"Ticking engine".......(one fix)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chris4x4, Jul 7, 2009.
  1. Dec 2, 2009 at 10:50 AM
    #141
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Nice write up. This problem can also be fixed by installing a louder exhaust system (louder than clicking noise)
  2. Dec 12, 2009 at 4:58 PM
    #142
    LFH
    LFH Active Member
    Spring, Texas
    2001 Tacoma 4x4
    I haven't a clue, so will say none.
    Rubber washers, like maybe in the end of a garden hose?
    Have any of the bolts backed out from not snugging them down? What about some blue locktite on the loose snuggings?
  3. Dec 12, 2009 at 7:14 PM
    #143
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Washers from a garden hose are too large. Bolts are still snug.
  4. Dec 12, 2009 at 8:05 PM
    #144
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    a M8 vibration isolation bumper would be the best way..but mine hasnt worked loose yet either.
  5. Jan 1, 2010 at 11:25 PM
    #145
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    I need to do this!
  6. Jan 2, 2010 at 7:08 AM
    #146
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    We can do it when you get your Fog lights. Pick up the rubber things at an Ace. :)
  7. Jan 3, 2010 at 2:07 PM
    #147
    alx_alx_69
    alx_alx_69 Well-Known Member
    Alex
    Hope Mills, North Carolina
    Just to be clear, is this the ticking I hear when I have the radio down and I am accelerating???
  8. Jan 10, 2010 at 6:07 AM
    #148
    MINTaco
    MINTaco Active Member
    On a Lake in MN
    08 V6
    DIY Block Heater, Weathertechs, A.R.E. Utility Topper, aFe Pro Dry S
    not sure what "isolation bumpers" are but wouldn't the stock reinforced rubber plumbing washers work just fine? Like was mentioned, you can get them any where and they should be durable enuf. JAT
  9. Jan 10, 2010 at 6:40 AM
    #149
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They might. I havent tried them.
  10. Jan 10, 2010 at 6:37 PM
    #150
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    Hey i was just curious, didnt read thru the whole post. Does this fix work on the 4 banger, i have this annoying noise coming from the engine and dont know what it is figured this could be it>?
  11. Jan 21, 2010 at 12:19 AM
    #151
    superminsoo
    superminsoo Well-Known Member
    Just read all 8 pages... and searched 'ticking'.
    Is this the same ticking that you get from 1750 rpm to 2000 when switching gears according to the manual? 1-8 first to second 9-15 second to third 15-24 third to fourth 25-34 fourth to fifth 35-41 fifth to sixth?
  12. Jan 21, 2010 at 10:34 AM
    #152
    superminsoo
    edit: 1350 to 1500 rpm
  13. Feb 7, 2010 at 5:39 PM
    #153
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    My ticking stopped and it is missing for past month.
    I wonder if me running STP gas additive had anything to do with it.:confused:
  14. Mar 5, 2010 at 12:55 PM
    #154
    2ndTaco1stTRD
    2ndTaco1stTRD New Member
    Andy
    North Carolina
    '10 V6 4x4 TRD Off Road
    Does this affect 2010 TRD Off Road (4x4 V6)? Does anyone have the PDF link?
  15. Apr 6, 2010 at 6:27 PM
    #155
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    I cant believe how well this works. The noice is not gone, but i cant hear it from inside so it might as well be.
  16. Apr 13, 2010 at 12:21 PM
    #156
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    Hey was wondering if you could install an oil catch can here. Says somewhere on the first page that the valve is suppose to force fumes into the charcoal container. I had a catch can on my old nissan and thought it might be a good idea here.
  17. May 25, 2010 at 12:21 PM
    #157
    Irishtoy2008
    Irishtoy2008 New Member
    Jeremiah
    Lees summit MO
    08 SR5 4x4
    bone stock
    yo, whats the hook up and stats on that front bumper and the rally off set on the front end... for lack of better words...
  18. Jun 19, 2010 at 12:58 PM
    #158
    Orion
    Orion Well-Known Member
    Rhode Island
    Tacoma TRD
    never mind...
  19. Jun 28, 2010 at 9:18 AM
    #159
    drwalker65
    drwalker65 Member
    ohio
    2010 dbl cab 4x4
    none yet
    Hey Guys, I think the loud engine noise comes from the exhaust header pipes. If you look there's no shroud blocking or insulating the sound. I wonder if the header pipes are a little thin on the 2nd gen taco's? Anyone replace the headers and get rid of the annoying engine noise?
  20. Jun 28, 2010 at 9:35 AM
    #160
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have done this in the past, but the ticking is still there. A quality header will dampen any noise being emitted by the exhaust though.
