Tie rod replacement
Discussion in 'Technical Chat' started by bigmooze, Dec 29, 2013.
  1. Dec 29, 2013 at 10:34 AM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I had my truck jacked up by the frame to check wheel bearings... they seem fine. However, with the driver side tire in the air, I can feel play in the steering when pulling the front/back of the tire back and forth.
    I can feel knocking in the tie rod, not so much the tie rod end.
    There's not really any play on the passenger side when I repeated this on that side.
    Has anyone replaced their tie rods? Is it difficult? Any nasty surprises I should know about?
  2. Dec 29, 2013 at 10:36 AM
    Large
    Large Red
    Tie rods are fairly easy to replace, only takes a few minutes and both sides are interchangeable with the same part number.
  3. Dec 29, 2013 at 10:38 AM
    Large
    Large Red
  4. Dec 29, 2013 at 10:54 AM
    bigmooze
    Richard
    Belle River, ON
    Thanks! Does anyone know if the approach the same for 2nd-Gen Tacomas as well? Looking at the FSM I got scared, but that video made it look simple.
  5. Dec 29, 2013 at 10:55 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Outers are the easiest thing you can do. Inners are a little more challenging but do able if you have the correct tools.
  6. Dec 29, 2013 at 10:57 AM
    bigmooze
    Richard
    Belle River, ON
    What special tools would I need?
  7. Dec 29, 2013 at 10:58 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i had to get a pipe wrench to remove my inners.
    defiantly wasnt the correct tool.
  8. Dec 29, 2013 at 11:08 AM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Though outers you just need regular hand tools. For the inner there is this tool you would have to rent from the an auto zone or something.
  9. Dec 29, 2013 at 12:10 PM
    bigmooze
    Richard
    Belle River, ON
    OK, Harbor Freight has an inner tie rod removal set. It's not for use on Saginaw type rack and pinions. Does the 2nd gen Tacoma have a Saginaw type rack and pinion?
    Edit: it would appear that these trucks do not have a Saginaw type rack and pinion.
  10. Dec 29, 2013 at 2:05 PM
    bigmooze
    Richard
    Belle River, ON
  11. Dec 29, 2013 at 5:02 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    If the outers are seized you will need a pickle fork or a puller.
  12. Dec 29, 2013 at 5:34 PM
    bigmooze
    Richard
    Belle River, ON
    Thanks, I have a ball joint separator in my toolbox :)
  13. Dec 30, 2013 at 7:01 AM
    bigmooze
    Richard
    Belle River, ON
    Does anyone see an issue with using a tie rod removal tool like that one at Harbor Freight? Like putting too much strain on the rack and pinion as the tie rod is loosened?
    I might be overthinking it. Maybe the double wrench approach is better?
