thoughts on this '04?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacod, Oct 9, 2010.
  1. Oct 9, 2010 at 12:47 PM
    tacod
    tacod [OP] Well-Known Member
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    drove this '04 today...
    http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=280401782
    it's a fully-optioned truck in the last year of the 1st gen. it drives nice, has new tires (though spare is well worn), inspection 'til august. everything seems to work. no odd noises. pretty clean for an 80k-mile truck, but still an 80k-mile truck (in other words, not SUPER clean, but clean). straight, original body panels, original paint.
    points of concern: unknown service history, though carfax suggests at least some upkeep (oil was clean, but is likely brand new as dealer has mechanic go over all vehicles), rear leaf springs may be sagging just a bit, shocks are all original, rear axle and parts of shocks have been rattle-canned over in black, wheel wells may also have been recently sprayed with undercoating, plastic insert bed liner has left it's mark around the top of the bed/gate, hitch has obviously been removed, water was dripping from front seam of bed from where a crack in the bed liner was allowing this week's rain in (truck was inclined forward slightly, so bed had ~1" of water in front half -- concern being moisture trapped under liner), frame has not obviously been treated/replaced.
    (aside question: is it true that frame inspection must occur this month?)
    dealer came down to $15,800 and let me walk. it's been on the lot for six or seven weeks after having spent 2-3 months on a toyota-dealer's lot after trade.
    thanks in advance for the thoughts!!
  2. Oct 9, 2010 at 1:07 PM
    ChewbacaTW
    ChewbacaTW My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    If you can wait till towards the end of the month, and they still haven't sold it, go in and offer them 15k. Do it on a wednesday too. but if you are afraid it might be bought out from under you, GO FOR IT!!!:D It's a nice looking truck.
  3. Oct 10, 2010 at 12:51 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Nice find. Looks good. Buy it and don't look back. At 80K it is barely broken in. :D
  4. Oct 10, 2010 at 1:09 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Yeah, looks like a real nice clean truck.
  5. Oct 10, 2010 at 3:04 AM
    Tommo
    Tommo Well-Known Member
    Fairfax, VA
    base 4X4
    Sounds too high to me. I just bought a '09 base regular cab 4X4 with 18,000 miles for $16,145 in June. Have you checked on Autotrader, Ebay and Kelly Blue Book websites?
  6. Oct 10, 2010 at 3:32 AM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
  7. Oct 10, 2010 at 3:35 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    sorry this is the link. the above is for a Tundra... $15,965
    http://www.kbb.com/used-cars/toyota...137033|true&condition=excellent&mileage=81000
    btw, if you're going to buy a truck. go to the dealership at the end of the month... at the end of the day. end of the month because they're trying to fill their quotas. and at the end of the day because they're trying to hurry up and get a sale so they can go home
  8. Oct 10, 2010 at 3:46 AM
    chrisx1
    chrisx1 Well-Known Member
    NE Missouri
    95 4cyl 4x4 5sp
    15x8 Pro Comp Wheels w/4" backspacing, 31x10.50 Mickey Thompson MTZ's, Bilstein 5100's set to 2.5", URD Short Throw Shifter kit, URD rear O2 sensor simulator
    Like Chewie said - wait till the end of the month, in the middle of the week, walk in and offer them blue book value or less. The salesmen are hungry for a deal then because their boss is on them to meet their quota for the month.
    I have purchased 4 or 5 cars at the stealership.....you have to really be on your game to get a good deal, and be willing to walk away if they won't deal.
    It is a great looking truck, but don't pay more than you should!!! :)
  9. Oct 10, 2010 at 6:45 AM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
  10. Oct 10, 2010 at 7:02 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I notice the ad says 27,000 miles and odometer says 62,000?
  11. Oct 10, 2010 at 7:06 AM
    david7268
    Tucson, AZ
    NONE.....yet!
    Trip mileage 6293..........
  12. Oct 10, 2010 at 7:22 AM
    WNYTACOMA
    Clarence, New York
    Ahhh..
  13. Oct 10, 2010 at 1:47 PM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    nadaguides: retail 16675
    edmunds: retail 14074 (clean), 15400 (outstanding)
    kbb: retail 14620 (excellent)
    so part of my issue is the wide range of values offered by these resources. dealer says that he can't buy them at auction for what edmunds and kbb say they're worth...
  14. Oct 10, 2010 at 3:49 PM
    david7268
    Tucson, AZ
    NONE.....yet!
    Nevermind
  15. Oct 10, 2010 at 4:54 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    The frame inspection from what I am told by Toyota you get a free inspection once a year, I bought a 04 Acess,TRD 50 K auto new tires and battery, one owner, all Toyota service records in May of this year in Kansas City gave $18,500 ( Car Max ). I probably paided a little more than I should of but WTF, you gona do if you want it. Also if you buy it check the Quarter glass window's for broken links. Good luck!
  16. Oct 22, 2010 at 4:17 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    I just got a 2003 w/94k. Loaded and looks NEW. has everything except overdrive. 4x4 extra cab w/6cyl,bed cover, crome wheels,sr5, off road racing ,ECT>. Paid 13k. It does need tires -probably 700.00. I would low ball them w/14k.at the end of the month. they try to reduce inventory for tax reasons. KEEP LOOKING-Get what YOU want at YOUR PRICE. I looked for 9 months--finally found what I wanted-except year--wanted a 2004-- got 2003 and not dissappointed--GREAT TRUCK
  17. Oct 23, 2010 at 6:54 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
  18. Oct 24, 2010 at 7:30 AM
    Madjik_Man
    Colorado Front Range
    Just remember in 10,000 miles you're gonna have to do the timing belt and water pump which usually runs upwards of $600
  19. Oct 25, 2010 at 5:18 AM
    tacod
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    @newertoy: that's pretty much how i'm going. interestingly, the truck still sits on the dealer lot, so their price obviously isn't a steal. i like this truck and it's essentially what i want...except for the price...
    @fidencio: it's tough to go by the listing prices...searching autotrader, there are a bunch of trucks for $16k-ish that are similar. but many have been there for awhile...and they don't update the listings with what they ultimately sell for. there's similar truck on ebay right now that is relisted. the last time through, bidding petered out at $14.6k...reserve not met. on dealer's website: $18750(!).
    @madjik: that is foremost in my mind...especially since there are essentially no records available for this truck.
    thanks all for the input!! still looking...or waiting for the dealer to call back. they did drop another $300 off the price in a recent email exchange...but claim they can't do 14s (which is my stated range). they suggest that these trucks auction in the 14s, but of course haven't said what they paid for THIS truck...
  20. Oct 25, 2010 at 5:47 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    you have to wonder why the truck sat in the dealer lot for 2-3 months and didnt sell and now almost 2 months here and still didnt sell
