Throttle Body cleaned and Now!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gerry Pope, May 25, 2010.
  1. May 25, 2010 at 6:45 PM
    Gerry Pope
    Gerry Pope [OP] Well-Known Member
    San Diego
    07 4X4 PreRunner
    Good Day..
    I have a little problem.. I removed the screws holding the air box and tilted it out of the way. Plenty of room to get at the T.B. I used a lint free towel and carb and throttle cleaner. I manually moved the butterfly till I could get in there with the towel. I wiped some residue.. wasn't much.. But enough to leave the towel pretty filthy. Looks pretty clean now. I have 21K on my 2K7 TRD Sport AC 6 spd.
    I put everything back together and went for a ride. It starts fine but idles around 2k now.. It would idle @ 1-1.5k before I cleaned the T.B.
    I double,triple checked everything and all looks good.
    Any Ideas..
    Regards,
    Gerry
  2. May 25, 2010 at 6:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it will idle like that til it relearns the mix. unhook your battery cable for a few minutes and reconnect it.
  3. May 25, 2010 at 6:57 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Thanks for the response.. Will do..
  4. May 25, 2010 at 7:13 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    Are you sure you plugged back in the smaller vaccum/airlines connected to the airbox? there is a small one at the backside of the airbox that doesn't have alot of slack. A higher idle could also mean vaccum leak...
  5. May 25, 2010 at 7:29 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    I am kind of new with the ECU in these trucks, most of the vehicles I have worked on in the past requires the disconnect to be done with a cold engine block, or a cold start after battery disconnect. Following the cold start, no throttle response until engine is warm. Had you heard of this with the Tacomas?
  6. May 25, 2010 at 7:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah......not really. i always unhook after i've had it running........both tacomes i have had...first and 2nd gen)...and havent had a problem.
  7. May 25, 2010 at 8:11 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Yup..
    Double checked.. That small vac hose is where it should be..
  8. May 25, 2010 at 8:25 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  9. May 25, 2010 at 8:25 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    What he said of what the other guy said.
  10. May 25, 2010 at 9:36 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    had same prob , after awhile it went back down. much more power my was sooooo dirty.
  11. May 25, 2010 at 9:59 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Thanks for all the help..
    Nice easy fix..
    Gerry
