Time to do maintenance.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Volvoman01, Jun 3, 2014.
  1. Jun 3, 2014 at 7:03 AM
    Volvoman01
    Volvoman01 [OP] New Member
    Today, I'm going to buy spark plugs, air filter, etc, for maintenance. What should I do for best results?
  2. Jun 3, 2014 at 7:13 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
  3. Jun 3, 2014 at 10:41 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    You're fuel filter probably hasn't been done and your MAF and throttle body could use a cleaning. If you're going all out, change all your fluids. (Engine oil, transfer case, both diffs, coolant, ATF fluid)
  4. Jun 3, 2014 at 5:48 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Pcv valve probably also.
  5. Jun 4, 2014 at 2:51 AM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    A power steering flush never hurt either ;)
