Tie Down Cleats - Will it hold a motorcycle
Discussion in 'Towing' started by JFS867, May 28, 2009.
  1. May 28, 2009 at 5:40 AM
    JFS867
    JFS867 [OP] New Member
    Stallings, NC
    09 PreRunner 4cyl.
    I was wondering if the tie down cleats will hold a 450 lb sportbike with out breaking or damaging the rails? I now the weight limit is 400 lbs per cleat so it should hold. Just wondering if anyone has done this and their experience was?
  2. May 28, 2009 at 6:12 AM
    jizzam93
    jizzam93 Well-Known Member
    Kris
    H-Town, TX
    08 DC PreRunner SR5
    YES!!
    I've done it twice on my R6 with no problems at all. However, I decided to get extra D-Rings and used the bed bolts to hold the D-Rings in place. That feels way more secure than the cleat rails. I still use the rails for a little bit of support, but not as the main part of the tie down. HTH. And welcome to TW!!
  3. May 28, 2009 at 6:23 AM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    actually each cleat is only rated at 220lbs each. i believe it says it right on the cleat if you wanna make sure.
  4. May 28, 2009 at 1:10 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    yep...what he said.
    You can also toss a wheel chock in there (like baxleys or harbor freight version). Then all your straps are doing is stabilizing things without having to be pulled so tight and stressing your cleats.
    I would not trust the cleats by themselves, no real reason, just a gut feeling.
    Check out my gallery, I have a few shots of how I haul my VFR.
  5. Nov 15, 2010 at 12:51 PM
    BarkSlayer
    BarkSlayer Well-Known Member
    Jim
    Northwest Ohio
    Silver SR5 with 2.7 liter 5-speed stick
    Bed-Buddy motorcycle tie-down bar installed in headwall.
    It's a good idea to use soft tie extensions on the cleats, wrapping them around the cleat at the rail. That moves the leverage in to the rail and away from the outer edge of the cleats, so there's much less stress on the thin wall aluminum rails that the cleats fasten to.
  6. Nov 15, 2010 at 12:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't trust the cleats. I put D-rings in the front of the bed and use those and the ones already in the rear of the bed to tie in my bike. Those cleats are only rated for like 200# STRAIGHT OUT, not being pulled at an angle. People have tied motorcycles in with using the cleats but I don't trust 'em. http://www.tacomaworld.com/forum/motorcycles/120955-loading-motorcycle-dcsb-pics.html Right, wrong or indifferent, here's I tie mine in.
  7. Nov 16, 2010 at 11:33 AM
    BarkSlayer
    Jim
    Northwest Ohio
  8. Nov 17, 2010 at 10:43 AM
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    they held great from me.. when i moved from orlando to ri i tied my 04 cbr600RR and my old 440 standup jet ski down with the cleats and it held fine.. 1300 miles straight though and no problems what so ever
  9. Sep 25, 2012 at 11:22 AM
    morenoa
    morenoa New Member
    David
    High Desert
    11 Tacoma
    I move a lot of motorcycles in my Tacoma. I would not use the cleats for a big street bike. For dirt bikes I put two cleats in the front each on a different rail (one on the front one on the side rail next to each other to get the corner support.) For the big bikes I took out the front bed bolts with a 17mm Torx and put the bolt back in through a D ring to use as the front hooks. If you don't want to do all that put the bike in backwards close the tail gate and use the rear D rings already in the truck bed. It's not the cleats or railing but the actual bed top railing that can twist upward when transporting a big bike.
