Throw out bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 14deckedtaco, Sep 1, 2016.
  1. Sep 1, 2016 at 5:18 PM
    14deckedtaco
    14deckedtaco [OP] New Member
    Brandon
    2014 tacoma 6speed
    Retrofit headlights, 3inch lift, 33's, daul exhaust
    Alright guys I have a 2014 toyota tacoma it had a 3" rough country 33" tires and my throw out bearing is squeeling I took it to dealership and they say lift caused the problem I know better but I need help to prove to them that it didn't I know some have had this issue with same mods and I just need any tips or proof to get them to fix it any information is helpful thanks guys
  2. Sep 2, 2016 at 5:12 AM
    gearcruncher
    Canadain bumper technician
    10trdtaco likes this.
  3. Sep 2, 2016 at 11:52 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have them explain how the lift effected the throw out bearing. Keep pushing and open a case with Toyota Corporate.
    gearcruncher likes this.
  4. Sep 2, 2016 at 11:55 AM
    eon_blue
    Azusa, CA
    I don't see how a lift will cause a throw out bearing to go bad, lol. That doesn't make sense to me.
    When my throwout bearing started to go bad, it chirped like my truck was full of crickets whenever I was coasting in gear. Applying throttle or pressing the clutch pedal would make it go silent, is that how your's is?
  5. Sep 2, 2016 at 12:18 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Isn't there a tsb for this thing?
  6. Sep 2, 2016 at 6:54 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wow, are those red lights legal?
  7. Sep 2, 2016 at 7:02 PM
    eon_blue
    Azusa, CA
    You can control the colors and switch them to normal, at least if it's the setup I'm familiar with.
  8. Sep 3, 2016 at 4:55 AM
    14deckedtaco
    Brandon
    2014 tacoma 6speed
    Mine has gotten to the point where it squeaks all the time unless I push clutch in and the red lights change colors to whatever color I want flash go with music etc the kit is from led concepts and I've worked on vehicles all my life and can't figure out how the lift caused this problem especially since I only have a 1" block in the rear but thank you all for the feedback like I said any info is better than none and is all appreciated
  9. Sep 3, 2016 at 5:19 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is correct "It Can't". You need to not let them get away with the false claim that it did. Have them explain to you how the lift effected the throw out bearing. God I would love to hear them explain it.
    They are counting on you not pressing the issue. Bring up the Magnuson–Moss Warranty Act. When you escalate this up through the service manager and general manager of the dealership. Be nice, but let them know you are not going to go away.
    http://www.mlmlaw.com/library/guides/ftc/warranties/undermag.htm
  10. Sep 3, 2016 at 9:47 AM
    eon_blue
    Azusa, CA
    I've heard that some throwout bearings will squeal when going bad, mine was a chirper though. Could also be a possible bad pilot bearing, or cracked flywheel. All part of the clutch assembly though and will require the transmission to be dropped in order to access and replace the culprit. So you might as well just throw a whole new clutch in while you're at it, if you only replace the throwout bearing you're paying hundreds of dollars in labor just to replace a $20 part.
    Also, I have a 60k warranty on my truck and my throwout bearing went bad at 30k. The warranty provider wouldn't cover the bearing because it's a normal 'wear and tear' item (part of the clutch), even though I argued that it shouldn't go bad at 30k...they should last at LEAST 90k. They wouldn't have it though, had to pay for it out of pocket.
  11. Sep 3, 2016 at 10:53 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  12. Sep 3, 2016 at 3:22 PM
    14deckedtaco
    Brandon
    2014 tacoma 6speed
    Can somone tell me how the Magnuson–Moss Warranty Act can help me I read it but I dont quite understand how it will help me in my situation
  13. Sep 4, 2016 at 6:41 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The aftermarket lift has no effect on the throw out bearing.
    The Magnuson–Moss warranty act says they have to show a correlation between the failure of the throw out bearing and the lift.
