Tie Rods Squeaking?
Discussion in 'Suspension' started by ComaTosin, Jun 11, 2010.
  1. Jun 11, 2010 at 10:47 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I have some horrible squeaking in the front end of my truck. Strangely it seems to mostly happen on hot days (maybe a coincidence) and primarily when I'm and either parked or going very slow. I have greased the TC UCA but it did not help - I was able to climb under there while my friend turned the wheel back and forth. The ties rods seem to be the source of the noise and I can feel them vibrate when the noise is present.
    I have 36K on the clock and have had it lifted 2.5-3" up front the entire time. Is it time for new TRE or new all pro ties rods? I'm not keen on spending big money on something so - unsexy but if i gotta do it i guess i have got to.This seems early. Also, is there something else i should be mindfull of?
    Any help would be great. Thanks guys.
  2. Jun 11, 2010 at 7:42 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    anyone?
  3. Jun 11, 2010 at 7:46 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    what did you "grease" the UCAs with?
  4. Jun 11, 2010 at 8:00 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I'll have to check exactly what the "grease" was. Just all purpose I believe. Why are we putting "grease" in quotes? I've determined that it's not the UCA though. Thanks man
  5. Jun 11, 2010 at 8:04 PM
    The_Hodge
    SC
    b/c the uniballs can squeak when you turn, if they are dry. try a dry teflon lube on the uniballs. just making sure you didnt put a grease on the uniballs
  6. Jun 11, 2010 at 8:07 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I see. I had considered that it could be the uniballs and was actiually wondering what to lube them with. I'll have to get some teflon lube. Just spray it on there?
    thanks
  7. Jun 11, 2010 at 8:10 PM
    The_Hodge
    SC
    yeah...spray it on top of the uniballs....then drive or just turn them to get it all in there
  8. Jun 11, 2010 at 8:26 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    cool. i'll let you know how it goes.thanks.
  9. Jun 12, 2010 at 3:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does this happen only while turning?
    If yes...it could simply be the tires on the hot pavement. Mine does it all the time.
  10. Jun 12, 2010 at 4:25 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    it mostly happens when hot - it would be awesome if it were only the tires on hot pavement. I'll consider this next time I check. thanks
