"Ticking engine".......(one fix)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chris4x4, Jul 7, 2009.
  1. Jul 7, 2009 at 8:26 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    One of the things causing the "Ticking" on the 1GR-FE is the PWM Valve (also know as VSV), located on the drive side of the intake.
    It is held onto the intake assembly with 1 10mm bolt. The Ticking is amplified by the plastic assembly, but it can be quieted down by installing some rubber washers inbetween the Valve, and the mount on the intake. I used (4) 1/16" thick rubber washers purchased at Ace Hardware.
    Useing 2 inbetween the bolt head, and the valve, and 2 between the valve and the intake.
    Very easy to do. First, remove the 10mm bolt:
    Then install the washers, and re attach the Valve. :)
  2. Jul 7, 2009 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Soorry about my arm being in the way :(
  3. Jul 7, 2009 at 8:28 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  4. Jul 7, 2009 at 8:28 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    you should be, buddy!
    shtmouth81 and qjwright like this.
  5. Jul 7, 2009 at 8:29 AM
    Jester243
    Dan
    Spokane, WA
    Just have Molly hold the camera higher.
    Brian007Taco likes this.
  6. Jul 7, 2009 at 8:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    Great work Chris, as usual.
    What exactly is the VSV and it's function?
  7. Jul 7, 2009 at 8:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....The VSV, Also called Evap Valve, is used to purge fuel vapors from the system and into the charcaol canister.
    yotaTom likes this.
  8. Jul 7, 2009 at 8:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    Found this from the Tundy FSM for the 1GR. Interesting that it is only used for the Idle Air Control Valve state.
  9. Jul 7, 2009 at 8:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was just happy she held it still. :D
    ramonortiz55 likes this.
  10. Jul 7, 2009 at 8:53 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Doing this tonight...thanks!
  11. Jul 7, 2009 at 9:04 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    x2, i will do that when i get home. + rep for Chris
    Hotrodroxie likes this.
  12. Jul 7, 2009 at 9:08 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I seem to always have the mp3 cds jamming in the truck. what tick? :)
    mattillakk and 10trdtaco like this.
  13. Jul 7, 2009 at 9:10 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    can you really tell the difference from before and after?
  14. Jul 7, 2009 at 9:13 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Nice write up as usual, I didnt see the first aid kit or the fire extinguisher in the frame.
    Hotrodroxie and DeathTruck like this.
  15. Jul 7, 2009 at 10:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It makes a little difference in that the ticking from that part is now isollated. You will still have ticking from the injectors and valvetrain.
    I edit those out....as well as the blood and screams...:D
    Sfcmcmahon and DeathTruck like this.
  16. Jul 7, 2009 at 11:59 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    nicely done on the writeup and video.
    DeathTruck likes this.
  17. Jul 7, 2009 at 6:15 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Another great tutorial Chris...:D Keep 'em coming. Great job!
  18. Jul 7, 2009 at 6:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    I have had this done for quite some time and notice very little difference.
    Good write up and video thanks Chris, on under par as usual. (Under par is in good job.Eagle, Birdy,hole in 1)
    Big Brutus likes this.
  19. Jul 7, 2009 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks, Luk. I noticed a little bit, but the Toyota engines are noisy in their design, so its hard to separate all the sounds.
  20. Jul 7, 2009 at 7:04 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Nice writeup, Chris, as usual! :thumbsup:
