Thoughts on 37s
Discussion in 'Wheels & Tires' started by SGTCap, May 8, 2014.
  1. Sep 23, 2015 at 8:02 PM
    #1461
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Mine weighs 4080 lbs wet, on a certified CAT scale, and I don't have stock axles. The difference between 37's and 40's is 1.5" more ground clearance, they are not much bigger. Also my current wheel and tire combo weighs north of 150 pounds, per corner. If you went with light aluminum wheels and a lighter AT style 40", they would be considerably lighter and easier on hardware than my double beadlock 12 bolt steelies. Just sayin'.
    When these tires wear out I'm doing it just because you guys say I can't. Have me lookin' like this dude pretty soon.
  2. Sep 23, 2015 at 8:08 PM
    #1462
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Super Swamper IROKs weigh 85 pounds a peice. Pro comp steelies are 39 pounds. So that's ball park 125. So with a lighter wheel you wouldn't be much heavier than my 285's and steelies.
  3. Sep 23, 2015 at 8:32 PM
    #1463
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I'd feel sorry for putting the engine up to turning those heavy beasts, be cool but probably slow as hell. I have 37's on my diesel, but I don't even know they are there with that 525lb/ft of torque. 35" is as high as I'd go on my little Tacoma, any bigger and I'd be looking at a V8 swap and SAS as well lol.
  4. Sep 24, 2015 at 4:08 AM
    #1464
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Keep telling yourself that :luvya: 37s vs 39s. Both aired up, just one is mounted on the truck
    username[QUOTED] likes this.
  5. Sep 24, 2015 at 4:23 AM
    #1465
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I didn't say you can't. I didn't say anybody can't. You also just stated a few things that tells me its a much better idea on your truck then on the one I described in my post, which is a lot of folks on here. To try and compare your truck to anyone else's is kinda ridiculous. For example, I have an AC with a 4 banger, 35s, aluminum alloy wheels, all my interior and no cage work and my truck weighs 4686# last time I went to the scrap yard
  6. Sep 24, 2015 at 6:17 AM
    #1466
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Im in the process of doing it!! 39.5's in the garage now. Crawl box was ordered last November... Should be here soon :annoyed: I will probably break stuff, but then Ill build it stronger!! Im thinking Ill swap a ton axle in the rear first, then collect the parts for the SAS from RST.
    tacoma16, Taco Nation and username like this.
  7. Sep 24, 2015 at 6:48 AM
    #1467
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
  8. Sep 24, 2015 at 7:26 PM
    #1468
    SGTCap
    SGTCap [OP] Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    You gonna try it without the SAS first?
    I had no idea led time was that bad on a crawl box
  9. Sep 24, 2015 at 7:27 PM
    #1469
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I'm going to look for someone local with 40's on 6 lug wheels so I can take a picture and be a poser.
  10. Sep 24, 2015 at 7:41 PM
    #1470
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Got mine from inchworm in like three weeks...
    PSU Taco85 likes this.
  11. Sep 25, 2015 at 6:07 AM
    #1471
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    And it spent almost 2 years in the garage :p
    Large, NYCO, Neutral and 2 others like this.
  12. Sep 25, 2015 at 12:11 PM
    #1472
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Its been a wait yes, but its been revamped for the 4.0's and the prototype was in Wyatt's Beast for testing. Word is its going full production now. Im really hoping its all worth it.
    Yes Ill run 39.5's without SAS first. Ill post all the pics when they are rolling, as well as flexed
  13. Sep 25, 2015 at 12:35 PM
    #1473
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Let me know if you need a hand with the install! We're going elk hunting this weekend but should be around next week.
  14. Sep 25, 2015 at 5:15 PM
    #1474
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    phillstill and la0d0g like this.
  15. Sep 26, 2015 at 6:57 AM
    #1475
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I gotta see this shit
    Supra TT likes this.
  16. Oct 2, 2015 at 12:23 AM
    #1476
    bzzr2
    bzzr2 Well-Known Member
    2 inches up-travel & 11 or so inches down-travel = kickass if things hold up to those monster tires!!
  17. Nov 23, 2015 at 5:03 PM
    #1477
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Project fender clearance has commenced... 39.5's on the floor
    Crawl box suppose to be here in December (-:
    PSU Taco85, BoatRacer and Neutral like this.
  18. Nov 23, 2015 at 5:05 PM
    #1478
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Pics pics pics pics pics
    HHIRunner likes this.
  19. Nov 23, 2015 at 7:15 PM
    #1479
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
  20. Nov 23, 2015 at 7:16 PM
    #1480
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
