Tick from first gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justin723, Oct 13, 2009.
  1. Oct 13, 2009 at 7:25 PM
    Justin723
    Justin723 [OP] Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    Does the first gens have the same ticking problem as the second gen engines?
  2. Oct 13, 2009 at 7:47 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    They shouldn't.
  3. Oct 13, 2009 at 7:50 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    the "ticking" you hear may be the charcoal canister..mine does it just loud enough to hear it while at an idle
  4. Oct 13, 2009 at 7:58 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Mine gets louder as it idles higher. im thinking from the valves just not 100% where to start. i would imagine something might need replaced i mean the truck does have 165k miles on it
  5. Oct 13, 2009 at 8:02 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had over 160K on my rig before I sold it and it still ran like a champ, no ticking, no oil leaks, nothing.
  6. Oct 13, 2009 at 8:02 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well then get on a valve adjustment
  7. Oct 13, 2009 at 8:12 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    it doesnt leak oil it and it runs great. Valve adjustment? with hydraulic lifters, didnt know you could do that.
  8. Oct 13, 2009 at 8:19 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    not sure, never had the 3.4 apart
  9. Oct 13, 2009 at 8:22 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Me either lol. hmmm idk what to do. You think it would be expensive to redue the top end? or atleast just the valves
  10. Oct 13, 2009 at 8:29 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    find out whats ticking first..Maybe its the timing chain ticking, meaning its due for a replacement.
    Unless they have belts..I dunno, im tired and cant think right now:rolleyes:
  11. Oct 13, 2009 at 8:33 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    I didnt even think about that. what is it every 90k miles it should be replaced?
  12. Oct 13, 2009 at 8:55 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    the 3.4 has a belt.
    the 90k thing is preventative maint. if it snaps while you're driving the only problem is that you're not going anywhere til you get a new belt (non interference design means that valves wont bend or whatever)
  13. Oct 13, 2009 at 8:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    V6 has a belt and should have been changed out at 90K, 4 bangers have a chain.
  14. Oct 13, 2009 at 8:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They are not hydrolic. Its a shim under bucket valve train
  15. Oct 14, 2009 at 9:05 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Oh ok. So possibly the lifters then?
  16. Oct 14, 2009 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lifters, fuel injectors, etc. Its a noisey engine.
  17. Oct 14, 2009 at 9:27 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    lol you aint lying. im farely sure its something that needs to be fixed because its gotten louder over the past few months. Im just not to sure where to start or even how to check that stuff
  18. Oct 14, 2009 at 9:32 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Mine's made a sort of "ticking" sound the whole 14 years and 223,000 miles I've owned it. I wouldn't worry about it.
  19. Oct 14, 2009 at 9:36 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    I probably am stressing it. But how loud does yours tick?
  20. Oct 14, 2009 at 9:49 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've noticed my 2.7l ticking here lately too...sounds like it may be the valves or something....the tick will increase with engine speed but then it goes away after a little bit. I've never had the timing belt or chain changed....no one has been able to give me a straight answer at the stealership about what it has in it. idiots.
    Murph
