thunk when brake released
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingmancruiser, Feb 19, 2010.
  1. Feb 19, 2010 at 6:49 AM
    kingmancruiser
    kingmancruiser [OP] New Member
    Prerunner
    '05 PreRunner
    Doesn't happen all the time, but after I've come to a stop, when I take my foot off the brake I hear a thump under my feet.
    Took a mechanic out, and it didn't happen. (Nothing ever happens when a mechanic's in the driver's seat)
    Anyhow, I'd like to go back in to the shop and say that I'd like the U-joints/drive shaft, or something in the brake assembly looked at.
    Has anyone had that problem?
  2. Feb 19, 2010 at 7:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How long have you come to a stop before releasing the brake?
    In other words....If you're stopped sitting at a stop light with brakes on...and then you get the green light, let off the brake...does it still thunk?
    Need more information.... Does it do it when you're on/off the brakes fairly quickly?
  3. Feb 19, 2010 at 7:29 AM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    this happened on my last truck when i would either have to slam on my brakes, come to a quick stop, or what janster said when i would be on/off the brakes quickly. I never figured out why, i would be interested in knowing why it was happening.
  4. Feb 19, 2010 at 7:33 AM
    kingmancruiser
    Prerunner
    Yup. Your first question describes it just right.
    No to your second question.
    I notice it most when I've been driving maybe as far as a mile, then come to a stop (at a light). When I take my foot off the brake (to place it on the accelerator) that's when I feel it. It doesn't seem to come from the engine compartment (motor mounts?) but it feels like it's directly under my feet.
    That's why I thought u-joint.
  5. Feb 19, 2010 at 7:37 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    it's normal.. I can't elaborate but i know somebody else will
  6. Feb 19, 2010 at 11:55 AM
    Janster
    Jandy
    Lancaster, PA
    I'm still confused a bit.... So, you've come to a complete stop. Your foot is still on the brake and remains down fully on the brake for a good 5 minutes - then you take your foot off the brake and it thunks?
    I'm trying to tell the difference whether or not you're experiencing axle wrap - or something else.
    Axle Wrap occurs when you've got your foot on the brake lightly while the truck slows down. You put the brake on harder as you approach a stop sign. The truck stops......but still has momentum. YOu remove your foot off the brake and the momentum thunks forward (so to speak). The thunk is the suspension coming to its RESTING position after the momentum passes (hard to explain).
  7. Feb 19, 2010 at 1:20 PM
    kingmancruiser
    Prerunner
    Thanks, Janster and 619.
    So it's 'normal'.
    I'll take your word on that, and stop bugging the mechanic, but I've had 4WD trucks for close to 30 years, and never had that kind of sound.
    This is the first 2WD I've had and I'm not likin' it.
    Good truck, but strange thunks in the night being normal. . . .?
    Thanks again, folks.
  8. Feb 19, 2010 at 1:25 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Yep, alot of our Taco's do it.. There was a vid around here somewhere show how loose the cv shaft was closest to the diff. My dads 07 does it also. Ohh you have a Prerunner, well then im not sure. Maybe in the drivshaft?
  9. Feb 19, 2010 at 1:27 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    ^^ X2 on Axle wrap.
  10. Feb 19, 2010 at 1:32 PM
    timmaayyy
    timmaayyy Well-Known Member
    Tim
    Raleigh, NC
    '16 TRD Sport DC
    mine does the same thing. i can sit at a light for 20 seconds or 2 min, when i let off the brake i get the thunk...'06 2wd.
  11. Feb 19, 2010 at 2:33 PM
    kingmancruiser
    Prerunner
    Thanks all. Talked to my mechanic. He explained it in detail, about how there's pressure on the gear inside the axle shaft when it engages other gears in there. Maybe not a good description of what he said, but I understand it. I'm not going to beat a dead horse, just don't understand why I've never felt it on any other truck, (4WD), 3 Dakotas, '83 Nissan and '02 Tacoma - all 4WDs.
    Now I'm gonna see how this sucker will hold up going through some washes near Yuma where I've taken my 4WDs in the past. Might be interesting. My son-in-law, (Grand Cherokee) says the only difference between driving a 4WD and mine (locking diff) is that I gotta go faster. That's not my style, but we'll see.
    Thanks again.
