ticking noise 2.7 liter any ideas
Discussion in '1st Gen. Tacomas (1995-2004)' started by rll131, Dec 5, 2011.
  1. Dec 5, 2011 at 8:37 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    2000 2.4 liter 4 banger
    i did a search on here for the ticking noise but it seems it was only for the v6. i have a 1996 2.7 liter with 146k miles. for some reason there is a loud ticking sound when the truck is at idle whenever i push the gas it goes away then comes right back when at idle also if the truck is rolling at anytime and the gas is not pushed it does this the truck is a stick shift so basiically whenever i am not accelerating the truck has this loud ticking sound almost sounds like a bearing or something does not sound like valves to me. any ideas on this. sounds like coming from the front bottom of the engine, possibly by the belts.
  2. Dec 5, 2011 at 8:42 AM
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    When is the last time you had the valves adjusted?
  3. Dec 5, 2011 at 8:44 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    just bought the truck so im not sure if it has ever been done.
  4. Dec 5, 2011 at 8:46 AM
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    Based off your description I would say it is the valves. That's where I would start.
  5. Dec 5, 2011 at 9:03 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    just dropped it off to my mechanic hes going to check it out he also said it sounds like the valves so we will see. if it is should i have them adjusted or just leave it alone one of those if it aint broke done fix it kinda things?
  6. Dec 5, 2011 at 9:14 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Adjusting the valves on the 2/3rz isn't an easy task. It requires replacing the shims.
    The intake clearance is .006 - .010". The exhaust clearance is .010 - .014"
  7. Dec 5, 2011 at 9:31 AM
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    If they are making that kind of racket than the valves need to be adjusted. Adjusting them per the scheduled maintenance is more of a preventative maintenance thing.
  8. Dec 5, 2011 at 10:50 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    just got my truck back he said it is just the valve train and doesnt need to be fixed so hopefully i wotn notice it after the flowmaster is installed :)
  9. Dec 5, 2011 at 11:45 AM
    abn2060
    abn2060 Infidel
    N Florida
    2014 Tacoma OR 4x4
    Stock
    Thats right!!! My Flowmasters drown out all the rattles and weird noises my '91 Mustang makes...:D
  10. Dec 5, 2011 at 12:05 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    somewhere in the manual it says that the engine will make a ticking noise and it is not an issue, ill try to find where it said it.
  11. Dec 5, 2011 at 1:17 PM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    haha yea i cant wait cant stand the ticking..
  12. Dec 5, 2011 at 1:18 PM
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    My sisters 98 always had the ticking from day 1. It is a normal sound for that engine
  13. Dec 5, 2011 at 1:23 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Where do you think they got the phrase "takes a licking and keeps on ticking???" :D
  14. Dec 5, 2011 at 1:27 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    :thumbsup: witty sir, witty
