Timbrens or WDH
Discussion in 'Towing' started by tractng, Jun 24, 2012.
  1. Jun 24, 2012 at 11:07 PM
    tractng
    tractng [OP] Well-Known Member
    Looking to replace my 2600 lbs dry weight travel trailer with a 4000 lb dry weight.
    I have a 2012 DCSB with towing package.
    Do I buy the WDH and sway or Timbren and a sway? Thanks. Tongue weigh should be around 360lbs (dry weight). I am looking at the 19feet 2008 Mallard Sport travel trailer.
    Thanks,
    tntrac
  2. Jun 28, 2012 at 4:41 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    WDH. Timbrens only make it look better and keep you from hitting the bump stops, but they do not distribute any weight.
  3. Jun 28, 2012 at 7:18 PM
    tractng
    Thank you. Any recommendation for a trailer about 4k dry weight around 22' feet (bumper to tongue).
    Tntrac
  4. Jun 28, 2012 at 11:45 PM
    campthewestcoast
    campthewestcoast Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    Look at HI-LO towlite 22ft. (2001-2010 because you want alumium framing). I'm towing an 06, without any problems. no canvas/hardsided pop-up.They stopped making them in 2010, but nice used ones are out there. I'm using a WDH with 800lb. bars, no sway control needed because it's lowered for towing and I never had an issue with swaying
  5. Jun 29, 2012 at 9:57 AM
    tractng
    Currently, I have the FunFinder x139. Painful to have delamination. Not going with fiberglass again.
  6. Jun 29, 2012 at 11:51 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Definitely WDH. I would use airbags over timbrens for the purpose of towing.
  7. Jun 29, 2012 at 1:42 PM
    tractng
    So I don't need both airbags and wdh? Just wdh with sways?
  8. Jun 29, 2012 at 1:47 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    WDH and sways are just fine. I tow a rather heavy toyhauler with WDH only and it was fine. Just a tip, attach your WDH while the tongue jack is extended. Then lower. Keep doing this until you find the sweet spot on the chaings.
