Throttle Body
Discussion in '1st Gen. Tacomas (1995-2004)' started by crzylee, Oct 28, 2009.
  1. Oct 28, 2009 at 5:18 PM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    99 tacoma xcab 4wd 3.4L
    I have a 99 taco and I purchased a replacement throttle body from a 96 4Runner. Got everything replaced and mounted, but went to plug up the TPS and I have a 3 prong harness, and a 4 prong sensor. Has anyone wired this up to work? Check engine light stays on, and its idling near 2k RPM.
    Thanks!
  2. Oct 28, 2009 at 6:20 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Subscribe, just want 2 no the answer 2 this 1
  3. Oct 28, 2009 at 6:32 PM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    I guess I should have put the engine size sorry - its the 3400 V6
  4. Nov 1, 2009 at 6:50 AM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    BUMP!
    Anyone? Someone? Anything!
  5. Nov 1, 2009 at 7:00 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You might not be getting any answers cause this is in the wrong section...Should be a 1st gen post.
    No idea what you can do...sorry.
  6. Nov 1, 2009 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I'lll move it to first gens.
  7. Nov 1, 2009 at 7:25 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    well this may sound a little basic but can you swap the TPS? probably the easiest fix
  8. Nov 1, 2009 at 10:35 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    could you just splice the wires and hook them us to the correct plug? idk
  9. Nov 1, 2009 at 3:17 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    yeah what he said or just take it back and get the right one
  10. Nov 1, 2009 at 9:15 PM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    Thanks, thought I had a 2nd Gen, my bad. First time owning a Taco and don't know a whole lot about them.
    Thought about that and started to try it. Realized on the new TB, the butterfly rod isn't the same as the old one. Old one has a single rod, the new one has 3. Weird.
    Heard I could do this, but I'm unsure of what wires from the harness go to what ports on the TPS.
    Can't do that. eBay purchase and it was used. Got it with a cruise control module for $40. New they were $200 +
  11. Nov 1, 2009 at 10:47 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Check the junkyard for the correct one & resell that one on ebay. Splicing and rigging it to fit sounds like it could cause more harm than good down the road.
    Welcome to TW!
  12. Nov 2, 2009 at 10:49 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    x2, sounds like the wrong TB.
  13. Nov 3, 2009 at 4:20 AM
    crzylee
    crzylee [OP] Member
    Brandon, Ms
    Thanks guys! I will do some searching.
