Throttle body cleaning?
Discussion in '4 Cylinder' started by u02913, Jul 14, 2009.
  1. Jul 14, 2009 at 9:33 AM
    u02913
    u02913 [OP] Member
    pa
    1996 tacoma
    To eliminate the idle shaking the Toyota dealer suggested we do a Throttle body cleaning. Is this something I can tackle myself? If so, can somebody please give me a procedure for doing this and the items I need for this. The vehicle is a 1996 Toyota Tacoma 2.4L 2WD. Thank you.
  2. Jul 14, 2009 at 10:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW.
    Yes it is fairly simple. Let me find the FSM. Where in PA are you located?
  3. Jul 14, 2009 at 10:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here is the link for the FSM. You will have to download it to view it.
  4. Jul 14, 2009 at 10:39 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    This seems to be the standard service rep answer for everything. I don't think I've been to the dealer yet when they didn't suggest a throttle body cleaning. I am assuming therefore that this is a ridiculously expensive but extremely simple task to undertake. Must be the first service they teach them to "sell".
  5. Jul 14, 2009 at 8:06 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  6. Jul 20, 2009 at 5:32 AM
    mdub
    mdub Well-Known Member
    Missouri
    2016 Black DBLC TRD Off-Road
    ARE CX
    Has anyone found that after cleaning their throttle body, the idle is a bit high? Cleaned it yesterday, let it sit with the air intake off for about 15 minutes when done, Fired it up so it would for sure start again on Monday morning. Drove 12 miles to work, parked, put car in neutral, idle is sitting at about 1000rpm. Usually idles in the 600-750 range.
    2001 2.7l I4 Manual Transmission.
    does it just need a few driving sessions to work itself out?
    Thanks!
  7. Jul 20, 2009 at 6:58 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Just go to a auto parts store and get a bottle of Techron Concentrate Fuel injection cleaner. Put it in with 12 gallons of gas and it will not only clean your entire fuel system, but will help remove carbon deposits from the top of the pistons. If a severe case do it twice. $7 a jug and many times AAP and O'Reillys run this as a BOGO item. Try to do this near the end of a oil change interval as the krap Techron removes, some of it makes it to the oil.
  8. Jul 21, 2009 at 4:53 AM
    mdub
    Missouri
    ARE CX
    Thanks 91r100gs!
    I pulled the neg terminal on the battery for about 4 hours. Put it back on and now that the computer reset i'm running at the right RPM.
    I've heard of the Techron, a friend swears by it. I'll try it soon because I need some gas and an oil change is near.
    Thanks again!
  9. Jun 13, 2017 at 3:48 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    That's what I always do B4 every oil change - does that mean I Don't have to do a throttle body cleaning at all ? I have 100,000 on the truck. Thanks.
  10. Jun 13, 2017 at 7:24 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Clean your throttle body. Fuel system cleaner doesn't touch the throttle body.
    98tacoma27 likes this.
  11. Jul 14, 2017 at 11:14 PM
    Jigeye
    Jigeye Active Member
    Alaska
    09 2.7L SR5 4x4
    LCE header, secondary air filter removed, AFE pro-dry S, backup camera anytime, blistein 5100s on .75" and General HAD leaf springs, Michelin Defender LTX 165/70/16 on stock rims, Cali Raised stealth mount light bar, leer camper shell, 200k miles mod
    There is a sticky thread at the top of the 4cyl page with easy instructions to clean the throttle body, and yes, it's a good idea to do it every once in a while. Just cleaned mine this morning as a matter of fact. Idle is a bit more smooth now.
    Also, in regards to the techron fuel treatment, this:
    https://youtu.be/h8i9qftqKNY
  12. Aug 12, 2017 at 12:01 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    anyone actually notice a difference after doing this? whats the reasoning? sounds like most people seem to create problems by cleaning.
  13. Aug 12, 2017 at 6:56 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    maybe the easiest/safest way would be using a rag or microfiber towel spray it with cleaner and wipe out the inside of the intake throttle bottle instead of spraying cleaner directly into it, doing the later seems to screw up the idle for a lot of people. I never really seen an improvement in doing it but getting the soot buildup out and from around the butterfly keeps it from binding or sticking for maybe better throttle response.
  14. Aug 12, 2017 at 8:19 AM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I had a smoother idle after cleaning my throttle body and MAF, but it only lasted 1-200 miles until the ECU relearned itself. My idle is rough when the AC compressor is engaged. If I turn off the AC, the idle smoothes out.
    TheCookieMonster likes this.
  15. Sep 20, 2017 at 9:46 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I just did the Seafoam treatment to my throttle body. I'm also on the second treatment of Amsoil PI. The engine does run a lot smoother and there seems to be much more "pick-up" but the idle was only smooth for about a day. From what I have read and from what a friend of mine who was a Toyota mechanic tells me? The 2.7 is just is what it is once it gets miles on it. They idle and vibrate at the same time. Some do and some don't. I'm at the point that if it runs smooth, gets good mileage and gets me where I want to go I'm not going to worry about a slightly rough idle. Many posts and pages on this forum have been dedicated to this problem with the 2.7 and I've come to realize that it's just the way they are. That's why Toyota added the dual balance shafts to the 2.7 I would guess. Until I get a code I won't worry about it but I still think I'll buy an IAC valve to have on hand when the code pops up. Then there is the myriad of vacuum hoses on these newer vehicles to check. Let alone the various valves.
  16. Sep 9, 2018 at 5:01 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Cleaned the Throttle Body on my dad's Camry 2.4. The idle was low and rough before. Cleaned it out with CRC Throttle Body cleaner and a rag. Idle was high afterwards. I simply disconnected the battery for 10 min and it was back to normal after that. I read that the Idle becomes high because there is now increased air flow after cleaning and the engine adds more fuel to compensate for increased air.
  17. Sep 10, 2018 at 5:58 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    well that doesnt clean the throtle body how would it?
