timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Aug 19, 2010.
  1. Aug 19, 2010 at 12:59 AM
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    Lakewood, CA
    04 Double Cab PreRunner SR5 TRD
    Ok, so my timing belt is due soon. Went to my normal mech. and i told him that i wanted to change the timing belt followed up with some new spark plugs. He told me since were in there changing the timing belt to get a new water pump, thermostat, and someother crap that i forgot because i was spacing out on the price he told me ($600-700).
    My question is, is that a normal price and/or do i really need to change all those extra parts out?
  2. Aug 19, 2010 at 2:31 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    That seems about like a normal price, if not a bit on the low side.
    Some other expenses that might pop up include the tensioner, pulleys, belts, and hoses. If all those need to be replaced, you could be in it another $100-200 if he didn't include those in the price (complete guess - might be more).
    As far as if you should replace the water pump and thermostat at the same time, it isn't 100% necessary but your mechanic is right that you really should.
    The water pump does have a tendency to start leaking about the same time the timing belt is due to be changed. Since the water pump is right there under the timing belt and most of the work is labor, everyone changes the water pump at the same time, as it'll cost you another $400-500 if it fails later. Its not worth saving the $50-100 on the water pump when its only a few bolts to remove it at that point. Think of it as you're replacing the timing belt and getting free labor on the water pump. I had the mechanic do the belts and hoses at the same time just to save on having to do them later as well.
  3. Aug 19, 2010 at 7:04 AM
    travis9287
    travis9287 Well-Known Member
    Travis
    Tuscaloosa,AL
    2003 Tacoma, 2006 GX470, 2000 Jeep TJ, 1985 C10
    a lot lol
    sounds right. i did mine myself and it cost that much, so if he is including labor then thats a pretty good price.
  4. Aug 19, 2010 at 7:43 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    What's he charging for the spark plugs? Save some money and do them yourself
  5. Aug 19, 2010 at 7:48 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's not bad....considering the amount of work is involved.
    If you haven't had your water pump changed, it's a good time to get it done plus the thermostat and all your accessory belts too.
    My water pump leaked for over a year (on my 96) and I finally changed it myself at 85K miles. They don't last forever. Cheaper to have them do it now than have to pay them another $600 to do it again when it does leak.
  6. Aug 19, 2010 at 2:02 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Yup that sounds about right, the same price was quoted for my 2003 Taco but no sparks plugs.
  7. Aug 19, 2010 at 2:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    FYI, I paid 163.93 for the t belt, water pump, and t stat at my local NAPA auto parts and did it with my dad in a day. It was terrible but worth saving the money IMO.
  8. Aug 19, 2010 at 2:50 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Hell yeah I would do it myself luckily mine was done right before I bought my truck.
    I say but a Haynes Tacoma manual and go to Napa but the parts and do it yourself.
    Shit you might even find some guys here that would do it for half the money i know I would if you were near me.
  9. Aug 19, 2010 at 2:50 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    I thought about doing it myself, but I chickened out. Thats just a bit more than I feel comfortable doing by myself.
  10. Aug 19, 2010 at 3:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    fair enough. The hardest part is breaking all the bolts loose. I think we broke 2 chinese breaker bars and a craftsman socket driver before it was all said and done lol.
  11. Aug 19, 2010 at 3:12 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the timing belt and water pump arent too bad of a job....mostly just time consuming. and its a good idea to change the seals while you are in there...especially if you see any signs of leaking.
    to the op....that aint a bad price. i got the tb kit from ebay(reputable ebayer) and did it on a sunday...then me and tigerfan did his on a friday evening. hardest part....prolly breaking the crank pulley bolt loose. i used a breaker bar and socket..set against frame, and bumped starter over. worked easily both times for me.
  12. Aug 24, 2010 at 8:45 PM
    gman88
    gman88 Active Member
    Gary
    Pittsburgh
    I just purchased an 03 double cab TRD with 42K. At what point should I consider the age vs. mileage for the timing belt/water pump work? My guess is that I should be OK for awhile? thanks.
  13. Aug 24, 2010 at 8:48 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    That's a pretty reasonable price and yes it's a good idea to change those other parts. The other thing he was talking about was probably the pulleys.
  14. Aug 24, 2010 at 8:58 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    The recommended service on the timing belt is 90k or 72 months (6 years), so if you go by months, you'd be past due. There are a lot of factors that go into how fast rubber will break down, but I think it'd probably a good idea to get it changed just so you're doing it on your terms and not when your going down the highway at 60mph.
    Knowing me, I probably still wouldn't put a rush on it, but still something I'd plan on getting done within the next little bit.
  15. Aug 24, 2010 at 9:02 PM
    96er
    96er Sport Rally'er
    MA
    Yeah but it is a non interference engine so if you don't want to do it the worst case is that you'll need a tow (your engine will not blow up is what I mean).
  16. Aug 25, 2010 at 7:19 AM
    gman88
    Gary
    Pittsburgh
    Thanks. Good to know I won't mess up the engine. I'll plan for Spring replacement.
