sounds easy enough.
  3. Jun 17, 2015 at 6:24 PM
    #1303
    PSU Taco85
    optional
    I never bent a tie rod with 33s but with 36 and 37s seem like it is more common. What I do is set up a new inner/outer tie rod with the same thread count as what's currently on my truck that way when it breaks you swap the whole assembly out and don't need to worry about the alignment. MOOG tie rods are pretty good quality and cheap on rockauto. I haven't bent a rack yet but I'm hoping with cheap chinese tie rods they stay the fuse haha
  4. Jun 17, 2015 at 6:26 PM
    #1304
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I hated swapping out the rack, nice thing about tie rods is you don't necessarily have to take the tire off
  5. Jun 17, 2015 at 6:47 PM
    #1305
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Just spent almost $400 on my rear driveshaft. All new u joints, carrier bearing, re-tubed and shortened for the krawl bawks
  6. Jun 17, 2015 at 6:49 PM
    #1306
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    If I talk about my lil ole 315s. I wonder how pissed Cap will get :)
    PSU Taco85 likes this.
  7. Jun 17, 2015 at 7:01 PM
    #1307
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    This turned into a fantastic night!! Haha good times.
    And keep in mind Cap and others that a lot of breaking has to do with driving style and just bad luck, not big tires and low gears. Obviously they help but as some here can testify to, people have broken ring gears on stock tires and people have survived quite awhile on 4.88s and big tires
  8. Jun 17, 2015 at 7:01 PM
    #1308
    SGTCap
    SGTCap [OP] Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I just found out you can't get the yokes at most parts stores, so if you think you'll ever need one go ahead and order a couple online. About $45/each
  9. Jun 17, 2015 at 7:17 PM
    #1309
    PSU Taco85
    optional
    Ouch, you're better off just buying a used junkyard shaft and installing a new u joint. Can't believe the yoke costs that much, think it's a spicer only part, and yota doesn't sell subcomponents only the whole drive shaft lol
  10. Jun 17, 2015 at 7:31 PM
    #1310
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Spicer discontinued it. Now the only source is
    powertrain industries 3302-185
  11. Jun 17, 2015 at 8:17 PM
    #1311
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Is anyone making replacement gearsets for the FJ tranfer case? If I could get a tcase with 4.7s in it I would be all over it
  12. Jun 17, 2015 at 8:19 PM
    #1312
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Now THAT is a useful tip. I'll start calling junkyards next week
  13. Jun 17, 2015 at 8:20 PM
    #1313
    BradyT88
    BradyT88 Well-Known Member
    Trailgear recently started making gear driven cases for Tacomas. I haven't heard much about them though, not that I have looked.
  14. Jun 17, 2015 at 8:29 PM
    #1314
    PSU Taco85
    optional
    Bummer, thanks for the part number though that will come in handy in the future I'm sure.
    Being a chain driven case with a planetary reduction gear, there is no option for different gear ratios unfortunately. You would have to reengineer the whole housing to fit a different gearset in there.
    Just keep your eyes open, the deals will pop up, don't act to anxious or they might overcharge you lol. U less they have all new ujoints I wouldn't pay more than 75 for one.
    The trail gear reduction box is a shitty version of Marlin or inchworm boxes, I wouldn't recommend my worst enemy run one of those. You haven't headr much because people have wisened up and nobody probably bought one lol
  15. Jun 17, 2015 at 8:54 PM
    #1315
    BradyT88
    Yeah... I'm not a big fan of trail gear... the products or the company...
  16. Jun 18, 2015 at 1:39 AM
    #1316
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    What you saying? Haha
  17. Jun 18, 2015 at 4:30 AM
    #1317
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    That I enjoy your company. Haha I'm just glad I'm not the one who breaks shit all the time.
    Keep in mind that a one piece driveshaft is gonna be more susceptible to damage and will be more likely depending on the wheeling you do. I'd recommend at least running a track bar with one
  18. Jun 18, 2015 at 4:36 AM
    #1318
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Didn't think about a track bar... nice thing is like psu said one pieces are cheaper so I can have a spare
  19. Jun 18, 2015 at 7:57 AM
    #1319
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Track bar would serve as a driveshaft skid of sorts...
    Taco Nation likes this.
  20. Jun 18, 2015 at 9:43 AM
    #1320
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Didn't think of that... :drevil:
