Time to Change Spark Plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by akneppers, Jan 12, 2011.
  1. Jan 12, 2011 at 6:10 PM
    akneppers
    akneppers [OP] New Member
    Virginia
    2016 Toyota Tacoma TRD Sport 4x4
    So I was wondering if it was time to change the spark plugs.
    Cause i bought the truck with 60,000 miles and I'm not sure exactly what was done to it, as far as maintenance.
    Through researching I found that the factory used Denso on the left side and NGK on the right, although the plugs had 2 contacts on it. So I'm not sure if they were original or not.
    I've attached a picture. Thanks
  2. Jan 12, 2011 at 8:42 PM
    747 function > form
    1st Gen.
    iirc, chris4x4 posted somewhere that tacos come from the factory w/diff brand plugs on each side :notsure:.
    i'd replace them.
    [EDIT: I don't mean "i'd replace them" because they're diff brand plugs on each side...but, you've got them out, and it's time.]
  3. Jan 12, 2011 at 9:09 PM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    i replaced my plugs at 102000 miles and yes they come factory with two different brands.
