timing belt and water pump 495.00
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Aug 7, 2008.
  1. Aug 7, 2008 at 2:47 PM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    Guys I need to know if you thats had this done is this a good price. I have a 2001 v6 crew cab. I want to have the spark plugs changed also so what do you recommend, or just go with whats in the manual. Thanks Rick
    Black97v6MT likes this.
  2. Aug 7, 2008 at 3:30 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Personaly I like to have everything replaced.
    T-belt
    Idler pully / tensioner pully
    Cams seals / Crank Seals
    Water Pump / T-stat
    Betls and Hoses
    Radiator Flush / Block Flush
    Spark Plugs and Wires if they are over 60K
    Then 100% of the Fluids
    This is just me..
  3. Aug 7, 2008 at 3:39 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I threw the book at it at 71,000 miles. For $1660.00, I had the following done at my dealer
    timing belt and drive belt
    water pump
    cam/crank seals
    tensioner/idler pulleys
    fan belts
    oil change
    radiator flush
    fuel injection flush
    .......and the usual 75,000 mile service. OH YEAH, she's happy:D
  4. Apr 27, 2025 at 2:05 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    So what do you think all that maintenance might run you now 17 years later?
    Curious a bit about it is all
    Ridgerunner[QUOTED] and Moonrman like this.
  5. Apr 27, 2025 at 5:34 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    $2465.67 that's the conversion for inflation. But I think it would cost more. He was in Rocklin, CA.
    Ridgerunner and Black97v6MT like this.
  6. Apr 27, 2025 at 5:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Moonrman and Black97v6MT like this.
  7. Apr 27, 2025 at 7:34 PM
    Black97v6MT
    iMA0
    tacoLand USA
    He was seen just this past Friday :confused:
  8. Apr 28, 2025 at 6:05 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Zombies......
    boy its got to be really bad......when you love that truck so much
    ......you wont move on to the light
    Moonrman likes this.
  9. May 3, 2025 at 4:14 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Not at the time I had these done, I was in San Francisco. I am planning on doing these again at 160,000. I'm at about 156,000 now. So maybe next year. She is till very much alive, looking and running perfectly. I am still alive.
    Black97v6MT and Moonrman[QUOTED] like this.
  10. May 3, 2025 at 7:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    At least 2,000$
    Back then you mentioned a 75,000 mile service. Hard to tell what a mileage/maint package would cost at 160k miles. Might need a little, might need a lot
