Thoughts on this black/chrome rim?
Discussion in 'Wheels & Tires' started by TheRiddleOfSteel, Mar 3, 2011.
  1. Mar 3, 2011 at 10:16 AM
    TheRiddleOfSteel
    TheRiddleOfSteel [OP] Well-Known Member
    Phx
    08 TRD sport
    Truck is black-sand.
    The all black isnt for me, I only like those for the charcoal gray or midnight blue trucks, so I wanted a black w/ chrome accents or vice versa.
    http://www.tirerack.com/wheels/Mini...autoModClar=2wd+Prerunner&wIndex=96&grid=true
    If you know of anything along these lines that I should check out, please let me know.
    Im also going to try to put the 285/65/18's on and do some cutting underneath, Id rather not do a lift but might do a 1.5 rough country or something if I have to.
    thx
  2. Mar 3, 2011 at 10:19 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you plan on running 285/65/18's, first you need a 3" lift. Then you need wheels with less backspacing than the ones you posted.
  3. Mar 3, 2011 at 10:26 AM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    Im not sure whats up after the thread
    BFG TA KO 285/65/18 on Chrome XD Monster with 3" Lift
    looks like he had only minor rub with a 18mm offset, so Im thinking with 12mm Id have less.
    I called ultra wheel and they recommended the 12mm offset, but they have a 0 offset and I wonder if that would prevent any rubbing...
  4. Mar 3, 2011 at 10:36 AM
    KPT
    09 Prerunner
    -12mm (negative 12) would be best for a 9" wide rim.
    You'll find that 99% of people still had to trim a bunch of fender well plastic to fit 285/65/18's, even with a 3" lift and wheels with 4.5" backspacing.
    There's always the exception, such as the thread you posted above. I would be willing to bet those tires rub significantly when there is any suspension flex at all. Note how he also had to glue his fenders with gorilla glue to keep them from rubbing...and one of them broke loose after it made contact with the tire. That doesn't qualify as "minor rub" to me.
    If you want a no-rub setup on stock suspension, loo for 285/60/18's. They are 32's and several folks on here have them with no issues. You coud also go with 265/65/18, which is what I have.
  5. Mar 3, 2011 at 4:27 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    was just at discount looking at the 285/65 and 285/60
    I guess the 60's arent that much smaller and if they avoid all the hassle (and having to spend $ on a lift) they are the way to go
  6. Mar 3, 2011 at 8:14 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Ehhh cheap wheels. I say no.
  7. Mar 3, 2011 at 10:13 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    ^ got any similar/better alternatives to check out?
  8. Mar 4, 2011 at 6:43 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    The only reason I have 285/65/18 on mine is because I found the tires and wheels used so I couldn't be picky. When I wear these out I will switch to 285/60. Less rubbing, less power loss, better gas mileage. I just did the last bit of trimming on mine and they currently do not rub. Had to cut a good bit of the plastic in the front of the fender well, cut a corner off the fender flare, and trimmed pieces out of the mud flaps so they wouldn't rub. I could have removed the flaps, but wanted to keep the rocks off the truck.
  9. Mar 4, 2011 at 6:47 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    No bueno. That looks ugly. Get some flat matte black wheels.;)
  10. Mar 4, 2011 at 11:09 AM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    I havent seen any all black, or mostly black, wheels that I would like on a black truck, so im pretty much looking for black with chrome accents or vice versa.....im just surprised there arent as many choices out there as I would guess
  11. Mar 4, 2011 at 11:16 AM
    KPT
    09 Prerunner
    How about these? Dick Cepek DC-2's
  12. Mar 4, 2011 at 11:25 AM
    KPT
    09 Prerunner
    Or Eagle alloy 63's
  13. Mar 4, 2011 at 11:59 AM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    that eagle 63 looks pretty sharp, I hadnt seen that brand on any of the tirerack.com/etc sites, now I need to try to find a pic of them on a tacoma (mine's black)
  14. Mar 4, 2011 at 12:08 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    my truck's not black but the color scheme on mine is close to that eagle 63 but mine are 187 blacks
  15. Mar 4, 2011 at 12:18 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Soooooooooo sickkkkk:drool:
  16. Mar 4, 2011 at 12:31 PM
    KPT
    09 Prerunner
  17. Mar 4, 2011 at 12:40 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
  18. Mar 4, 2011 at 1:28 PM
    Bama_TACO
    Winfield, AL
    I wanted some of these when I was looking for 17" wheels, but they only came in 17x8 and I really wanted 17x9. They look really good on a Tacoma. There is a black one close to where I work. They are Eagle Alloys 140.
  19. Mar 4, 2011 at 3:39 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    now im prob gonna go with XD spies
  20. Mar 4, 2011 at 7:00 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
