Ticking noise from fan
Discussion in 'Technical Chat' started by BarkSlayer, Nov 15, 2010.
  1. Nov 15, 2010 at 8:23 AM
    BarkSlayer
    BarkSlayer [OP] Well-Known Member
    Jim
    Northwest Ohio
    Silver SR5 with 2.7 liter 5-speed stick
    Bed-Buddy motorcycle tie-down bar installed in headwall.
    The fan for my heater/AC makes a distinct ticking noise that's making me nuts at lower (vehicle) speeds. Does anyone know if access to the heater fan is an easy thing or does the dash need to come out? The only cure for this sound is to drive fast enough that tire noise eventually drowns it out.
  2. Nov 15, 2010 at 11:27 AM
    BarkSlayer
    Jim
    Northwest Ohio
    Found the fix.
  3. Nov 15, 2010 at 11:37 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Dealer just replaced mine this afternoon free of charge. It's a TSB issue.
  4. Nov 15, 2010 at 11:40 AM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I had that as well - I just adjusted to speed and it went away - what is the problem?
  5. Nov 15, 2010 at 11:40 AM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
  6. Nov 15, 2010 at 11:41 AM
    Spridal
    Spridal Active Member
    Palm Springs, CA
    PreRunner
    What was the fix?
  7. Nov 15, 2010 at 11:43 AM
    JakesTRD
    JakesTRD Well-Known Member
    Jacob
    Newland, NC
    09 Tacoma SR5
    16" Ivan Stewart Wheels, 265/75/16 BFG TA/KO, Grillcraft with TOYOTA emblem, 15% tint all around, 5100's @ .85 with eibach coils, Rear TSB w/ Toytec 1.5" AAL and extended length 5100's, AFE air filter, Fog light mod, AVS in channel rain quards, LineX'ed TRD skid plate, Low profile tool box
  8. Nov 15, 2010 at 11:47 AM
    neoflex
    neoflex Well-Known Member
    My 2010 just started doing this. My simple fix will be driving it into the service dept for them to deal with rather than me having to pull the truck apart.:D
  9. Nov 15, 2010 at 12:47 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    dude, mines been doing this forever. I've never found a fix for it (I haven't really tried). I dont want to take it in simply because if they take the dash apart then something else is probably going to start squeaking. Here is what mine sounds like.
    http://www.youtube.com/watch?v=reidtA0u5Lo
    edit, just saw the fan lives behind the glove box so I guess they don't have to take the dash apart. I was reading other posts saying how the dealership fixed it since it was TSB, but they squeak came back.
  10. Nov 15, 2010 at 4:20 PM
    rondog
    Ronnie
    Escondido/San Diego
    Welp I did this and the ticking is gone. It still squeels like a mouse when I turn the temp from hot to cold and vice-versa. Took about 45 mins to take it apart, clean it, lube it and put it back in. The hardest part was taking the fan blade off. Those things are stuck on there. I ended up using pry bar
