Thumping noise at low revs under load
Discussion in '2nd Gen. Tacomas (2005-2015)' started by schnoutboy, Mar 13, 2017.
  1. Mar 13, 2017 at 5:26 PM
    schnoutboy
    schnoutboy [OP] Member
    2014 V6 4x4 SR5 access cab manual
    Snugtop Rebel shell
    I've driven Toyota trucks for over 30 years and have been very pleased with them. I recently traded in my 1991 extra cab v6 4x4 after almost 26 years of ownership. I traded it for a 2014 Tacoma access cab v6 4x4 with a 6 speed manual transmission about 2 months ago. The truck had about 47k miles when I bought it. It is in very good shape and carfax records showed that the previous owner got the required maintenance done. After a while I noticed that it makes a noticeable thumping noise at low revs (under 2000 rpm) when the engine is under load, like driving uphill. It "sounds" rough, but feels smooth. If I accelerate above 2000 rpm, the thumping noise goes away or is at least very diminished. I can't tell if it's an engine noise, exhaust noise or something else altogether. I've searched here and all over the web and haven't found any definitive answers. Has anyone else experienced something like this? Is it an indication of a minor problem or am I in for some major repairs? I don't know if it matters but I do live at about 6000 feet and drive at elevations varying from about 4000 feet to 9000 feet. Thanks!
  2. Mar 13, 2017 at 5:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the heat shields on the exhaust are not rotted apart and vibrating
  3. Mar 13, 2017 at 5:34 PM
    schnoutboy
    Snugtop Rebel shell
    Thanks Steves104x4, I will check that out.
  4. Mar 13, 2017 at 5:35 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    also check the air box inlet from the fender. the tube vibrates around the hole. some weather stripping or foam will fix it.
  5. Mar 14, 2017 at 11:47 AM
    schnoutboy
    Snugtop Rebel shell
    Thanks desertrunner24, I will look into that too.
  6. Mar 14, 2017 at 12:07 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    you got it. mine had a similar thing and when i replaced my factory intake with a trd one the sound went away
  7. Mar 20, 2017 at 7:41 PM
    schnoutboy
    Snugtop Rebel shell
    Steves104x4, I checked the heat shields and they were all in good shape and firmly attached. I may have my mechanic check in case I missed something when I take it in for the next service. Thanks again.
  8. Mar 20, 2017 at 7:43 PM
    schnoutboy
    Snugtop Rebel shell
    desertrunner24, I checked the air box inlet from the fender and I can see that there's some slop. I may work on it this weekend or just let my mechanic deal with it when I take the truck in for the next service. Thanks again.
    desertrunner24 likes this.
  9. Mar 20, 2017 at 7:52 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    has it had the ping tsb done ?
  10. Mar 21, 2017 at 5:15 PM
    schnoutboy
    Snugtop Rebel shell
    127.0.0.1, I just bought the truck 2 months ago so I don't know if the ping TSB was done or not. Can you point me to information about the TSB? I will look into it, but don't think it applies in my case. I don't hear a pinging. It's more a a thumping or burbling sound. It almost sounds like it has an after market exhaust to make it sound "rougher". But I think the exhaust is stock. Thanks for your reply.
  11. Mar 21, 2017 at 6:25 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    https://www.tacomaworld.com/threads/tsb-list-for-2005-toyota-tacoma.7107/
    T-SB-0044-14- 07 JUL 14 - Spark Knock Noise
    Some 2012 – 2014 model year Tacoma vehicles equipped with 1GR-FE engines may exhibit spark knock (detonation) during light acceleration and/or uphill in hot weather (80 ◦ F or higher). The Engine Control module/ECM (SAE term: Powertrain Control Module/PCM) logic has been modified to reduce the possibility of this condition occurring. Follow the Repair Procedure in this bulletin to improve this condition.
  12. Mar 22, 2017 at 10:28 AM
    baboon
    baboon Active Member
    Long shot, but driving with the windows open? Sometimes you can get a thumping from the air flow patterns in the cab.
  13. Mar 22, 2017 at 12:51 PM
    schnoutboy
    Snugtop Rebel shell
  14. Mar 22, 2017 at 12:52 PM
    schnoutboy
    Snugtop Rebel shell
    baboon, I know the sound you're talking about that's not it. This happens with windows closed. Thanks for your reply!
  15. Mar 22, 2017 at 12:57 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I attach a video camera to the undercarriage when I can't isolate the sound I'm looking for. It's helped me rule out large sections in a short amount of time (like, is this coming from the front or back) and then focus on the smaller spots.
  16. Mar 23, 2017 at 12:30 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    Does it sound anything like this? https://youtu.be/uFJx75kTmEw I'm having a similar noise to what you describe and am trying to figure it out. I will let you know what I find out.
  17. Mar 23, 2017 at 1:03 PM
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    Did the noise change when you switched to neutral? Sort of sounds like it did. Have you checked your motor and transmission mounts?
  18. Mar 23, 2017 at 2:54 PM
    Saskabush
    Adam
    2013 TRD Sport
    I haven't taken a good look at those yet. I'll do that next time I'm under there tho! Thanks
    Edit: Just checked and the mounts seem like they are still in great condition. Must be something else because the engine barely moves when idling under load. The search continues...
  19. Mar 23, 2017 at 4:51 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    https://m.youtube.com/watch?v=Xf6eA5kxe2k&feature=youtu.be
    Sounds similar to the problem I had. Mine was the intake snorkel in the front passenger fender. There is a gasket between the snorkel and fender that gets crushed or damaged.
    Couldn't believe that a vibration issue on the passenger side fender can migrate over to the driver side pedals. Fixed the gasket and haven't heard it since. My symptoms were more evident with a cold engine.
  20. Mar 24, 2017 at 4:13 PM
    schnoutboy
    Snugtop Rebel shell
    Saskabush, the noise is kind of similar. However, I don't hear it at idle. Only only hear it when the engine is under load, lik when I'm driving uphill. Thanks for the sound clip and good luck with your noise!
    Saskabush likes this.
