timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vater1775, Jan 5, 2010.
  1. Jan 5, 2010 at 10:06 PM
    vater1775
    vater1775 [OP] Member
    charlotte
    04 tacoma dbl cab all black sr5, trd
    none yet...need advice
    Ok, Im at 122 K on my 04 Taco 3.4 L V 6. I know the the timing belt needs replaced along w/ the water pump. Dealer wants to do it for 600..good price or not? also, I really do not have the funds to do it immediately but im working on it so my question to you is...are there any signs that I should be looking for in the mean time that should let me know to get the thing in there now or can I wait another 5 to 10 K miles before getting it in there.
    thanks
    Rob
  2. Jan 5, 2010 at 10:17 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Dude I just went in today and they said they wanted $900 for timing belt and water pump :/
  3. Jan 5, 2010 at 10:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The only sign I know of is when the timing breaks and you're stuck on the side of the road.
  4. Jan 5, 2010 at 10:39 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you may be able to see some staining around the water pump if its leaking (which it probably is) but past that...like humanoid said...you'll know it NEEDS it when it breaks
    otherwise it should be done at the 90K service interval if im not mistaken
  5. Jan 5, 2010 at 10:42 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    $600 is pretty damn cheap. I'd call them and verify the price - make sure they quoted you everything (TB, WP).
    I'd also recommend changing the thermostat and all your accessory belts too.
    My husband and I changed the water pump on my 96...wasn't too bad of a job. http://www.lieblweb.com/waterpump.html
    With timing belts...you don't know WHEN they could break. Those types of belts don't usually show any type of external visual signs of disrepair. At work (on machinery), I've seen similar belts break and they still look new. While, I've also seen dried out & cracked belts continue to function. It's like rolling the dice....
  6. Jan 5, 2010 at 10:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Just curious... do any seals need to be changed while doing the TB or water pump?
  7. Jan 5, 2010 at 11:48 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Yes, make sure they change both cam seals and the crank seal even if it shows no sign of leakage. If you don't change them and they leak after the timing belt work is done, goes what you'll have to pay double labor for them to tear down to get to the seals.
    Where I work, we do timing belt jobs COMPLETE, so we don't have to do anything twice. What we do(all parts are OE Toyota):
    -Timing belt
    -Timing belt hydraulic tensioner
    -Idler pulleys (for timing belt)
    -Water pump and flush cooling system
    -Thermostat and gasket
    -Radiator hoses (if they are old)
    -Cam seals and crank seal
    -External drive belts (if they're no good or old since there is no addt'l labor)
  8. Jan 6, 2010 at 5:53 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I did 143k before I changed mine out. :eek:
    Didn't have extra cash lying around then so I didn't replace the water pump, now it is leaking and I know what I am doing this spring. If you are mechanically inclined and have a place to work and tools, you can do the whole thing your self for a lot less. Afford yourself two days to work on it and you should be just fine. (it is only about a 4-6 hr job, but being your first one and the ability for problems to occur I would allot two days for this job.)
    Auto hobby shop comes to mind. :D
  9. Jan 6, 2010 at 6:08 AM
    maddog61
    maddog61 Member
    Revelstoke,BC Canada
    04 4x4 2.7 Tacoma
    I hate timing belts, thats why I stick with 2.7 4 cyl. You get better mpg and costs less for maintenance.
  10. Jan 6, 2010 at 6:14 AM
    Afwrestler1986
    Johnstown, NY
    The 4 Cyl would have been fine for me, but it didn't meet my criteria for the truck i needed. And it has more HP. :p
  11. Jan 6, 2010 at 7:38 AM
    Janster
    Jandy
    Lancaster, PA
    When my husband and I did the TB/WP on the 96, we didn't do any seals.
    We did the TB/WP, thermostat, and drive belts.
  12. Jan 6, 2010 at 7:40 AM
    Afwrestler1986
    Johnstown, NY
    I did the crank seal, didn't look bad at all, but I know how that goes. Spend 15-20 bucks on the seals so you don't have to tear it all down later on.
  13. Jan 6, 2010 at 7:53 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    x2..... We do this also
  14. Jan 7, 2010 at 5:36 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    sounds like a decent price - i had to have the seals, pump and belt changed out on my subaru a couple of years back. got two quotes - 600 and 800. of course i went with the cheaper one. i think the biggest difference is that the guy that quoted me 600 favored foreign cars and the guy that quoted me 800 was more familiar with american cars. once you find a reliable and reasonably priced mechanic, stick with them.
  15. Jan 8, 2010 at 3:06 AM
    vater1775
    charlotte
    Thanks for the posts. Fortunately I am mech inclined which is good..the bad news is my ex wife sold all of my tools 14k worth during the divorce. so I think I will let Toyota do my work for me..thanks again
