time to bring her down
Discussion in 'Suspension' started by blacksheff405, Apr 24, 2012.
  1. May 23, 2012 at 12:48 PM
    #41
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    alright thanks
  2. May 26, 2012 at 7:13 PM
    #42
    YotaKid62
    YotaKid62 Dirty mall crawler
    Forrest
    North Dakota
    00 Tacoma TRD Sr5 5 speed
    Grey Wire Locker Mod, 3" coil spacers & custom leaf packs, 2" BL, Skyjacker rear nitro shocks, Monroe front gas shocks; 15" eclipse sub & 1400 watt visonik amp with Kenwood stereo, Billet Petals, Black Aries series Grille guard, ebay baja lights (unsure of brand)
    I would say that the best way to improve ride quality is to remove the spacers and make sure your body mounts are tight, the body lift could probably stay until you get your smaller tires since the body lift has no relation whatsoever to your suspension. I don't know why everyone claims they make your ride suck if they don't do anything to your suspension. More swaying on corners, sure, but a crappier ride, i wouldn't think so. I would still take it off once you get new tires though. And if you're short on cash, then check out Doug's (4WD) leaf spring rebuilds, or my build thread since i did them. That might work for you too that way you can put that money towards other stuff (ball joints, shocks, etc.)
  3. May 26, 2012 at 7:27 PM
    #43
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    Here's what I'd do...
    remove body lift
    buy bilstein 5100 front shocks, and replace the crappy stock ones with all the spacers.
    remove extended shackle and add a leaf, and buy extended rear bilstein 5100 shocks (check to make sure they are long enough for your lift.)
    Then you will have stock leafs, and though they are tired, will ride smoother than with the AAL and shackle in there. the new shocks will help a lot too of course.
    then in the front all you have is a regular 6'' lift, with some nice bilstein shocks, you'll have to keep the large fabtech spacer that is on top of the shocks.
    then I'd get the front end checked out by a shop, and replace any needed tie rods, bushings, etc etc.
    then save for a custom rear leaf pack.
    the only cost will be buying 4 bilstein shocks ($350) and any front end work that must be done.
    Also, I'm sure those 38's are an E rated tire... try to find a D when you go to 35's
    thats just me.
  4. May 26, 2012 at 7:32 PM
    #44
    YotaKid62
    Forrest
    North Dakota
  5. May 26, 2012 at 9:28 PM
    #45
    blacksheff405
    caleb
    well I measured some of the stuff and talked it over with my dad and the block that is on the truck isn't the factory block from fabtech it is a 5" block with an add a leaf and the db is a 6" and thats it for the back and I have no clue what the hell is up front.
    but me and my dad thought that for now it would be better to go back to the stock fabtech set up and later when I have more money to then look for bringing up the ride quality.. because that way all i really need to do is buy 2 3" blocks and I could theoretically take it back to the factory fabtech set up.
    am I correct? :confused:
  6. May 26, 2012 at 9:42 PM
    #46
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    the add a leaf will make the ride in the rear harsher, and shitty shocks make the ride suck, also the big tires and the body lift don't help the ride either.
    so yes, take out the add a leaf, take off the body lift, but go here...
    http://www.wheelersoffroad.com/05uptacoadjbils.htm
    you can buy front and rear shocks for $350, that will help the ride a lot!
    edit: you are going to have to get the current shocks taken apart to get the spacer out anyways, might aswell put the money towards new shocks. bilstein 5100 specifically. what about finding some lightly used tires so you can put a few bucks toward shocks?
  7. May 26, 2012 at 9:50 PM
    #47
    blacksheff405
    caleb
    for some reason my dad is dead set against used tires which I understand but he would rather me buy new ones and know that they are new than buy used and not know what they have been put through. and that's what we are trying to mostly figure out right now is what exactly it will take to put it back to just the fabtech lift kit and then I will slowly change it as time goes on.
  8. May 26, 2012 at 9:54 PM
    #48
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    no problem, can you afford tires and $350 for shocks?
  9. May 26, 2012 at 9:57 PM
    #49
    blacksheff405
    caleb
    not really but they are gonna help me out and i'm gonna pay them back as I save some money cause the grand i saved went towards one hell of a first semester of college but had no job. so there was no replacing of funds.
  10. May 26, 2012 at 10:02 PM
    #50
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    ok, well personally I'd get 35's, they will be cheaper than anything bigger, and the biggest you'll want if you plan on getting back to a smaller lift.
    you can also save by going to an all terrain tire over a mud terrain, again that will help with the rough ride.
    I'd start by taking the bodylift off, then you can buy just front bilsteain 5100's to start, and see if you can find some stock coils from someone who has removed theirs...
    post here to see what you can find for free from members..
    http://www.tacomaworld.com/forum/buy-sell-trade/141819-i-want-free-stuff-thread.html
  11. May 26, 2012 at 10:26 PM
    #51
    blacksheff405
    caleb
    thanks man yea as far as tires I have heard great things about the cooper stt's as far as milage and off-road abilities so I am going to give those a try and I think I can get them fairly cheap. and I'll have to troll that forum some:eek: and hopefully all this will help my gas milage some so I'm not spending over 100 bucks of my pay check towards gas.
  12. May 26, 2012 at 10:27 PM
    #52
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yup exactly, is your truck regeared?
    and definitely check out wheelersoffroad.com for the front bilstein shocks.
  13. May 26, 2012 at 10:29 PM
    #53
    blacksheff405
    caleb
    to be honest I have no clue. it doesn't have like a lot of get up and go but it def. can pull my tires pretty well.
    and will do man :thumbsup:
  14. May 26, 2012 at 10:32 PM
    #54
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    hmm, well going to the 35's it will feel fast :p
    from your pics it looks like a looong shackle, are you sure it's the stock one? it also might just look long because of the body lift.
  15. May 26, 2012 at 10:34 PM
    #55
    blacksheff405
    caleb
    they are 6"
  16. Jun 8, 2012 at 10:30 AM
    #56
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    gotten any work done on the truck?
  17. Jun 8, 2012 at 10:06 PM
    #57
    blacksheff405
    caleb
    well I listed it to see if it would sell and i think its going to so if it does i'm going to go that route
  18. Jun 9, 2012 at 8:05 PM
    #58
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    oh wow, then what?
  19. Jun 9, 2012 at 10:33 PM
    #59
    blacksheff405
    caleb
    either buy the tacoma I want this time or go with another vehicle.
