Throwout bearing again!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by P. Bauer, Oct 31, 2008.
  1. Oct 27, 2009 at 5:59 PM
    #121
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
  2. Nov 24, 2009 at 9:07 AM
    #122
    Toph
    Toph Addicted to V8s
    Took mine in again yesterday after the squeak came back...no transmission replacement, but they told me toyota is working on an updated bellhousing that will be out at the first of the year...apparently there's an alignment issue with the current design. Hopefully they'll make the pilot shaft out of steel this time...either way, I'm glad to see they're coming up with a design fix.
  3. Nov 24, 2009 at 8:40 PM
    #123
    Oppie1
    Oppie1 Member
    Can't wait!
  4. Dec 1, 2009 at 4:59 PM
    #124
    Toph
    No courtesy car...I just had to wait while they put it back together :mad:
  5. Dec 1, 2009 at 5:10 PM
    #125
    ridereno
    ridereno Well-Known Member
    Tom
    Reno, NV
    2017 Tacoma DCLB 4X4 TRD-Off Road
    I am having the same problem. I have a 2007 with 52,000 miles on it and it has been making the noise for the last 15,000 of that. I am actually glad to hear it may be the throwout bearing and not a bearing in the transmission.
  6. Jan 6, 2010 at 9:08 PM
    #126
    tenbbs
    tenbbs New Member
    Louisiana
    None yet...
    Boy am I glad I did a little research on this truck. I've known many old farts that converted from US made full sizes to Tacomas and Tundras, and I suspected they had figured out it was a superior product. I bought a GMC 1500 5 speed RWD in 01, and somehow it knew last year that it had hit 150k miles (I drive, highway, quite a bit) and in the last 12 months it's gone through complete XMSN replacement (ratcheting sound in all gears), clutch (was due), Master cylinder, fuel pump, and is in the shop for a 2nd master cylinder now. It's well beyond the point where no matter how much $ I pour into it to fix it, I'll never get that money back in a vehicle sale.
    Now knowing what all the old farts figured out years ago, that the Toyota is in general, a superior product, I went looking for a Tacoma Access Cab, V6, 4x4, Manual. I test drove a 2009 and it should suit all of my needs. The dealer wouldn't come off of their invoice price of 26,4, so I hit the bricks and left them with a truck that became an 09 leftover the next day. I've found a dealer that will sell a 2010 in the correct configuration for 25,1, and I want to be all over it. I'm ready to drive a few hours to save $1300.
    And then I read this thread. While on the upside, it appears that Toyota has eventually manned up and replaced the problem children, that only happens on visit number 4 or 5 for service, and it happens near the end of the 5yr/60k powertrain warranty. Sounds like 1) A pain in the ass 2) Real close to falling outside of the warranty's limits. At the speed I put miles on the GMC, in a Toyota I'll be outside of that warranty in 3-4 years, and based on the breakdown point of the throwout bearing / pilot shaft / bellhousing alignment issues described here, I'll find those within 2-3 years.
    The questions:
    The last post in this thread was a whole month ago - Has there been a Tech Svc Bltn, recall, or replacement part(s) issued since then?
    Is it worth chasing the dealer around multiple times to get this fixed?
    Even then, is it really fixed, or is the "new" replacement XMSN going to start shitting bearings 40-50k miles later, just like the original XMSN did?
    I don't want to have this kind of problem go down in the wintertime - If the truck is going to be in the shop for multiple iterations, that puts me on the motorcycle multiple times. I wanted to buy the Toyota because of the "legendary reliability" that the GMC has not had over the last year...
  7. Jan 7, 2010 at 7:17 AM
    #127
    Oppie1
    Oppie1 Member
    I'm not a fan of my Tacoma. Too many annoying issues other than the bearing. Buy a Ford truck.
  8. Feb 3, 2010 at 7:09 AM
    #128
    ClimberE
    ClimberE New Member
    Eric
    Seattle
    05 4x4 TRD Off-Road
    So, I just bought an '05 4x4 DC MT from a used car dealer with 59k...
    Just noticed the squeeling TOB...
    Thought I would check out the problem on the googles...
    Immediatly followed by a large pit in my stomach...
    Anyone know if Toyota allows their 60k warranty to transfer to new owners?
    I think I may puke.
  9. Feb 20, 2010 at 7:47 AM
    #129
    WeeCujo
    WeeCujo New Member
    Little Rock
    07 Tacoma
    I have a 07 Tacoma, 44,000 miles, 6 speed manual, same problems with throw out bearing, haven't had it replaced yet. Dealer in Little Rock (North Point ) says not covered under 5/60 warranty, Talked to Customer Relations Manager at dealer, called Toyota (on hold for 1 hr 15 min) finailly talked to Senior Customer Experience and got same response (not covered) and will not admit to there being a common problem. Filed complaint with BBB, same response, Toyota will provide no assistance case closed!! Can the people that had it covered under 5/60 warranty give more info (name of Dealer ect..) that may help my cause?
  10. Feb 20, 2010 at 8:14 AM
    #130
    firegoldlynx
    firegoldlynx Member
    08 TRD 4x2
    STOCK
    My 08 taco 20k miles just started to chirp, put slight pressure on the clutch and it goes away. Anyone, know about the redesigned parts that are supposed to be available in Feb-2010 that I've heard about.
  11. Feb 20, 2010 at 8:22 AM
    #131
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    This sounds like a pretty serious yet common problem? Throwout bearings shouldn't need to be replaced in that quantity at such low mileage. The fact that this is happening to multiple years/owners tells me the problem lays in the design, not the individual.
  12. Feb 20, 2010 at 8:57 AM
    #132
    Terrier
    Idaho
    Is yours a 5 speed or 6 speed? If it is a 5 speed, I do not think they have the same parts. I think the 5 speed shaft is removable from the bell housing. Of course, your's could be an entirely different issue.
  13. Feb 20, 2010 at 9:26 AM
    #133
    firegoldlynx
    firegoldlynx Member
    08 TRD 4x2
    STOCK
    It is the 6 speed manual 4.0L V6
  14. Feb 25, 2010 at 4:03 PM
    #134
    cudason
    cudason Well-Known Member
    Vancouver
    TURD
    Eagle Alloy 050 series wheels. TRD fj shift knob Bilstein 5100 set @1.75 TRD CAI TRD seatcovers 2009 Taillights Xenon HID kit
    i have an 05 with 54,000 mile. local dealer won't fix under warranty. i'm salty. what a joke
  15. Feb 25, 2010 at 4:32 PM
    #135
    cudason
    Vancouver
    TURD
    last fucking toyota i buy.
  16. Feb 25, 2010 at 4:53 PM
    #136
    ryhar85
    ryhar85 Well-Known Member
    W. WA
    05 TRD 3" lift
    3" Trailmaster lift, 18" rockstars blacked out, 275/65/18 sxt mud terrains, more to come.
    I have this exact same problem. Never really thought it was a big deal till a few weeks ago when it started to get worse (chirps / squeals almost all the time now) I am gonna call the dealership and see what they say. I bought it as a 'Certified' pre owned and got the 100k extended warranty. It has 91k right now, so I need to jump on this to have any luck at all. Also, does anyone know if the extended certified 100k warranty would have any impact on the rear spring tsb? Cause my rear springs are bad (negative arch, and squeak like crazy) and I would love a new set. . . :D Not sure if it works like that though.
  17. Feb 27, 2010 at 10:17 AM
    #137
    cudason
    Vancouver
    TURD
    toyota will not warranty it. they say its not part of the powertrain warranty. toyota shit the bed big time here. make sure everyone who has the 6 speed lemon calls toyota and lets them know. i guess i'll trade my truck in on a honda. toyotas are crap...
  18. Feb 28, 2010 at 9:58 AM
    #138
    ridereno
    Tom
    Reno, NV
    I talked to my dealer here in Reno and they said they have heard about it, but it is not covered at all under any warranty. Also asked about the rear springs and that was only covered if I got it in before 3/36 warranty. At the time I had 54,000 miles. This is my second Tacoma I have purchased from them, and even that didn't get me anywhere. :confused:
    I have to be honest though, I find it hard to believe that some people are claiming to have had there transmissions replaced because of this. To me that would be like replacing my entire axles because my tires were making noise. JMHO!
    Now to go mudding with all this rain and snow :D
  19. Mar 1, 2010 at 6:50 AM
    #139
    WeeCujo
    WeeCujo New Member
    Little Rock
    07 Tacoma
    I'm sorry Ridereno, I have to be honest though, I find it hard to believe that you reply to a post that you know nothing about, it doesnt sound like you are having the same problem with the throw out bearing that some people are, or you would offer some helpfull info
  20. Mar 1, 2010 at 9:11 AM
    #140
    ClimberE
    ClimberE New Member
    Eric
    Seattle
    05 4x4 TRD Off-Road
    As someone who had a Throwout Bearing go out and is now have the transmission replaced, I can speak to the fact that there seems to be a link. I took the truck in for a TOB squeel and the shop found a noise in the transmission. They took the tranny apart and found that it was eating itself, they could not determine why. Whether the transmission caused the issue, the TOB caused the issue, or the previous owner railing on the truck caused the issue, no one knows.
    Though my TOB and my clutch were not covered under the power train warranty my transmission was (though since I just bought the truck the car dealership that I bought it from had a warranty and that is covering the work). So they are putting a "reconditioned" transmission in the truck under warranty. I am paying for the clutch work. As of right now, I am $650 out of pocket and have had my truck in the shop longer than I was able to drive it. We'll see if this happens again with the new transmission, if so, Toyota has a serious problem.
