Thule xsporter racks on an '08?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mainerinexile, May 10, 2008.
  1. May 10, 2008 at 9:27 PM
    mainerinexile
    mainerinexile [OP] Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    I just bought Thule xsporter 421 racks for an '08 with 6' bed. The racks barely sit on the edge of the bed, and the XK1 clips are almost impossible to line up and tighten in the bed rail. The adjustable rack won't quite go into the lower poisition because the bedliner slopes inward. For a $550 rack, I'm not impressed. Has anyone had better luck with the 421, or a recommendation for a different rack?
  2. May 12, 2008 at 7:12 AM
    mainerinexile
    central Maine
    Has anyone used the Trac rack 25000 on a Tacoma? Comments on it?
  3. May 12, 2008 at 7:37 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I've been interested in racks that attach to the bed rail system since I don't want to do any drilling for the two or three times a year I need them. I'll keep watching this thread in the hopes that someone finds a good (and hopefully reasonably priced) system.
  4. May 12, 2008 at 7:39 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    i must say
    :worthless:
  5. May 13, 2008 at 12:45 PM
    JJPF
    JJPF Member
    Dillingham Alaska
    07 access cab sr5 2.7 5 spd
    I put a Trac Rack on mine. I paid $400 for it. Easy install, easy to remove. Rated for 500 lbs, but a disclaimer about depends on the truck. I primarily wanted mine for hauling a canoe, light lumber. Nice solid feeling, I like it.
    JJPF
  6. May 16, 2008 at 8:43 PM
    mainerinexile
    central Maine
    The Trac Rac 25000 for 05-08 Tacoma's is a nice fit, very rugged rack. $470. DON'T buy the Thule Xsporter with XK1 adaptor for 2nd Gen Tacoma!
  7. May 22, 2008 at 3:53 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I actually just took off the Thule 421 with the adapters. (just got a snugtop shell) The fit was fine.. You do need to play around with it a little. The fronts are no problem up and down. The rears has a little bit of rub when putting it down because I chose to have the bars act as a "lock" for the side compartments. After playing around with the crossbars, there was just the slightest bow (which a thule rep here said was within the thule tolorences..) All in all a very awesome rack. I do have the long bed so if you have short, will not be able to but the racks down due to the tire fender..
  8. May 23, 2008 at 8:55 AM
    mainerinexile
    central Maine
    Glad to hear that you go the Xsporter racks to work. Having tried both racks now, the Trac Rac Pro 25000 is a far superior and more rugged rack. In addition to being easier to install, it sits squarely on the sides of the bed, unlike the xsporter. The xsporter needs a different clamp for the bed rails to make it really work.
  9. Apr 30, 2011 at 8:55 AM
    aljones
    aljones Member
    Aaron
    Houston, TX
    SR5 PreRunner
    Drat! You really don't recommend the Xsporter with the XK1?
    I have a 2000 extended cab with Xsporter and just traded in for the 2011 access cab. I was hoping I could keep the Xsporter and purchase the XK1 adaptors...
    Any other suggestions or do I need to sell the XSporter and get another rack.
