"Ticking engine".......(one fix)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chris4x4, Jul 7, 2009.
  1. Feb 7, 2012 at 6:32 PM
    #201
    beckettisgod
    beckettisgod Well-Known Member
    Vermont
    '09 TRD Sport Barcelona Red
    Fog light anytime mod, Black lower valence, In-channel AVS Ventvisors, drop-in K&N filter so far...
    Tried this out and as far as I can tell it worked. I can still hear injectors but at least some of the noises are gone! Thanks Chris!
  2. Feb 7, 2012 at 6:48 PM
    #202
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Feb 9, 2012 at 1:16 AM
    #203
    Jayzekiel
    Jayzekiel Active Member
    Colorado
    08 Tacoma
    aries bull bar, truxedo low pro, k&n cold air
    Did this today as well. I see a difference.
    Thanks Chris!
  4. Feb 9, 2012 at 7:35 AM
    #204
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know!
  5. Apr 24, 2012 at 5:59 PM
    #205
    stocksport
    stocksport Well-Known Member
    Orlando, FL
    White 2011 TRD Sport DC 4x4
    Blacked out emblems, Weathertech liners, LED interior, tag, and 3rd brake light, reverse light mod, rear TSB, rear diff. breather, added black factory running boards, OR tow hook, and rhino lined UWS low profile box.
    Just knocked this out. Did it literally in the parking lot at Ace. I took the bolt in so I could get the washers that fit the best. I "think" it is quieter now. Either way, it cost $1 and about 5 minutes of my time. Well worth it.
  6. May 5, 2012 at 7:59 AM
    #206
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive thought about that too. Seems the fix all depends on if the ticking is generated by the VSV, as opposed to other things. Some folks notice a difference, while others dont. Let us know how it turns out on your truck.
  7. May 22, 2012 at 7:39 AM
    #207
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    Ended up going to Taylors and bought (4) of these washers. Bought it 2 sizes too large the first time. Checked the bolt size after removing the 10mm, and it needs a washer to fit a 6mm.
  8. Feb 20, 2013 at 7:45 PM
    #208
    ovrebo1
    ovrebo1 Well-Known Member
    You could of just went to ACE too
  9. Mar 9, 2013 at 12:14 AM
    #209
    riceandpho
    riceandpho Member
    cant you stick some dynamat on the part itself front and back? double layers to make it more quiet right? it works on my doors.
  10. Mar 9, 2013 at 1:18 AM
    #210
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  11. May 10, 2013 at 9:07 AM
    #211
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    If you say so wise one :)
  12. May 10, 2013 at 10:27 AM
    #212
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    Great work Chris! :thumbsup: I need to try this out on my other tick i have to quiet down. :D
    This seem to work for the valve ticking but in my case i always fill at Chevron with 91 now, i use to use 87 but once i change to 91 the valve ticking went away but still have the other tick that could be the some as Chris has pointed out here.
  13. Jul 1, 2013 at 6:40 AM
    #213
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  14. Jul 1, 2013 at 12:00 PM
    #214
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    This is on the short list for mods to get done this summer!
  15. Jul 8, 2013 at 9:01 PM
    #215
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Seeing how mine has done this since the day I drove it off the lot I am going to have to do this mod. I even went as far as to refuse to take delivery of the truck until they pulled the vc's off and showed me no damage inside.
  16. Jul 8, 2013 at 9:13 PM
    #216
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    well just went out and unbolted it and pulled it to the side and no difference in sound. Got my handy dandy stethoscope out and I do believe I have injector rattle. So anyone have any experience with aftermarket injectors?
  17. Jul 13, 2013 at 6:25 AM
    #217
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    So I've done the washer in between the one in the second picture but I'm not sure where the other one goes.. Can someone enlighten me on its location?
  18. Aug 1, 2013 at 6:52 PM
    #218
    zfox44
    zfox44 Well-Known Member
    Kennesaw, GA
    2010 Sport BSP DCLB
    Thanks, Chris. This took about 50% of my tick away. I barely hear ticking when in the driver seat with the window open. Outside the truck is a different story. I suspect the remaining ticking is from injectors.
  19. Aug 1, 2013 at 7:28 PM
    #219
    YOTA LOVER
    NH
    The noisy injectors are Toyotas way of letting you know the 4.0 is a HP beast and cannot be contained!
  20. Nov 8, 2013 at 3:05 PM
    #220
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    anyone have any updated pics of this?
