timing belt ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CaliKimba, May 10, 2013.
  1. May 10, 2013 at 11:44 AM
    CaliKimba
    CaliKimba [OP] New Member
    Kim
    Citrus Heights
    99 SR5 Green Badges
    Ok new here anyways I have a 99 SR5 and need to replace the timing belt. I know it's always recommended to go with toyota parts but as a cash strapped college student that's not always the easiest route. There are kits to replace the timing belt and water pump at autozone for 260 or there is this http://www.ebay.com/itm/TOYOTA-Timi...271&pid=100011&prg=1005&rk=5&sd=270865241552& . So I'm wondering if I should go the ebay route. Any ideas? Plus I'm somewhat mechanical (4 years helo mechanic) so I think I can tackle this project on my own. Figured it would cost a ridiculous amount to have a shop in Sacramento change it anyways.
  2. May 10, 2013 at 6:56 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    realistically, you should do at least the autozone route. Most mechanics like Midas, Firestone, etc use generic parts & are cheaper routes. If you're particular like myself, you should prob go to a toyota specific shop with a great review section on yelp in your area.
  3. May 10, 2013 at 6:57 PM
    Blindsider
    Blindsider Well-Known Member
    Craig
    Upstate NY
    18 DCLB TRD OR
  4. May 11, 2013 at 9:47 AM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
  5. May 12, 2013 at 10:59 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
  6. May 13, 2013 at 11:34 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    ^Holy hell are you a Toyota tech? Serious question. Anyways man thank you so much this is awesome!
  7. May 13, 2013 at 6:44 PM
    SafetyDang
    Dang
    Anaheim, CA
    During this video I was just a guy who knew a little here and there. I am currently going to a T-ten school. (Toyota sponsored). I'm going to try to make more videos when I get some free time.
  8. May 13, 2013 at 7:31 PM
    BamaToy1997
    Bill
    Navarre, FL
    Good video, however I would point out that you should never use a torque wrench to loosen any bolt or nut. While they can be used that way, it is not the correct way, and can cause damage and inaccuracies in the torque wrench.
  9. May 13, 2013 at 8:22 PM
    SafetyDang
    Dang
    Anaheim, CA
    Yep learned that in class. I am no expert, just a guy trying to help visual learners.
  10. May 14, 2013 at 11:10 AM
    CaliKimba
    Kim
    Citrus Heights
    99 SR5 Green Badges
    awesome thanks guys. I think I'll attempt this project in a couple weeks once my classes are done for the semester.
  11. Oct 15, 2013 at 7:47 PM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Fantastic bit of info there SafetyDang. Subbed on YouTube. Keep it up!
  12. Oct 15, 2013 at 10:08 PM
    Jwoody
    Jwoody Member
    Justin
    Mesa, AZ
    2000 trd tacoma
    Great video ! Thanks this is my next project on my truck. Not to hijack but Has anyone had any problems going with a aftermarket timing kit? I usually go oem but didn't know if anyone had issues with aftermarket.
  13. Oct 16, 2013 at 1:37 AM
    SafetyDang
    Dang
    Anaheim, CA
    thanks medicmutt.
  14. Oct 16, 2013 at 9:08 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    timing belt is just as easy on these as anything else IMO. but then agian ive dont alot. its alot about being very percise and double or tripple checking your work.
