time chain cover stud doesn't hold threads (socket stripped)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Sep 10, 2015.
  1. Sep 10, 2015 at 8:35 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    One of my two timing chain cover studs won't go back in because the threads in the block are either stripped or the gasket maker got in the hole and prevents gripping (unlikely but i guess possible). As a result, I can't torque the nut on the other end because any attempt causes the stud/bolt to break out of the little grip it has on the other side. It spins in place no matter how much I tighten. The other stud/bolt works fine.
    All the other timing chain cover bolts went in fine and I torqued them to 17 ft/lbs. What are my options here ? Is there any hope that some thread sealant would ensure a better grip ? I am hoping not to have to use Helicoil. I tried running a tap in it but to no avail.
    The arrow in the picture below shows the stud/bolt in question. The picture is old, I have the cover on now. I didn't take them off when I was dismounting the cover but then someone told me I should before putting it back on because it will be easier.
  2. Sep 10, 2015 at 12:18 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I solved a similar problem by tapping hole to next largest bolt size. However, I don't see that you have much material there and you'll have to drill out the cover also. I'm inclined to suggest the Helicoil. If it were not a critical location like this, I might even suggest using red thread locker, but I would do it right for this component.
    Why J likes this.
  3. Sep 10, 2015 at 12:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How long did you wait to install the stud,after installing the timing cover?
  4. Sep 10, 2015 at 12:30 PM
    foampile
    Mid-Atlantic
    a few minutes, IOW right after
  5. Sep 10, 2015 at 1:21 PM
    foampile
    Mid-Atlantic
  6. Sep 10, 2015 at 1:27 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  7. Sep 10, 2015 at 2:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Either way you are going to have to remove the timing cover to do it correctly. If it were me I wouldn't bother with the quickie fixes as the Magic Locktite Thread Maker .... Half Assed Fix if it even works.
    Do it properly : Remove the timing cover and install a Thread Insert or a Helicoil.
    After all the time you have in this engine why half ass it when you are so close?
    Oh and learn how to not strip bolts/nuts/studs.
    DoorDing likes this.
  8. Sep 10, 2015 at 3:03 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    So the stud won't go in, it only catches a couple threads and pulls itself back out?
  9. Sep 10, 2015 at 3:06 PM
    foampile
    Mid-Atlantic
    sort of. it feels like it's going in but towards the end, it just starts an infinite spin never increasing the torque. if i try to tighten the nut over it, it actually starts reversing the stud
  10. Sep 10, 2015 at 3:11 PM
    foampile
    Mid-Atlantic
    One more question: out of a total of 19 fasteners on this cover, only 2 are studs with a nut. What is it that they do that a plain bolt like the rest of the 17 can't do ?
  11. Sep 10, 2015 at 3:15 PM
    Bullfrog 75
    Bullfrog 75 Well-Known Member
    Jeremy
    2002 red prerunner
  12. Sep 10, 2015 at 3:17 PM
    foampile
    Mid-Atlantic
    Yet another question: considering that this is just one of the 19 fasteners of the cover, and that excludes the ones from the water pump, how much leak could I expect if I just left it off ?
  13. Sep 10, 2015 at 3:26 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Try to install a slightly longer stud if possible. You may catch a few good threads if it doesn't bottom out. See if one of the bolts will catch in there.
    foampile[OP] likes this.
  14. Sep 10, 2015 at 3:27 PM
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    Just fix it right. No one can answer your hypothetical what if's
    A helicoil is the correct way to fix this. It is easy to install.
  15. Sep 10, 2015 at 3:27 PM
    foampile
    Mid-Atlantic
    yeah, i was thinking the same thing
  16. Sep 10, 2015 at 4:16 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Or use a bolt. And try applying slight pressure while threading it. It sounds like some fipg is blocking the path.
  17. Sep 10, 2015 at 8:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yeah but then you have to ask yourself how many of the threads are actually holding or are engaged?
    Questionable at best.
  18. Sep 10, 2015 at 8:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    FIPG isn't going to stop a bolt. It is stripped threads in the block.
  19. Sep 10, 2015 at 8:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You're left with seeing if it works without it, or pulling it apart and fixing it with a heli-coil.
  20. Sep 10, 2015 at 8:56 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    It will if air is trapped inside the threads.
