Thoughts on rear bumper design?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Apr 20, 2013.
  1. Apr 29, 2013 at 11:05 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  2. Apr 29, 2013 at 3:16 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I actually REALLY like what Btnewman did above with the square tube.
    Sure looks like it.
  3. Apr 29, 2013 at 4:37 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Just a few thoughts, the plates that you have drawn in that go along the frame rails, they will probably have to be cut and notched around the shock mounts.
    And you might think about using a little bit heavier material as backing for the reciever tube, if you are pulling a trailer or have any kind of load on the hitch, You might get a lot of flex on that reciever.
    And yeah, those bumpers were all mig welded.
  4. Apr 29, 2013 at 4:40 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Yep i was expecting to have to redo the mounts i knew that.
    what if i braced the receiver tube like you did? think that would be sufficient.
  5. Apr 29, 2013 at 4:58 PM
    Btnewman
    Benjamin
    Grand Junction co
    Bracing them with some tube would be way stronger! Over all. I really like your design!
  6. May 1, 2013 at 10:04 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    okay how about now? better??
  7. May 1, 2013 at 11:45 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Very nice, that should be pretty strong. I would still move the recovery points but it should be fine like that.
  8. May 1, 2013 at 2:32 PM
    Btnewman
    Benjamin
    Grand Junction co
    That looks way better! How thick of metal are you going with? And on the recovery points, the closer to the framerail, the better, but if you are going with a thicker plate for the bumper, you will be ok if you either have it close to some egdes, or brace the back side of the mounts inside the bumper.
    And make sure you find a way to weld the outside edges, as well as some weld inside. Either cutting a small slot directly under the tab and weld through to the tab. Or have a tab that goes all the way through a cutout in the bumper.
  9. May 1, 2013 at 10:16 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    have not really decided on a thickness 3/16th seems to be a common size from my research.
  10. May 1, 2013 at 10:16 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    that should be plenty.
