Timing chain cover leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waller24, Dec 24, 2011.
  1. Dec 24, 2011 at 5:53 PM
    waller24
    waller24 [OP] Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    Is it worth getting this fixed? 1300 dollars since I'm at 78k miles.
    It's not that bad but that's alot of money
    I just noticed it today and then I saw the tsb up to 60k with doesn't help me. I bought this truck from a guy who was leasing it but in order for me to buy it from him , he had to first buy the vehicle he was leasing from Toyota. It's an 2007 and when I got it it had 46k. So would they have done a 7 year 100k power train on this? I'll check Monday just curious yalls thoughts
  2. Dec 25, 2011 at 3:24 PM
    waller24
    Alabama
    what have y'all paid to non dealer mechanics to fix this?
  3. Dec 25, 2011 at 5:51 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    around my area....at least half that
  4. Dec 27, 2011 at 8:20 PM
    waller24
    Alabama
    i got quoted around 700 from an independent mech. I cleaned it up real nice and found the small crevice. Its so minimal and scarce that i think I'm just going to wait it out till it gets bad.
    What yalls thoughts on maybe putting a small layer of engine silicone adhesive on the crevice making sure the surface is clean and dry? would i be wasting my time?
  5. Dec 27, 2011 at 8:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Supposedly there are dealers who try to do this under warranty. :eek:
    I have done such things before. Sometimes get lucky, other times not.
  6. Oct 11, 2017 at 6:06 PM
    TTG
    TTG New Member
    Today, Oct 11, 2017, Toyota dealer quoted $2,500 to fix timing chain cover leak on '06 Tac with 76K miles. Independent garage quoted $2,000 for labor only, that's 20 hours at $100 per.
  7. Oct 11, 2017 at 7:55 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    If your fixing it; I recommend using Hondabond; its the best stuff out there for sealing anything. I use it on timing covers, water pump housings, thermostat housings ect. and when I rebuild transmissions; this stuff will stick to anything and it cures within a good 30-45minutes, sometimes as quick as 15minutes if its warm out. It'll still seal even with oil on the surface, its not like the cheap RTV stuff that requires 12-24 hours of curing time before your able to use the vehicle. It does however cost about 20-25 bucks at the honda dealer.
    I say try the hondabond on the area and see if it'll seal it up. Its good stuff and the only gasket/sealer maker that I use on any vehicle. I have yet to find anything else better and believe me I have tried everything out there; I build my own engines and rebuild a lot of transmissions.
