Time to replace shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by stuckinmud, Apr 22, 2011.
  1. Apr 22, 2011 at 12:58 PM
    stuckinmud
    stuckinmud [OP] Member
    Neal
    Southern Ohio
    03 Tacoma TRD
    Gray wire mod, Bilstein 5100 shocks / front 5125 shocks / rear
    Hello, I own a 2003 Tacoma TRD, V6, Auto, 4WD. I bought it used some time ago, seems to be in pretty good shape inside and out, very clean. The truck just rolled over 80k and I wish to replace the shocks front and rear, I thought before buying I would hit ya up and ask, any recomendations? It has what seems to be factory Bilsteins on it now.
  2. Apr 22, 2011 at 1:03 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    search?
    bilstein 5100's
  3. Apr 22, 2011 at 5:09 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    x2 possibly most talked about subject on TW
  4. Apr 22, 2011 at 5:31 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    The factory (yellow billies) shocks are awsome. I wouldnt switch brands unless you lift it.
  5. Apr 22, 2011 at 5:33 PM
    98tacoma27
    Ben
    Not Beech Creek
    At 80k they're about shot.
  6. Apr 22, 2011 at 5:54 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Mine were still good at 150k, Compared to brand new Gabriel hydro's at least.
  7. Apr 22, 2011 at 5:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Mine were gone at 75k
  8. Apr 22, 2011 at 6:03 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    My 1999 non TRD V6 4X4 six lug has the original front shocks, springs, and rear leafs........hell I swerve to avoid a shadow. Good luck.(HINT HINT )
  9. Apr 22, 2011 at 7:10 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    you know there is so much talk about this subject. im in the same boat as the op. seems everyone has an opinion on billys / ome's / eibach combos... my question is, does going up about an inch put any added stress to speak of on the cv's? obviously its a bit more angle then the factory intended. any thoughts? because if im going to drop $ on factory oem parts, may as well spend a little bit more and upgrade
  10. Apr 22, 2011 at 8:47 PM
    stuckinmud
    Neal
    Southern Ohio
    03 Tacoma TRD
    Had just planned on leaving it stock, I want to replace shocks,Bilstein 5100's sound good to me from what I've read, is there any big deal replacing them though, was planning on doing it myself....do they come in a pre-set, that way they can be installed and just more or less forgot about.....
  11. Apr 22, 2011 at 11:00 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    What.
    I took mine off at 90k and with out the coils on them they
    took about ten minutes to extend when I compressed them by hand.
    also take off your sway bar. do it.
  12. Apr 23, 2011 at 6:21 AM
    stuckinmud
    Neal
    Southern Ohio
    03 Tacoma TRD
    I saw on the front shocks is like a coil over type deal, when I replace the front set do the Bilstein 5100's come with the new coil spring also or do you re-use that existing spring? Are the Bilstein 5100's a direct replacement for my factory stock shocks, do I have to do any modification's for installation? I just put new tires on all the way around last week, after I install the new shocks do I need to have another front end alignment, I just did that when I purchased new tires...:confused: Also why would I want to remove front sway bar??
  13. Apr 23, 2011 at 9:54 AM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    removing sway bar helps with articulation, and no the billys dont come with a new coil spring. For $150 more you can get some eibachs/toytec springs for a 3inch lift and a freaking awesome ride!:D the billys bolt in to the stock locations so no modding to any mounting hardware. Unfortunately yes you will have to get re-aligned but wait until whatever you get settles otherwise you will have to re-align twice.
  14. Apr 23, 2011 at 12:27 PM
    stuckinmud
    Neal
    Southern Ohio
    03 Tacoma TRD
    Oh ok..thanks :D I think I'll stick with the stock ride height, going to go with the Bilsteins 5100's I guess. The stock springs should be good, so I'll just do the shock replacement. I didn't know you had to get an alignment after just installing new shocks :eek: lol....I don't want to take any chances though cause I just put on 4 new tires and would like em to last..ha ha :) after checking em out on "Down South Motorsports" I think I will just buy the complete set of 4...I guess it would not hurt to lift it 2.5"... if I don't like it I can change it back lol
  15. Apr 23, 2011 at 4:01 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    You don't have to lift it with the billies... they just have an adjustable preload to lift the truck. You can leave it at 0 for stock height
  16. Apr 23, 2011 at 4:14 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    I have no sway bar:cool:
    If its stock i wouldn't recomend removing it. Cornering sucks with no sway bar, if you are turning and braking get ready for the pucker factor. When i put mine back it its like im driving a race car:cool:
  17. Apr 23, 2011 at 4:54 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    If you buy Toyota shocks and have a Toyota dealership install the shocks, they become lifetime replacement/labor.
  18. Apr 23, 2011 at 7:25 PM
    stuckinmud
    Neal
    Southern Ohio
    03 Tacoma TRD
    Ha ha..ok you talked me into it lol, I'll go with the 5100's, not sure what setting I'll be on yet but have time to think about that. I think I'll order the package set up from "Down South Motorsports", I'll keep my stock coil springs, I think I will do it myself and save the money lol I hope I like the way it turns out when I'm done...
  19. Apr 23, 2011 at 11:43 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Pshhh no sway bar makes turning way more fun!!!! :cool:
