Tie Down Cleats - to Trust, or NOT to Trust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sandie, Mar 12, 2007.
  1. Mar 12, 2007 at 3:42 PM
    sandie
    sandie [OP] Well-Known Member
    long beach, ca
    06 x-runner baby!
    whattya think? Will the cleats that come with the factory bedrails hold a 350+ lb moto in place?
  2. Mar 12, 2007 at 5:01 PM
    ducatista
    ducatista Active Member
    CAPTAIN CRAZY
    DALLAS TX & CLARKSDALE, MISSISSIPPI "THE CROSSROAD
    TACOMA X-SP
    EVERYTHING THAT I CAN AFFORD ! ESPECIALLY IF IT MAKES IT RUN BETTER &/or FASTER, STOP QUICKER AS WELL AS LOOKING GOOD @ THE SAME TIME.
    Listerines,
    I'm wondering the same thing, as I need to haul my Ducati
    too the shop IN THE MORNING. Any experience ? ?
    OWAF
    Andy
  3. Mar 12, 2007 at 5:37 PM
    TacoMan
    TacoMan Active Member
    I believe the cleats are not rated for that much. That being said, if you tie it down right, the load on any one cleat should be dramatically less than that.
  4. Mar 13, 2007 at 8:13 AM
    sandie
    long beach, ca
    06 x-runner baby!
    GAH! there is really not much to tie down to besides the cleats in the front of the bed...holy cow batman, i'm stumped!
  5. Mar 13, 2007 at 8:52 AM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    Use multiple cleats to distribute the weight better that way each one only holds about 100 pounds. I believe they are rated for 200 but I would double check that.
  6. Mar 13, 2007 at 9:04 AM
    ImInLoveWithMyTruck
    ImInLoveWithMyTruck Well-Known Member
    Don't you have 4 tie downs in your bed itself?
  7. Mar 13, 2007 at 9:12 AM
    sandie
    long beach, ca
    06 x-runner baby!
    mine only came with 3 (one in each rail)
    the problem is, i'm transporting 2 bikes...i was going to use the cleat in the rail behind the cab to hold both bikes, and a cleat on each side to hold the other side of each bike...
    hmmmm, now i'm getting nervous
  8. Mar 13, 2007 at 9:41 AM
    TRDeity
    ATX
    2017 TRDpro
    will you be able to use the hooks on the bed in the back? Those attached to frame and are rated for 450 lbs.
  9. Mar 13, 2007 at 11:11 AM
    topdec
    topdec Well-Known Member
    Here's an excerpt from http://www.caranddriver.com/roadtests/8517/toyota-tacoma-double-cab-sr5-4x4-v-6.html
    ...Four tie-down cleats rated for 220 pounds each slide on rails, and D-rings bolted through... the box will take 440 pounds each...
    I fully compress the front suspension when I transport my bike. I would probably load it up "tail-end" first, and make use of the 'D' rings. That's if my wife lets me buy the e-racings race fairing set!!!
  10. Mar 13, 2007 at 12:36 PM
    sandie
    long beach, ca
    06 x-runner baby!
    yeah, i bought it used, and it only had 3 cleats...i have 4 more cleats from the yellow x-runner we built at work for sema 2 years ago, but they're not complete (missing the bolts and springs)...i'm trying to figure a way to rig those in permanently in addition to the ones that slide
    in the meantime, i think i will use the d-rings in back and load back first...good idea topdec and TRDeity! thanks!
  11. Mar 13, 2007 at 2:00 PM
    spp
    spp OC, Kalifornia
    OC California
    Toyota sells D-rings for the front of bed. I put them in and they seem sturdy enough as long as you follow the instructions. Everyones Tacoma should have came with 4 factory tiedowns and 2 rear D-rings.
  12. Mar 13, 2007 at 4:02 PM
    TacoMan
    Each rail is rated for more than the weight of the bike, but you don't want a situation where slamming on the brakes will cause the g-forces of the bike to increase beyond the load limit of the individual tie down or the rail itself. Do as much as you can with the D-rings and distribution of the weight among the tie downs - you'll be fine.
    It is good to know D-rings are available up front. I was disapointed when I saw there were none. My '89 had them in the corners high and low.
  13. Mar 13, 2007 at 4:25 PM
    sandie
    long beach, ca
    06 x-runner baby!
    except for the tacomas that are bought used and the previous owner lost/kept/destroyed one of them :D :p ;)
    hmmmm, just called my toyota parts source and they don't know of any drings for the front of the bed...hmmm, guess i'll have to figure something out myself
    thanks for all the responses! i'll take pics of the bikes in the bed and the solution i come up with!
  14. Mar 13, 2007 at 8:06 PM
    topdec
    Here's what we did to load 2 bikes (SV & R6) on a truck with D-rings on the side...
    1. drilled 2 hooks on a piece of 2x4
    2. placed the 2x4 in the front side of the bed
    3. rolled the front tires of the bikes on the 2x4, to keep it still
    4. hooked the inside of both bikes onto the hooks on the 2x4
    5. hooked the outside of the bikes onto the d-rings
    Travelled 2.5 hours each way with no problems. Oh, we were also pulling an RC-51 loaded on a trailer.
  15. Mar 13, 2007 at 8:51 PM
    HyTrojan
    HyTrojan Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    Just be careful not to overtighten the cleats.
  16. Mar 14, 2007 at 7:41 AM
    spp
    spp OC, Kalifornia
    OC California
    Not a very good parts source then. Just look on the Toyota website under Tacoma Accessories and you will see them. Go to any Toyota parts counter and they will know what you are talking about. Mine had them in stock.
  17. Mar 15, 2007 at 8:32 AM
    sandie
    long beach, ca
    06 x-runner baby!
    could you link me to what you're referring to on the toyota website...i'm still not finding drings for the front of the bed...thanks!
  18. Mar 15, 2007 at 8:46 AM
    spp
    spp OC, Kalifornia
    OC California
    At the bottom of page it says these also available. They nare for the front of the bed since all come with rear D-rings.
    http://www.toyota.com/tacoma/accessories.html
    Just GO to your local dealers parts counter. There are 4 within minutes of you. They are not expensive. Can't remember what I paid but just pocket change compared to your bike.
  19. Mar 15, 2007 at 9:04 AM
    sandie
    long beach, ca
    06 x-runner baby!
    yeah, i'm eyeballing those mini cleats too :D
  20. Mar 15, 2007 at 1:22 PM
    spp
    spp OC, Kalifornia
    OC California
    Mini cleates are great and cleaner looking than the standard ones.
    Also if you really tighten them down, they are much harder to steal.
    06Tacooo likes this.
