Throwout bearing again!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by P. Bauer, Oct 31, 2008.
  1. Jun 23, 2010 at 10:19 PM
    #181
    joes06tacoma
    Joe
    Central Coast, CA
    Knowing what I know now, I would have bought the automatic instead. At least they fixed the automatic (software).
    Edit: To answer your question a little better, everything I have read makes it sound like the 2010s are put together the same way, so most likely will have the same problems.
  2. Jun 24, 2010 at 1:23 AM
    #182
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    It's $234 to my door. And yes I'm going to do it myself. I should be able to get it done in a few hours. I'm not going to do an upgraded clutch since I just don't have the money right now. And if I were to do it again I would have bought an auto.
  3. Jun 24, 2010 at 1:32 AM
    #183
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Stories like this are why I am going to get that extended warranty when I start to get close to the end of mine.
  4. Jun 24, 2010 at 4:11 PM
    #184
    TMCAEG
    TMCAEG Well-Known Member
    Vancouver, Canada
    2005 Access Cab TRD Black
    Double check the fine print. The Toyota extended warranty I have (Canadian) doesn't cover the bearing OR the clutch outside of the original 3yrs or 60,000KM warranty - it is considered a wearable item...
    I had mine replaced about 3300KM ago - at my cost and it is chirping again...let's see what the stealership says about it now.
  5. Jun 24, 2010 at 4:13 PM
    #185
    solidcopy
    solidcopy High Speed, Low Drag
    WV
    2010 DC 4x4 TRD Off-Road
    I feel so much better about opting for the automatic, having read this.
  6. Jun 28, 2010 at 2:46 PM
    #186
    firegoldlynx
    firegoldlynx Member
    08 TRD 4x2
    STOCK
    Just dropped off my 08 under factory warranty for chirping from the TOB, and a creaking clutch pedal, I just couldn't take the noises anymore. So we shall see.
  7. Jun 28, 2010 at 5:41 PM
    #187
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Your truck is a 5 speed right? i thought this was only on the 6 speeds. ??
  8. Jun 28, 2010 at 9:30 PM
    #188
    firegoldlynx
    firegoldlynx Member
    08 TRD 4x2
    STOCK
    nope, see this thread,comment 145, v6 6speed manual
  9. Jul 1, 2010 at 3:53 PM
    #189
    Trapper6speed
    Stock
    Ok almost done here with the replacement bearing and sleave. It seems to me this done before since the shaft wasn't too bad and the bearing looked fairly new. I hope this fixes it.
    Everything is in but now a check engine light? I will figure it out later. No squeaking, yea:burnrubber:
  10. Jul 1, 2010 at 7:41 PM
    #190
    Trapper6speed
    Stock
    Anyone know if it's that big of a deal to accedently mix up the plugs on the cats?
  11. Jul 1, 2010 at 7:54 PM
    #191
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You mean O2 sensors, it should not be they are the same just different readings, so computer will re-learn back. :)
  12. Jul 1, 2010 at 8:16 PM
    #192
    Trapper6speed
    Stock
    I'm going to stop by a parts store tomorrow and get the CEL looked up. I hope I didn't ruin a cat by beating a that stud out of the flange. Some half wit cross threaded one stud on there and it was a pita to get out after I stabed the trans.
  13. Jul 5, 2010 at 6:18 AM
    #193
    oldschoollear
    oldschoollear Active Member
    Rich
    Nashville,TN
    07 TRD 4x4
    Stocker
    2007 32,000 miles, chirp-chirp-chirp. Going to the dealer Monday. Does the PDM kit have a special bearing? Would it be available down the line if a replacement was needed. After a lot of research, it seems like getting the PDM kit installed with a new bell housing is the best fix I can think of, anything else looks like they are just throwing parts at it. How receptive do you think a dealer would be if I asked for the bell housing under warranty, plus the labor, and I pick up the tab for the kit. I plan on being well armed with info from these threads showing new release bearings are not the answer( there doesn't appear to be an answer).
    Went to the dealer( BEaman Toyota in Nashville) this morning. They said no warranty if it has anything to do with clutch. I immediately called Toyota customer service( they are off today) to start complaining. Any info that I could reference to customer service would be GREATLY appreciated. My 3 year is November and I'm at 32000 miles.
  14. Jul 5, 2010 at 9:14 AM
    #194
    oldschoollear
    Rich
    Nashville,TN
    07 TRD 4x4
    Stocker
    Update #2- Beaman called, turns out they will warranty the Release bearing. Intially, I was told no waranty for clutch, Seems that they called head quarters with the problem and were told to do it under warranty( this tells me corporate has heard of this enough to say do it). I tried to express my concern that this was not the fix, but they still insisted that it was the only thing they found. I asked them kindly to inspect the shaft carefully for damage. Looks like my saga is just begining, I have to give it up to Beaman for a virtually hassle free experience;which is good since I'll probably be back soon with the same chirp. Again, any and all advise, documentation, help ect. Would be greatly appreciated.
  15. Jul 5, 2010 at 9:43 AM
    #195
    Trapper6speed
    Stock
    Good luck. Mine looks like someone has already been there once, when I bought the truck there was just a little faint chirp and I talk to the dealer about it they said the all do that it should be fine so I got a little more out of them with my concern about it. But when It got worse I called and ask if there was anything they could do about it they were onl concerned about the mileage and I was out of any warrenty they had. So I just fixed it myself, but after finding two minor bolts crossthreaded and one looked like a repair from being snaped off. Im glad I worked on it myself knowing my Bro inlaw use to work for a Toyota dealer, seeing the kinda people that work on your stuff there. Good luck at the dealer.
  16. Jul 5, 2010 at 9:46 AM
    #196
    taco_89
    taco_89 Well-Known Member
    Steven
    So-Cal
    09 PreRunner SR5 V6 TRD
    ABS SWITCH,PAINTED RIMS,PAINTED FRONT AND BACK BUMPER,HEADLIGHT MOD.CUSTOM EXHAUST:)
    thats funnyy that toyota would say that.. yah man stay strong and if it keeps happening tell them they better just swap your tranny or give you a freakin new truckk. do you have the 100,000 mile warranty?
  17. Jul 5, 2010 at 10:18 AM
    #197
    oldschoollear
    Rich
    Nashville,TN
    07 TRD 4x4
    Stocker
    I have 3 year/ 36k mile. 3 years is gone in November, I'm at 32,600. I've seen a sticky on one of the forums for the 100k mile waranty for a good deal. prob going to that if it covers this. I'm also thinking about buying the bearing kit and going that direction.
  18. Jul 5, 2010 at 10:21 AM
    #198
    oldschoollear
    Rich
    Nashville,TN
    07 TRD 4x4
    Stocker
    I know you haven't had it on long, but how does the sleeve kit seem to work?
  19. Jul 5, 2010 at 12:22 PM
    #199
    Trapper6speed
    Stock
    I feel the sleave kit is working great.
  20. Jul 16, 2010 at 9:58 AM
    #200
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
    Just took in the truck yesterday and told them when i went in the first time he told me the noise was from the belts being dirty!!! So me not knowing left and it came back worse and worse so i looked up on this thread and found my problem.
    when i brought it back yesterday i told the guy they messed up leading me to belive something else while the prob gets worse,i tell him i reserched and found out these is a big prob. He looks on his computer and says no TSB or other reported cases. Left the truck for the head mech to look at and call me back, iused some quotes from the site to get my point across but well see later how this works out. 2007 AC 6 speed with 59,378 miles so just about done with warrenty. I'll keep posted!!!!!
