Thud when stopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nightwolf178, May 11, 2013.
  1. May 11, 2013 at 7:11 AM
    Nightwolf178
    Nightwolf178 [OP] New Member
    PreRunner TRD
    After stopping I can hear and feel a thud coming from my back end. Happens 50% of the time. Any suggestions anyone?
  2. May 11, 2013 at 7:17 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    It's axle wrap, try torquing your u-bolts to 75 ft lbs. A lot of trucks have this problem. This is assuming you're stock suspension.
  3. May 11, 2013 at 7:19 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Could be your slip yoke binding. Mine does it too. If thats it, the only thing you can do is take it apart and grease it because it doesn't have any grease fittings. A few guys have taken it apart and had grease fittings installed.
  4. May 11, 2013 at 7:28 AM
    Nightwolf178
    PreRunner TRD
    Yea..its stock. Thanks bud
  5. May 11, 2013 at 8:06 AM
    deepcoma
    deepcoma Well-Known Member
    Land of the rising sun
    2013 TRD Sport DCSB 4X4
    Same going on in mine. I will try tightening my bolts as see what happens.
  6. May 11, 2013 at 5:39 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    2 piece driveshaft
  7. May 11, 2013 at 6:33 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    He has a 2012 I doubt the center bearing is worn that much already, but OP the dealer should take care of you under warranty.
  8. May 11, 2013 at 9:18 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    My previous 2011 Tacoma did it the 2nd day that I got it. It felt like someone had hit me from behind. I got out and checked and nothing. My now 2013 does it too but it takes a lot longer while stopped then my previous Tacoma. I found that it's normal.
  9. May 11, 2013 at 9:23 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Its axle wrap.....tighten the u bolts, and for better prevention look into an aal.....preferably a progressive aal like Icon.
  10. May 11, 2013 at 9:25 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    yep, it's axle wrap... try coming to a stop more gradual. For me a aal and the weight of a canopy cured it.
  11. May 12, 2013 at 4:42 AM
    Nightwolf178
    PreRunner TRD
    Thanks for the info guys. Ill be taking care of it monday.
  12. May 12, 2013 at 5:02 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Here ya go::::
    http://www.tacomaworld.com/forum/1st-gen-tacomas/108316-goodbye-axle-wrap-mod.html
    Bar none, the under leaf application got rid of the axle wrap pronto, I also added the Helwig 550's to the upper rear of the leafs....the 550's raised the rear back to factory or a bit higher...
    Hard to explain, truck rides firmer, but not bouncy, I would say it is as close to 'new' feeling as possible...and it tracks awesome....
    I am running the standard yellow HD Bilsteins, just for reference...
    Side benefits are the no thump when releasing brake pedal after stopping as mentioned...I also siliconed the CB with some small dabs through the access holes, let it dry overnight, now under full throttle no vibrations at all from stop to full bore....awesome fix...
  13. May 15, 2013 at 12:49 PM
    Kawhampshire
    Kawhampshire New Member
    New Hampshire
    08 PreRunner
    Toyota has a TSB to replace the driveshaft for the 2WD models.
    T-SB-0250-12
  14. May 15, 2013 at 2:45 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    I had that thunk after stopping and about to go from a stop. It went away after i did a tranny flush. A coworker has complained about his 2010 doing it since day one and i told him it went away with a flush so he took it to dealer and they did a drain & fill and he hasn't had it happen since. Toyota techs denied that would fix it but the results show for themselves.
  15. May 15, 2013 at 3:37 PM
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    You sure its not the gas in the tank sloshing around? When my tank is mostly full it sloshes forward and feels like a thud.
  16. May 17, 2013 at 7:16 AM
    Nightwolf178
    PreRunner TRD
    There is a corelation between the level of gas and the thud. When the tank is full, the thud is prominant....and when it is empty it does not do it. Toyota replaced the gas tank and it is still doing it.
  17. May 23, 2013 at 10:12 PM
    2011Streaker
    Maine
    2012 DCSB TRD Sport
    Think it's normal noise ...
