Tie rods
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, May 29, 2015.
  1. Sep 9, 2015 at 12:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just curious how a Tie rod can physically connect to a ball joint ??
  2. Sep 9, 2015 at 1:09 AM
    Fallguy6666
    Fallguy6666 Well-Known Member
    Our ball joints come as more of a bolt on plate type.....the lower anyway.they simply bolt in.they have a homebuilt into em to except the tie rod
  3. Sep 9, 2015 at 8:18 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if you already have it then yes, its just this style, if you look at how it works, all the pressure is on the pivot pin of the tool rather then having all the pressure directly pressing on the ball joint bolt. for this reason I don't like the design of that tool and prefer something like I linked or the one that Digiratus posted. in fact I like the one Digiratus has better but I haven't seen one when I looked
    alphabravo[QUOTED] likes this.
  4. Sep 9, 2015 at 9:38 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    What also works is loosening the nut, and leaving it threaded on a bit, and putting the truck back on its tires and wiggling the steering wheel back an forth. The tie rod will usually pop right out.
