"Ticking engine".......(one fix)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chris4x4, Jul 7, 2009.
  1. Mar 2, 2016 at 11:52 AM
    #241
    jesse2035
    jesse2035 Well-Known Member
    Texas
    2016 Tacoma 4x4 Double Cab
  2. Mar 2, 2016 at 6:44 PM
    #242
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Go to Home Depot, you'll find them there.
    Don't expect to much from this mod though.
  3. Oct 7, 2016 at 12:25 PM
    #243
    geotechkid
    geotechkid Member
    Riverside, CA
    2009 Tacoma Double Cab TRD Off-Road
  4. Oct 7, 2016 at 2:24 PM
    #244
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a YouTube video.....
  5. Oct 22, 2016 at 4:32 PM
    #245
    Derrick1030
    Derrick1030 Well-Known Member
    Derrick
    TRD PreRunner Off-road SR5 Acc cab
    All stock accept for fabric on door panel was swapped out
    That tick!!! Ugh
  6. Dec 3, 2016 at 7:35 AM
    #246
    Munson01
    Munson01 Well-Known Member
    Cypress, TX
    2014 Silver Tacoma 4x4
    None yet
    Run premium gas about every third tank...should go away. When I have the tank in the truck, there is absolutely no ticking. It slowly starts to come back each tank after till I fill it back up with the good stuff
  7. Dec 3, 2016 at 7:39 AM
    #247
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
    Agreed I had the same thing I only run chevron 89 or 92 runs great sounds great everyone has their opinions on gas grades but I can for sure tell a difference when I changed to better gas. It also gives it a little more get up and go as well. that's my 2 cents.
  8. Dec 3, 2016 at 8:04 AM
    #248
    Munson01
    Cypress, TX
    None yet
    And I notice I can get about 20-30 miles more out of the premium tank with fuel efficiency. So you get a little more than a gallons worth for free. Figure that in when you get sticker shock from the premium gas. I track mileage on every tank. An old habit I had from my diesel days with a broken gas gauge. I reset the A odometer at every fill up, and refill to the same level every time. It makes tracking mileage pretty easy
  9. Dec 3, 2016 at 9:05 AM
    #249
    Caprizzy
    David
    Lake Stevens,WA
    GO HAWKS!!
    Ha ha to funny I have the same habit, my first vehicle was a 78 f150 with a broken gas gauge as well. I reset mine every time as well and keep tack I swear by top tier high octane gas I do notice better gas millage, smoother idol, better starting and more power.
  10. Jan 26, 2017 at 11:23 AM
    #250
    bwatty
    bwatty New Member
    Brian
    2005 Double Cab TRD
    Stock (for now)
    The ticking dosent bother me too much. Is it a problem or will it cause a problem?
  11. Feb 1, 2017 at 8:52 AM
    #251
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    I always thought this was a normal thing. :notsure: I've been doing this since I first learned to drive.
    It seems to be pretty normal. That's what others have told me.
    https://www.tacomaworld.com/threads/4l-v6-engine-ticking.473099/#post-14296182
  12. Apr 7, 2017 at 2:58 PM
    #252
    47driver
    47driver Well-Known Member
    Brandon, MS
    This helped some but did not fix completely. Will try the gas next.
  13. May 7, 2017 at 8:05 AM
    #253
    ccasteel
    ccasteel New Member
    Conor
    Sacramento, CA
    '11 DCSB MGM Tacoma TRD
    Will try this today, thanks!
  14. May 9, 2017 at 7:57 AM
    #254
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
  15. Feb 6, 2018 at 5:57 AM
    #255
    MAX TACO
    MAX TACO Member
    2011 4x4 4 door silver
    k&k intake banks stainless ex. and muffler
    NO RUSSIAN..................COM-RAD
  16. May 15, 2018 at 9:07 AM
    #256
    kfraserkelowna
    kfraserkelowna Member
    I had a terrible loud tick on my 2006 Sr5. I tried everything I could find online to fix it. I would have a loud tick anytime the clutch pedal was not depressed. I thought it was transmission resonance and decided to ignore it.
    Last week my serpentine belt snapped. The truck quit and it was perfect timing as I was just rolling into my driveway. Anyhow, the lower idler pulley was sized. I replaced it along with the other 2 upper pulleys for good measure. Slapped the belt back on, started her up and .... no more tick.
    MarMarSux and 4x4Taco09 like this.
  17. Jul 24, 2018 at 2:22 PM
    #257
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Did you end up using these and if so were there any issues with heat from the engine?
  18. Jul 25, 2018 at 5:57 AM
    #258
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    195k miles and no issue with the ticking
  19. Oct 6, 2018 at 1:13 PM
    #259
    Shhhammy
    Shhhammy Keep On Truckin
    Sam
    Riverside, CA
    2006 Red Tacoma TRD Sport SR5
    So did anyone actually figure out how to COMPLETELY stop the ticking?
  20. Oct 6, 2018 at 1:24 PM
    #260
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Only thing I’ve found.
